Results 1 to 7 of 7
Auto body fix - advice needed
    Member bassomatic's Avatar
    Feb 2014
    Pembroke, NH
    I'm a dope and punched a small hole with the tongue coupler of my trailer in the rear plastic bumper of my Mazda 3. I'll say up front that I have next to zero body work experience. I can't see a way to pull this back to shape and bondo the scar without removing a little plastic first. This doesn't have to be a perfect fix and I'm mostly interested in just keeping water out of it. Any suggestions?
    Auto body fix - advice needed-carhole_2-jpg
    Auto body fix - advice needed-carhole-jpg
    Re: Auto body fix - advice needed
    They sell repair kits with screen and glass reinforced filler. There are many excellent YouTube videos. You can drill holes in the deformed plastic to help give a better mechanical bond.
    But honestly I'd get some tape that's close in color and just cover it for now. Because during "trailer season" it might happen again. The Sprinter doesn't have a backup camera so I zonk it regularly.
    If stupidity got us into this mess, why canít it get us out?
    Will Rogers
    Jun 2005
    If you choose to fill it make sure you get the right filler. It needs to be flexible... more so that standard bond-o. 3M, Bond-O, etc sell kits specifically for plastic bumpers.
    Lifer G21forme's Avatar
    snh
    Buy a sticker
    [/IMG][/URL]
    Nov 2009
    Bristol County
    Bondo may work on metal panels, but I'm not sure it's going to last long on a flexible plastic bumper. It might be less effort and similar cost to buy a used bumper.
    I'm not sure water entry will matter much there. Probably need to watch a youtube of bumper removal to be sure, but I'd bet it just drains right out the bottom. Pop the 'tab' out instead of in and barely anything's getting in anyway.
    02 Aprilia Futura
    86 GPz900R
    Hypertarded
    Buy a sticker
    yeah, one of these should work
    Auto body fix - advice needed-byedon1-jpg
    Lifer golden chicken's Avatar
    Fitchburg, MA
    There's not much you can do that'll fix it and last and look good. You can try popping the entire cover off (surprisingly easy) and pressing the broken bit out after adding some epoxy. Theres nothing behind it that matters if it gets wet. Or grab one from a junkyard and swap.
