Results 1 to 15 of 15
Audi 2.0T owners here?? potential modding?
    Apr 2004
    Wilmington, MA
    SO i've had my 2009 audi for 2 years now. bone stock basic trim
    Looking to see what I can do with it
    Cold air intake? lowering springs/coilovers/larger wheels I'm a total beginner at modding a car
    Id ideally like to minimiize the turbo lag I feel primarily. I "think" based on the threads i read on the audi sites that the lag isnt significant but I feel its.( wide's rdx throttle response is nstatn(v6) mine is definitely not
    Doesnt seem to be any 1 cure all for it, other than a "tune" it seems?
    i'm new to the "tunes" language.
    All i've done to the audi is put on stiffer engine mounts which have helped tremendously in cornering/response.
    Not looking to track this car but enjoy it on the work commute
    PS i'm home recovering a from a hip replacement so i'm seeing how I can waste money thru amazon and what projects i can line up for this winter
    hmmmm......
    Hanover, NH
    Re: Audi 2.0T owners here?? potential modding?
    Massachusetts, in its infinite wisdom, is about to unleash its new vehicle inspection system specifically (right or wrong) to focus on things like ride heights and CAIs.
    Massachusetts Car Enthusiasts Fear New Inspection Program - The Drive
    Sigh.
    TWINS! xrocket21's Avatar
    Central Maine
    put a tuner on it and up the boost. You wont be disappointed.
    Lifer JohnnyV's Avatar
    Westborough, MA
    I've had a lot of "fun" playing with my Audi's. Friend has done just about everything there is to do to his 2.0T A4(wheels, suspension, stage 3 turbo kit that I helped him install, etc). They become money pits very quickly and the more you play with it, the more often things seem to break, but I guess that's true with modifying any car.
    For what it's worth, APR has partnered with VW/Audi to do flash tunes that don't void factory warranties, and you can get the flash done at participating dealerships.
    Apr 2004
    Wilmington, MA
    tuner?? kit name? price? have a link?
    I searched a4 tune and first hit
    Audi A4 B8 2.0TSI ECU Upgrade Software - 2009-2013
    stage 1+ might be it? would the boost be also done with this tune? Dont read it here
    dont have to worry about factory warranty anymore an '09 with 135k
    So no CAI....silly Mass... wonder what they'll do with my snorkel on my xterra?
    hmmmm......
    Lifer Danz19899's Avatar
    Grafton, Ma
    Modifying Audi's can be tricky business. Biggest thing i can say is dont try to be cheap. German cars destroy cheap components.
    For performance I strongly recommend APR . They have a partnership with Audi and tend not to cause any issues. Some of the other companies can have funky check engine issues. You may be able to get away with an Exhaust too, i'm honestly not sure with the new inspection BS. I'm working in CT now so i'm out of the loop.
    As for coil overs and wheels those will make a huge improvement aesthetically and handling wise. Just like I said early don't cheap out, get quality coils, wheels and tires.
    www.bostonmoto.com
    Ride to live, live to ride
    Nov 2009
    Bristol County
    I think what you might be perceiving as turbo lag is really throttle response. The turbo motor probably has lower compression and different cam tuning among other differences that ultimately affect the way your car feels the in the first moment you press the pedal.
    nedirtriders.com
    Apr 2004
    Wilmington, MA
    Quote Originally Posted by Danz19899 View Post
    Hey Dan Side question.... do you have that site for the "audi rims" that arent $$$$$ OEM by chance?
    hmmmm......
    Central Maine
    Im pretty positive a tune will make him happy...
    throw an APR program in that bitch and happy boosting
    Apr 2004
    Wilmington, MA
    that's what i'm leaning too right now....
    hmmmm......
    Westborough, MA
    What he said. If you're looking for a little extra you could throw on a AWE exhaust and intake, let her breathe a little more and get the stage 2 program. Really livens the thing up quite a bit.
    Seacoast NH
    I had (virtually) the same motor in my Jetta wagon. I left mine largely stock because I'd discovered track days and was largely feeding that addiction. I did a heavier sway bar and bilsteins (on stock springs). Left the motor alone.
    My cousin had a GTI and went bananas on it. 4-5 different sets of wheels. Adjustable coil-overs. "Dropped". Programmed. CAI. Exhaust.
    For the most part we both found the cars easy to work on and mod. You will need special tools for everyfuckingthing though. Lots of "12 point" drive.
    APR definitely seems like the way to go for a canned program.
    Probably my favorite mod on the car was a kit to take some of the slop out of the cable operated shifter. Dunno if this is an issue with the longitudinal mounted A4. But the shifter in the transverse mount FWD cars was pretty vague. Someone sells a kit that takes out most of the rubber and plastic bushings and replaces with brass. Also reduces the throw just enough. That, plus a heavier weighted shift knob not made out of plastic, made the car much more satisfying to drive.
    Westborough, MA
    JHM is the way to go with Audi/VW if you're going to solve the shifter slop issue. Have driven cars with Neuspeed, ECS, and the JHM I had in my S4 was far and away superior. Well worth the money.
    if you go with new wheels, make sure you choose ones that are lightweight, can really feel the difference.
    i've been having fun tweaking my GTI (2.0T TSI). like these guys mentioned, some of the basics really up the fun factor ... so far i've done: Boomba short shifter (weighted knob next), Neuspeed Power Module (sweet boost for cheap, plug 'n play), AFE panel filter in stock box (open intake took power away from bottom), GFB DV+ diverter valve, BC adjustable coilovers and Neuspeed lightweight wheels (dropped ~10lbs per corner) ... car is a blast to drive. still tuning the suspension but moving to exhaust next.
    i had the same goal as you, i rarely commute but when i do i'm in the car for hours. big smiles every drive ... and still use it to tow a dirt bike
    Westborough, MA
    "Tweaking" your car is a slippery slope..... ask me how I know
