Results 1 to 18 of 18
Carpenters/Builders-some garage finishing questions.....
    Jan 2007
    Rochester MA
    So I'm getting ready to finish my garage, I added some stairs, next step is putting a floor upstairs for storage. I've done this before at a previous house but it didn't have the angled 1x6's up there, which gave me a ton more room to move and keep things a little neater. So my question is, do I have any options with these? I'd love to take them out completely or even replace them with a knee wall further back. I did some googling on it but I can't really find anything solid on the topic. Any thoughts?
    Attached Thumbnails Attached Thumbnails Carpenters/Builders-some garage finishing questions.....-20180108_123543-jpg   Carpenters/Builders-some garage finishing questions.....-20180108_123533-jpg   Carpenters/Builders-some garage finishing questions.....-20180108_123525-jpg
    Raymond NH
    Re: Carpenters/Builders-some garage finishing questions.....
    What purpose do those 1x6 boards serve? they are useless under compression and there's no tension in that part of the structure unless the joists are way under-sized and they are holding up the floor.
    Raymond NH
    If they are under tension, you could build knee walls further back with studs that extend to the bottom of the joists and beef up the joists between the knee walls with some OSB laminated to them.
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Looks almost like the used those spring boards to hang the joists from the rafters.
    Is there a beam in the space below?
    Lifer loudbeard's Avatar
    That's a cantilever style roof, don't remove those.
    Edit:
    You could convert it to a strong back style bracing as you already have collar ties in place. It is still a bit intrusive, but it doesn't have purlins at every joist so you can access the area inside the purlins for storage as well.
    Jan 2007
    Rochester MA
    Looks almost like the used those spring boards to hang the joints from the rafters.
    No beam. Just 2x8 joists.
    Jan 2007
    Rochester MA
    Edit:
    You're speaking Greek right now dude! From what I read, some say they keep the garage from falling over or blowing down, others say they are just there for construction to hold up the joists until the sheathing goes on. Either way, It's an attached garage, it's not going to fall over or blow away.
    edit: And to my original post, I've seen and owned other houses that had nothing at all in that space, some older some newer than this house...so why must I keep them?
    They are holding your ceiling/floor up. Depending on the span, you could sister the floor/ceiling joists with LVL, or I joists. Or you could put a beam in the garage below the joists.
    You can’t just remove them, and you can’t move them to mid span of the roof rafter. Stick built roofs are by design, not rated to hold any internal weight within the rafters.
    A Big Powerful Sportbike
    Jan 2007
    Rochester MA
    The alternative to stickbuilt is prefab correct?
    For a roof system, it’s stick built or truss system.
    conventional design ......... maybe, I don't know
    what I do know, is that internal loading is whatever it is designed for
    if you want it to hold more load than normal, design it and build it that way, or maybe that $1k LVL beam I put in my barn was a waste of $$$$ cause stick built roofs have a design limit that you can't surpass
    Jan 2007
    Rochester MA
    Yeah I'm not putting in a beam just for a few extra square feet of storage. I don't know that much about the engineering of a building, but I still can't see why these diagonals have to be there when a garage that looks identical to me with no beam doesn't have these.
    Quote Originally Posted by b0xmonkey View Post
    They probably don’t need to be there to hold up the ceiling alone. Add plywood and storage space above and you change the load rating.
    How wide is the garage?
    What is the actual size of the ceiling joists?
    Unless you’re specific with whoever engineers your roof, and tell them you’re going to add internal load, it’s going to be designed by snowload in your area. My last house had a 20” LVL as a ridge, to meet current snowloads.
    Jan 2007
    Rochester MA
    Garage is a 2 car, 2x8 joists.
    So about 24’ span. To give you an idea, the max span for 2x8 @ 16”oc for floor load is 12’. You can up that to 14’ by going 12”oc
    Jan 2007
    Rochester MA
    Sounds like I should just keep it simple up there then. Doesn't seem worth it to add a beam for a small amount of storage.
    retrofitting, I agree,
    but in initial design and construction, it can make a big difference in many ways. my beam spans 30 feet, holds up one end of a loft designed for commercial 100lb/sf load and can support a trolley rail attached to the bottom that can lift 2 tons and I have a 30' space below with no support columns. It came in 4 2"x22"x30' sections that I bolted into a 8"x22" beam, Putting it in place almost became a fiasco, I did the "get four guys from NESR and lift it" routine, I shouldn't have engineer graduated tapes on one end of the beam and feet & inches on the other, luckily, it was only a jack stud, and discovered before we notched the beam
    glad I built it that way, it was not intended to be an office, but is out of necessity, I can't even guess how many tons of paper are in file cabinets & plan files "up in the archives" in my loft
