Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Body On Frame SUV - 4Runner
    Re: Body On Frame SUV - 4Runner
    A V8 would have some element of speed…
    “When it comes to the kitchen, I have a narrow band of competency.”
    Master Mechanic Roger Barr in “Chasing Classic Cars.”
    Apr 2004
    Wilmington, MA
    they're out there in 4runner land just hard to come by, with leather and 3rd row ( for kids and and an adult for small 30 min trips
    and the v8 is sooooo worth it. Good speed Suprises me.
    hmmmm......
    Lifer loudbeard's Avatar
    The problem with the V8 is it comes in the 4th gen....which is absolutely hideous.
    That may be, but I am working on this third Gen with the 3.4, which by all accounts is a supremely durable engine.
    Thing came with support bars but no crossbars and bases. Have some square Thule bars so need to see what I can use for bases.
    Attached Thumbnails Attached Thumbnails Body On Frame SUV - 4Runner-df8d1acd-7c44-4f39-8229-6ef00723bd40
    Apr 2004
    Wilmington, MA
    I used these
    Thule 450 CrossRoad Railing Roof Rack Foot Pack (Set of 4) https://www.amazon.com/dp/B0006HAPRA..._xX2ynTDQQNQfK
    On a Gen 3? Don’t seem to have room underneath for the metal strap.
    Apr 2004
    Wilmington, MA
    No not a gen 3
    I've used it on my Xterra and my current gx470
    Have a set of those used with an Outback Gen 3. But the Gen 3 4Runner rack base is flush.
    Somewhere saw an upgrade kit with larger battery cables. Recommended?
    Attached Thumbnails Attached Thumbnails Body On Frame SUV - 4Runner-ac8bb06f-a51a-4aaf-bada-e03c7bc5322a
    Bought some Gen 5 17” takeoffs for summer tires. Michelin AT2 was almost $300 each and Nokian Rotiiva is back ordered.
    Decided to try the new BF Goodrich Trail Terrain TA for mostly highway and very limited trail use. $196 each for 265/65x17.
    https://www.bfgoodrichtires.com/auto...il-terrain-t-a
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    I believe those came out recently. Not too many reviews on them just yet, be sure to post how you like 'em!
    They were introduced September. BF Goodrich seems to be very competitive in that market segment.
    No love for the Wildpeaks Gman?
    Moot as they don’t make 265/65x17.
    I was looking for a “just barely” All Terrain tire. Some of the serious tires are immensely heavy: up to 50 lbs. The BFG is heavier than I like at 34. The Rotiiva was under 30.
    Wanted to install LED turn signals but the OEM flasher doesn’t work with them. Bought a well-reviewed flasher on Amazon for $11.
    Installed today. The flasher is on the back of the fuse box so takes a little effort to get to. OEM flashers sell for $40 so perhaps I can sell the old one on eBay for a few bucks.
    Video link doesn’t seem to work but LED is on left.
    https://photos.smugmug.com/Cars/n-NM...G_1069-640.mp4
    Apr 2004
    Wilmington, MA
    If u want to upgrade headlights. Try the morimoto megatron LEDs crisp , clean defined cutoff. Around 40$
    I'll be upgrading mine from those to something from diode dynamics with ballast etc.
    I might even have some spares if u want and ur the same bulb as me
    Got the BFG’s mounted and they look like what we wanted. Should hold up OK on occasional rocky trails, without being noisy or hgh resistance. We didn’t need mud or snow traction. Continuous tread outside fro quiet highway ride, circumferential grooves for rain, reinforced sidewall for rocks. Surprised they have the 3P rating but the sipes do extend full depth of the tread blocks.
    Car is in the shop this week. They are going to drop the fuel tank, cut out the rusty area around the frame perforation, and weld in a patch. It’s a relatively straight, flat section.
    Even though it’s not likely a structural issue, it bugged me so it’s gotta go!
    This is kind of amusing. Guy made a chart of 4Runner wheel bolt pattern, hub bore, lug nut size and type, and torque value from 1990-2021.
    https://www.sparkyexpress.ca/blogs/a...t-pattern-more
    Summary: they are all the same. Torque changed from 83 to 81 lb ft in 2010…..
    Hypertarded
    Well, Toyota HAS been using the same in dash clock since 1980
    Body On Frame SUV - 4Runner-img_6546-jpg
    consistency is job #1
