Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
3D printing?
    Re: 3D printing?
    Steve Methia has been printing a bunch of face shield type things.
    Re: 3D printing?
    As of 5:00 4/6 we’ve made 137 holders, and Trimech made some for me as well. Delivering 30 today.
    Each one uses 1.99 cu in of material and the cartridge holds 42 cu in, so we can make 21.1 cartridges per spool. The “.1” may seem spurious but the machine meters it so precisely that it started the build with 1.42 cu in left, paused, and unloaded the old material. Popped in another one and we’ll keep trucking. Stopped building Friday to take a break and replace one of the feed tips: otherwise the machine has been running continuously since Weds March 26th.
    Re: 3D printing?
    Wild: RESEARCHERS DEVELOP HANDHELD 3D BIOPRINTER FOR TREATING SKELETAL MUSCLE INJURIES
    https://3dprintingindustry.com/news/...juries-170719/
    Hanover, NH
    Re: 3D printing?
    Garandman and others, how do you go about creating designs for what you print? I would love a horizontal tray or shelf where I could stand a bunch of magazines up on end, and then put that in my gun safe (whenever I actually get one). I found this online, but I would want a flat tray (say 30" x 30") to store them, instead of a something that mounts vertically...
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: 3D printing?
    Thingiverse has a bunch of stuff that you can download. https://www.thingiverse.com/search?q...&sort=relevant
    Otherwise you are going to need some sort of 3D modeler to design stuff.
    Blender, Fusion 360, and FreeCad are a few.
    There's generally a pretty steep learning curve to these.
    Hanover, NH
    Re: 3D printing?
    Yeah, I found this which I could use for my PTR91 mags. Basically I would just print ~10 of these and glue them to a tray. But how hard is it to take that model and (in CAD) replicate it 10x times and just print one big tray with 10 holders?
    Seacoast NH
    Re: 3D printing?
    I have designed exactly one print myself; a spacer for the arbor in my antique tablesaw that was basically a precision washer.
    Learning the CAD/3d modeling software is one of those things on my "one day" list that I just keep not getting to. I have a couple yootoobe primers half watched.
    The thing that will probably push me over the edge is when sketchup finally dies. I use that for all my cabinet and shop fixture designs. I refuse to use the hosted app version and the last build of the local mac version is getting buggier and buggier by the day.
    I'm ashamed to admit my 3d printer is offline and hasn't printed anything in over a year now.
    Edit: What I should have simply said was: good luck my friend!
    Re: 3D printing?
    Yeah with the cost of outside printing I haven't printed anything in a long time. Easier to design and then buy it from xometry.
    High maintenance priss
    Central MA
    Re: 3D printing?
    Think you mostly got your answer: you need to to take one of your mags and have the necessary features modeled which will interface with whatever rack idea you have. If you want to see someone step thru the process here's an example.
    To keep it simple & flexible I'd recommend a modular design like this one. Then you can link blocks to your sizing and create blocks for other types of mags. Also keeps the print sizes manageable for DIY.
    Re: 3D printing?
    I use SolidWorks and output an STL file.
    Just designed a lense cover for a research project.
    “When it comes to the kitchen, I have a narrow band of competency.”
    Master Mechanic Roger Barr in “Chasing Classic Cars.”
    Re: 3D printing?
    Same but I use solid edge.
    Lifer FirstDuc-1098's Avatar
    Central Mass
    Re: 3D printing?
    I think you can still get a free/cheap student /hobbyist access to cloud based onshape.com
    Shit Corey says:
    Central MA
    Re: 3D printing?
    Yep - also my understanding that OnShape supports free use for makers / non-commercial. The requirement is that your models will be in the public domain; you grant open license on whatever you create. I've read some good things about the software but haven't tried it myself.
    Re: 3D printing?
    The founder of OnShape was John Hirschtick.
    Along with being one of the MIT students that burned the Vegas casinos, he worked at ComputerVision before founding SolidWorks.
    Re: 3D printing?
    So what’s the all around best affordable, easy to calibrate, able to print ABS and food safe plastic printer with a heated plate and able to make something at least 6”x6”x6” these days?
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Re: 3D printing?
    Do you want one? I have one I ordered and never built. Anet A8M
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Re: 3D printing?
    Question for the gurus - I have 3 Makerbots in my classroom. NH passed a strict privacy law for school apps last year. All Makerbot sw is banned, including Makerbot Desktop. From what I've tried so far, it seems like the Replicators only recognize .makerbot file types, not gcode or other file types. Anyone know of other apps that will slice .skp files into a format recognized by Replicators?
    DanG
    - Blaise Pascal
    Re: 3D printing?
    You might check to see if GrabCAD Print can output MakerBot files. They are both owned by Stratasys.
    https://grabcad.com/print
    I had four MakerBots but gave them to Boston Collegiate Charter School and just use my uPrint.
    Posting Freak tonup's Avatar
    Feb 2008
    Alton nh
    Re: 3D printing?
    Trying to find someone to make some goofy clay target holders that can't be found anymore but are great fun for shooting. First question for you gurus, is a printer capable of making this little thing in the pics? It's nice to blow shit up than just poke holes in paper, and these little guys get hit now and again. Thanks for any help.
    Attached Thumbnails Attached Thumbnails 3D printing?-img_2825-jpg   3D printing?-img_2826-3-jpg   3D printing?-img_2828-2-jpg
    Re: 3D printing?
    Yes, a 3D printer can make it. It would be real easy to simply cut/file some plastic sheet with the product features you need as well.
    How many do you need?
  21. #46
    Feb 2008
    Alton nh
    Re: 3D printing?
    I would only need like 10-20, but not sure what the cost would be as I'm totally unfamiliar with the process. We don't hit them often but when you do, they're done. I work in wood and the time it would take me to scroll them out would be a bit much. Between work, then casting and loading and shooting, to pay someone to print them is a win for us.
  22. #47
    Walpole
    Re: 3D printing?
    Get a Prusa. Not bottom of the line, not top of the line. But owners of them just plug in and go after it’s setup. I spend more fucking time dicking around with my ender 3 than printing.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2018 Onewheel XR
  23. #48
    Member tucktuvak's Avatar
    Apr 2019
    Somerville, MA
    Re: 3D printing?
    Just got a prusa mini + a few weeks ago. If you buy one, ORDER THE ASSEMBLED ONE NOT THE KIT. I ordered the kit and it took me like 5 hours to assemble and it was a PITA. Other than assembly, it's awesome, prints very well. Actually printed a throttle body for my Husky supermoto on it a few days ago. Probably going to print some number plate holders for my new race bike in the next few days.
    YouTube: The Motorcycle Room 2014 MV Agusta Rivale - 2020 KTM 790 (race) - 2011 Husky SMR449 - 2011 TM Racing EN 250
  24. #49
    Re: 3D printing?
    Quote Originally Posted by tonup View Post
    If you can send me one I can draw it up in CAD.
  25. #50
    Feb 2008
    Alton nh
    Re: 3D printing?
    That would be a great thing. The wife loves her "bird board" as its calle, and to not be able to enjoy because of a simple plastic clay holder would be a sin. I'll PM you to keep this thread on topic.
