Results 1 to 13 of 13
Carpenter Ants
    Oct 2007
    Milton, MA
    Carpenter Ants
    Over the summer I remodeled my master bath (1st floor). When I tore out the shower the exterior wall was crawling with carpenter ants. I had a local exterminator come in immediately. He sprayed the impacted areas, and then did the entire perimeter of the house inside and out. I haven't seen any evidence of them since, but then again I didn't see evidence of them before either. I have no experience with this, and wonder if I need to do some sort of follow up treatment in the Spring?
    Re: Carpenter Ants
    I found theses work very well./http://www.terro.com/terro-liquid-ant-baits-2-pack they have outside and inside bait traps. put four to six around the outside of the house and inside under the bathroom and kitchen sinks. Simple and cheap, the trick is not to kill any ants you see as they need to take the bait back to the nest.
    Oct 2007
    Milton, MA
    Re: Carpenter Ants
    Thanks - they have these at Home Depot so I'll pick some up tomorrow. Seems carpenter ants don't necessarily go dormant in the winter, which is why they probably set up shop in a south-facing wall. I'll put some of these under the new bathroom and see what happens.
    Re: Carpenter Ants
    Spring. for the outside traps.
    Oct 2007
    Milton, MA
    Re: Carpenter Ants
    right - figured that!
    New Haven-ish, CT
    Re: Carpenter Ants
    I've used the terro stuff before too and it works well. I got this one, used it a handful of times over the years
    Access Denied
    -Matt
    High maintenance priss
    Central MA
    Re: Carpenter Ants
    We had the same problem in our new house, but we would see 10+ a day on the hottest days. It was pretty obvious that they were probably coming in near a water damaged window/framing.
    We had a pro do interior & exterior perimeter sprays 2 summers in a row. II also did the Terro dust and Advion. Find how they are getting in if possible. Once it starts warming up (spring->summer) go outside at night and you might catch 'em. Then put 1" strips of this stuff along their path: Advion Ant Gel. The exterminator said that they are looking for water. If you have sweating or leaky pipes: get that sorted. After the 2 years of treatment: haven't seen a single ant since.
    When we finally tore out a water damaged window this year: bottom of 3 stud cavities filled with carcasses.
    WMC original sdog30's Avatar
    Burgy
    Re: Carpenter Ants
    Carpenter ants usually only cause damage and get in when there is wet wood. Once they get in, they are worse than termites.
    If it was in your bathroom, more than likely it was a leaky shower surround or toilet wax ring. Double check that water is not getting in from the outside somehow.
    14 Triumph Street Triple R, 15 KX450F sumo, 15 Husky 250SXF tard, 14 KTM 250SXF and Cole's Grom
    LRRS/CCS #66
    Lifer Falko's Avatar
    MoonTown
    Re: Carpenter Ants
    Spray your foundation every couple of months with a carpenter and spray. They don't fly to your house, they crawl up the exterior. If you have the spray on the foundation, they will not typically cross it.
    Oct 2007
    Milton, MA
    Re: Carpenter Ants
    The shower I tore out was a rotted mess. That's where the biggest concentration was.
    Burgy
    Re: Carpenter Ants
    Quote Originally Posted by Bonk! View Post
    Usually if it's isolated like that from a leak, if you cut out all the rotted and infested wood and fix the leak (i.e. new shower that is sealed) you should be all set.
    LRRS/CCS #66
    Mar 2004
    woonsocket ri
    Re: Carpenter Ants
    It's cheap insurance to have the exterminator come back for another round. It might be overkill and it might not.
    Natick
    Re: Carpenter Ants
    I had an acute infestation after being away from my new constructed house for 3 days. Cut a few overhanging branches on the house and had the exterminator spray.. they said to spray 3X a year and they should start turning around. If I found any with wings then I'd have to be worried about a nest. So far so good, haven't seen a single one again..... They sprayed for the second time just a month ago.
