Results 1 to 16 of 16
2-stroke weed wacker issue.. won't stay running
    Just Registered bump909's Avatar
    Apr 2005
    Lynn, MA
    iTrader Score
    2 (100%)
    I've got a John Deere weed wacker that I sort of inherited from my family.. only problem is it doesn't run more for a minute or so then pukes and dies. I'm thinking something is gummed up, but I don't know where to look now. This is what I've done so far:
    - replaced spark plug
    - replaced oil/gas (correct mixture)
    - cleaned air filter
    - sprayed tb/carb cleaner in the tb
    Still no luck. Any ideas? It's only a few years old and is in good shape otherwise.
    0 Not allowed!
    '01 Aprilia SL1000 Falco
    I'll always be greasy on the inside.
    Infected Slyder's Avatar
    Concord, NH
    iTrader Score
    Re: 2-stroke weed wacker issue.. won't stay running
    Carb, no TB's on those things.
    I bet the carb is gummed up and needs a good cleaning. The jets are probably plugged or partially plugged. Unfortunately you'd not be able to clean the jets and the rest of the carb without taking it apart.
    0 Not allowed!
    Lifer snwbrdr435's Avatar
    North Shore Ma
    iTrader Score
    1 (100%)
    ^ +1 Carb is probably gummed up thank you ethanol.
    0 Not allowed!
    Apr 2005
    Lynn, MA
    iTrader Score
    2 (100%)
    Thanks guys, see.. I don't know much about 2-smokes.
    Is it ok to spray a crap load of cleaner in the carb? That's something I haven't tried yet. If it's the jets, could that be a costly repair bill?
    0 Not allowed!
    Concord, NH
    iTrader Score
    I'd take the carb off and take it apart to clean it. Without really looking at it, you might be able to take it apart without removing it....but taking it off completely shouldn't be a hassle.
    You might need a new gasket, carb cleaner...not expensive at all.
    If you aren't comfortable taking it apart, ask a friend or someone who is to do it. Probably won't take very long.
    0 Not allowed!
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    iTrader Score
    If its older than ethanol will f*up all the rubber parts
    Hoses , diaphrams turn to brittle plastic and crack
    0 Not allowed!
    Glen Beck is John the Baptist
    Old and Slow Sheppo's Avatar
    Westford, Ma
    iTrader Score
    2 (100%)
    throw it away and buy a new one it will cost you more in time and aggrevation than the thing is worth.
    -Not trying to be a smart ass honest-
    0 Not allowed!
    Posted by Jane in BoxChat
    Aug 2004
    Baltic,CT
    iTrader Score
    Frankly all my garden implements have turned over sinse ethanol
    0 Not allowed!
    iTrader Score
    12 (100%)
    Get a couple guys to help lift it.
    0 Not allowed!
    Waterbury, VT
    iTrader Score
    I lucked out with mine by dumping a healthy dose of carb clean in fresh pre-mix, and then running it on half choke until the exhuast note changed, then I flipped it to no choke. Since then it's run great - next fall, it and everything else I own will be run dry before being put away.
    0 Not allowed!
    SSearchVT
    Dec 2005
    Hartford region, Connecticut
    iTrader Score
    Quote Originally Posted by Slyder27 View Post
    technically speaking, you are wrong. a carburator has a throttle plate in it as well (usually, though some may use a slide rather than a standard butterfly).. ALL function as throttles, and thus are throttle-bodies.
    the term has come to refer to a fuel injection system's throttle plate region, but it is not necessarily such a limited thing.
    0 Not allowed!
    Get out while you can
    Find your own path
    Dec 2005
    iTrader Score
    2 strokes should never be run dry.
    out of fuel is out of oil.
    bad things happen.
    0 Not allowed!
    Find your own path
    Apr 2005
    Lynn, MA
    iTrader Score
    2 (100%)
    Thanks again guys.. went outside to try cleaning out the carb again and remembered I pulled the rubber fuel line out of the tank when I was messing around with it before. So getting that back in is the biggest issue right now. Major PITA trying to feed that rubber tube into the hole in the tank that is smaller in diameter.
    0 Not allowed!
    Aug 2004
    Baltic,CT
    iTrader Score
    Grease it up and suck it in
    Vacuum if possible
    Thread tough fishing line out through the hole as a snake
    then pull it throug
    0 Not allowed!
    beige camry attack mojobreakfast's Avatar
    Salem, MA
    iTrader Score
    I second checking rubber/plastic hosage for crackage/breakage. At a yard sale recently, I bought a Shindaiwa brush clearing thing, same as a weedwacker but with a skil saw blade on it. Shindaiwa's are big bucks, not cheap shit you get at Home depot. Landscaper grade. It was in mint shape but didn't run. I got it for $35.
    After head scratching & swearing, the problem was the fuel line (with integrated primer bulb) had a small crack in it, difficult to see but detectable by a slight amount of fuel leaking when you tried to start it. I guess the engine was just sucking air through the fuel line. I got a new one on the interweb for $8 or something, slapped that puppy on there, good to go. A nice slathering of carb cleaner made it run even better.
    0 Not allowed!
    12 Multistrada S Touring
    11 Street Triple R
    Cabin Fever kb1's Avatar
    Dec 2008
    Down South
    iTrader Score
    Buy a new 4 -stroke...best 200 bucks I've ever spent!
    0 Not allowed!
  1. dirtbike won't stay running
    By breakdirt916 in forum Bike Maintenance
    Last Post: 12-22-08, 08:51 AM
  2. They must REALLY want me to stay
    By The Snowman in forum Off-Topic
    Last Post: 11-25-08, 08:24 PM
  3. 2 Stroke Dirtbike Engine Issue
    By Nazo in forum General Bike Related
    Last Post: 06-07-06, 10:48 AM
  4. my f4i issue
    Last Post: 10-03-03, 09:57 PM
  5. this could be an issue...
    By twrayinma in forum Off-Topic
    Last Post: 06-28-02, 02:09 PM
