Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Air Compressors
    Air Compressors
    Ok, so my brother in law stole my small craftsmen air compressor, it was only good for filling tires anyway. And I will deal with him later.. Now I need a replacement. Would like something big enough to drive 3/8 ratchet . So what size works and what brands. Thanks
    Rust never sleeps. whynot's Avatar
    Arlington MA
    Re: Air Compressors
    Will it stay in the shop, or will you take to the track or what.
    I have a Sears-Craftsman that I bought about 20 years ago, works well. 2 hp, 20 gallon tank (horizontal). It has two wheels and a handle for moving it around. 20 years ago it was $180, probably twice that now.
    It runs 3/8 ratchets and 1/2" impacts, and air drill no problem.
    Here's a Sears search of $175 +
    Access Denied
    Don't believe everything you think.
    Lifer Falko's Avatar
    MoonTown
    Re: Air Compressors
    IF it is going to be stationary, go for an oil unit, belt drive. Much quieter than the direct drive oil-less buzz units.
    What's your price range? Ingersol makes some nice residential units. If you want something cheaper, Campbell, Craftsman, etc are all pretty much the same. I have a 40+ year old Campbell that I still run. She ain't pretty but she compresses air.
    Re: Air Compressors
    I bought a Harbor Freight 2hp, 8 gallon lube-able compressor. Don't use it a lot but it has worked well for nearly two years when called upon. Often on sale for $115, sometimes as little as $100. Portable. Spec is 4.5 SCFM @ 90 psi.
    Campbell Hausfeld is around $450 and Ingersoll $700, just couldn't justify that.
    PS. Somehow though I copied the HF site it brings you to Amazon....
    The one I have is #69667.
    “When it comes to the kitchen, I have a narrow band of competency.”
    Master Mechanic Roger Barr in “Chasing Classic Cars.”
    Lifer capitalcrew's Avatar
    Feb 2017
    Albany NY
    Re: Air Compressors
    Whatever you do don't buy a new budget IR from TSC or something like that. They're all cheap junk with a jacked up price and tan and red paint on em.
    It really depends on how much air you want and what you want to do with it. How many CFMs you need? You want to be able to move it? Single or three phase? Budget? No matter what you buy you're going to want more unfortunately lol.
    Re: Air Compressors
    Home shop only buget is $350 or so. Just want to drive.air ratchets. If I need impacts i have a great electric one.
    Re: Air Compressors
    You can get away with a smallish one. Remember, all compressors can drive air tools. It's the question for how long before they need to "catch up" in building pressure. That's why there is a CFM rating.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Jun 2016
    Foxboro
    Re: Air Compressors
    I'd recommend the one-and-done approach and picking up one of those 80 gallon two stage compressors. It's expensive but there is very little it can't do
    Lifer LuvDog's Avatar
    Ashland, MA
    Re: Air Compressors
    I have an old oiless devilbliss horizontal and a harbor freight veritcal oil compressor.
    The HF verical is much quieter. The price fluctuates a lot if it's on sale.
    29 gal. 2 HP 150 PSI Cast Iron Vertical Air Compressor
    2003 ZX7R
    1995 916
    Lifer loudbeard's Avatar
    Re: Air Compressors
    You're going to need a 10 horse rotary screw compressor. Anything less and you might as well use basic hand tools.
    MoonTown
    Re: Air Compressors
    We're pulling out two 350hp centrifugal compressors this summer. If you can wait, I can get you one, probably handle all your needs...
    Lowes always has a pretty good selection of compressors.
    Re: Air Compressors
    ^ this guy fucks
    Re: Air Compressors
    -Clayton
    2006 Suzuki SV650
    Re: Air Compressors
    We bought one of those at work. It's held up well. We also had a Craftsman Professional with similar specs, about $550.
    Lifer golden chicken's Avatar
    Fitchburg, MA
    Re: Air Compressors
    I bought a couple cordless ratchets and I basically never use my air ratchets any more. Haven't made the leap to a cordless impact yet.
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: Air Compressors
    Out of curiosity, what are the electrical service requirements for something this large?
    Re: Air Compressors
    At 480 volts, 3 phase, it's approximately 400 amps. Most electricians never see an installation like this.
    Re: Air Compressors
    all this compressor talk reminds me I need to change the oil in mine
    MoonTown
    Re: Air Compressors
    yep, that's about right. They are being replaced with two 300hp rotary screws. Centrifugals have issues with capacity and unloading. Unless your load is constant within 10%, they aren't great, they will blow off to maintain proper pressure, not exactly efficient. These set next to a 300hp screw and a 350hp variable speed screw. Yes, much compressed air load, about 3500-4000 cfm average. This project is slated for 1.5mmkWh of savings due to a number of operational issues.
    We were also just involved with three 400hp high pressure machines (550PSI), big multi piston rigs. Those will spin your impact gun.
    Re: Air Compressors
    Sounds like you work at an interesting shop. I've spent most of my career as a project manager and control tech for industrial electrical installation, a retrofit like that is always a fun challenge. Now I just manage a maintenance and facilities department, I'm working on the owner right now to replace our shop compressor and upgrade the air line system. Our demand is small comparatively, we just run a 10 horse compressor, but I have about 1000 feet of air lines and 85% of them are rubber flex lines. Yes, the type you're only supposed to use for 5-10 feet of an equipment drop. Anyway, I was quoted surprisingly low for a nice 10 horse rotary screw compressor, less than $5k for the unit including the starter. That with a 200 gal tank and hard line upgrade and we'll have our air situation squared away.
    Seacoast NH
    Re: Air Compressors
    What do you like for ratchets?
    I hear great things about the Dewalt brushless impacts. I have a cheap Craftsman C3 system impact that does the trick 9/10 times. That system has a lot, even a brad nailer.. but no ratchet.
    At this point the only things I'd want a compressor for is media blasting and painting.. both are high CFM needs, naturally.
    MoonTown
    Re: Air Compressors
    I don't know who your utility is, but there used to be incentives out there for compressed air storage. 200 gallon won't be substantial, but it can get you a couple bucks for simply signing an application.
    Our shop does mostly efficiency projects on all avenues of industrial systems. Compressed air is just one of the rabbits in our hat. It's a neat place to work for the most part, see a lot of different technologies.
    Posting Freak OneCheekRider's Avatar
    Aug 2012
    LA
    Re: Air Compressors
    Sorry to derail but Craftsman does have a ratchet for the 19.2V C3 system. I have it and it works well. Maybe it's discontinued?
    Amazon.com: Craftsman 19.2 Volt C3 Max Axess Power Ratchet (Bare Tool, Bulk Packaged): Home Improvement
    I paid a lot less for mine a few years ago though.
    The craftsman 19.2 'heavy duty' electric impact works great for my needs. I won't go pneumatic unless i have to.
    Re: Air Compressors
    nothing like a nascar tuned air wrench and a bottle of nitrogen
    Air Compressors
    I just purchased a husky belt driven one.
    It was $349.99 and 20 gallons.
    Also got these 2 1/2 inch Guns.
