Results 1 to 10 of 10
Boiler replacement
    Jan 2014
    Framingham, MA
    Boiler replacement
    Think I'm going to go ahead with this project but it's so damn hard to tell if I'm being bent over. Respected local company, I don't expect a cheap rate just a fair one. Don't want to pay more because there's a mass save rebate and loan.
    Replace existing gas boiler (forced hot water, 2 zones) and gas fired water heater tank with 200k btu version of this:
    Lochinvar Products - Noble Fire Tube Combi Boiler product line.
    1yr labor warranty, 5yr parts, lifetime boiler.
    They are going to install a plumbing board (air elimination, dirt seperator) and do everything else they should be doing. Quote is almost 15k.
    Rust never sleeps. whynot's Avatar
    Arlington MA
    Re: Boiler replacement
    I replaced two boilers about 8 years ago, got great prices on the boilers going through MASS SAVE Residential Rebates & Incentives for Homeowners, Renters, & Landlords
    As I recall, the gas boilers (Burnham) were about $1500 each through MASS SAVE.
    Installer was Unified Mechanical, Wakefield MA, they acted as general contractor. They did the whole job in one 8-hour day in January.
    Pricing overall was very good, but being a few years ago, may not mean too much. The total bill was $10K for two boilers installed, all cleanup and disposal, all piping connected, controls wired, chimney lined and pointed, two oil tanks removed and disposed of. (Already had gas piped in the house for hot water and stoves.)
    That's all I know about boilers, hope it might help.
    Don't believe everything you think.
    Sounds high to me, but mass prices always seem to be double what other states are. I had a quote last year to replace our boiler only and it was $5k. The boiler they were installing was $2500-3k just to buy, so $2k in labor for 1 day... I denied it. My last house I had a complete heating system installed in a new construction house, with central air for $13k for comparison.
    A Big Powerful Sportbike
    Not sure if it is comparable but I replaced a 30 year old gas boiler for $7k out the door (taxes, fees, everything).
    Jan 2014
    Framingham, MA
    It's hard to compare apples to apples. I know this is a good company who will do this high end install right. Sales person expected about 1.5 days for install not including the board that they would assemble and pressure test at their shop. I'm sure if I wanted a straight boiler swap it would be a fraction.
    Lifer Stromper's Avatar
    Eastern Ct
    Corn hole
    Boiler delivered should be 3000 2 guys 2 days 2500 extra stuff another 1500
    My water heater is a 3rd zone and was about 2000 it is all stainless inside
    Unless its an emergency do this stuff in the summer
    The calculus of hate
    Lifer Falko's Avatar
    MoonTown
    That's a bit high.
    Lifer zxme's Avatar
    Mar 2007
    Mass
    Buddy just did a combo unit through Mass save and was 2500 out of pocket all done . A regular slant Fin or Weil McLain will be 5500 installed all done
    Jan 2014
    Framingham, MA
    Thanks guys. I hit pause on the job and I'll get some proper quotes in the Spring. If I miss out on the rebate then so be it.
    xxaarraa
    Guest
    The numbers I am sharing below are for someone to install the boilers for me. I have no idea what numbers would be like if you installed them yourself.
    I installed two new boilers in my two family this year and split the utilities for the first time as well (so involved National Grid setting up a new meter bar, new meter, upgrading old meter and plumbers tracing pipes between the two units).
    Paid $12,500 to one plumber for one boiler and $9,650 to another a few months later. I went with identical Navien NCB-240 'combi' boilers for both units. The first one was an emergency as the old boiler quit working abruptly in middle of winter, and that plumber is usually a high priced but immediate response type of guy. In both cases, MassSave subsequently cut me a check for $1600 each time about 8 weeks after install paperwork was faxed to them.
    So all in, my average cost per high efficiency boiler installed was $9,475. Happy to send you the contact info for either of my plumbers if you need.
