View Poll Results: Chainsaws: What Brand do You Use? And Why?
Voters
74. You may not vote on this poll
  • Stihl
    32 43.24%
  • Husqvarna (from a Dealer)
    28 37.84%
  • Japanese (Tanaka, Shindaiwa, etc.)
    0 0%
  • Chinese (any Big Box Store Brand; Husky, Jonsered, Earthquake, BlueMax, etc.)
    10 13.51%
  • Other: I know I missed a few, Just post it below
    6 8.11%
Multiple Choice Poll.
Page 34 of 40 FirstFirst ... 142425262728293031323334353637383940 LastLast
Results 826 to 850 of 980
Chainsaws: What do You Have?
  1. #826
    iTrader Score
    11 (100%)
    Re: Chainsaws: What do You Have?
    Not that I'm looking for ways to do it but how frequently does kickback happen to where it's a discussion point?
    I've had one occurrence where the brake kicked in but that was it. What gives?
    0 Not allowed!
  2. #827
    Lifer ZX-12R's Avatar
    Candia, NH
    iTrader Score
    Kickbacks happen often but most are easily manageable and given no thought. The problem is when they are severe enough that the bar strikes the operator, the results are usually gruesome even if the inertia brake manages to stop the chain before contact occurs. Those are the ones that drive the discussion.
    0 Not allowed!
  3. #828
    iTrader Score
    sprocket nose helps reduce kickbacks cause it helps keep the chain speed up.
    I find I have most kickbacks when I'm limbing and hit the wood before the chain speed us at maximum, happens more now that I am running a 20" bar, the saw really isn't big enuf. I got the longer bar so that in my old age, I wouldn't have to bend over so far when limbing .... didn't work out the way I had hoped. I really don't want to get a bigger heavier saw, although I wouldn't mind one to work in the wood yard where weight isn't so much of an issue
    0 Not allowed!
  4. #829
    Lifer Falko's Avatar
    MoonTown
    iTrader Score
    Not to switch sprockets off the kickback discussion, but what do you guys use to sharpen the blades? I've been using a file and guide but the files seem to lose their edge quickly. I thought they were just getting fouled but the tips are getting wrecked. Granted these files came from Home Cheapo but still they didn't last long and I don't use them much. I was thinking about getting some of those dies for a dremel. Friend of mine said get the Harbor Fright sharpener, not sure that is a great idea either.
    0 Not allowed!
  5. #830
    TWINS! xrocket21's Avatar
    Central Maine
    iTrader Score
    3 (100%)
    Chain sharpening is a black art
    just keep trying, and someday the force will be with you
    0 Not allowed!
  6. #831
    iTrader Score
    no science, just
    find the angle indicator on the top place. usually to the rear of the top plate and set with a dept gauge. Correct file size is a definite! Done
    0 Not allowed!
  7. #832
    MoonTown
    iTrader Score
    I can get it sharp, just wrecking the files in the ordeal. Thought the files would last longer than the chain.
    That Katzco set up pretty durable?
    0 Not allowed!
  8. #833
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    iTrader Score
    I've sharpened with the dremel and guide, for years. It's ok as long as you keep fresh grinding wheels in use (they lose diameter quickly and then can damage the cutting teeth), make sure to not overheat the cutters, so two or three quick passes per tooth, and it takes off a lot of material so if you don't stay on top of lowering the rakers the chain won't work well, either.
    All in all, friends who make their living with chainsaws prefer hand sharpening but I never had success that way and the dremel is very fast and effective for me
    0 Not allowed!
  9. #834
    iTrader Score
    No problem with my Katzco
    although my holder has knobs to secure the file. it would be much better than the clips they are showing on that one.
    like this one
    0 Not allowed!
  10. #835
    Lifer snwbrdr435's Avatar
    North Shore Ma
    iTrader Score
    1 (100%)
    I have found that kick back is also more related to what part of the bar you are cutting with.
    I've been having a blast with the new electric saws that stihl has come out with. They fucking rock, for doing pruning and make very fine cuts. Not having to pull start while up in the bucket and not having to listen to the saw running is a huge benefit. I can't wait till they make a top handle. Still don't have the same power as my 200T/201T but they are getting close. I will be adding one to my overland setup since I can charge the battery and will only need to carry bar oil and skip on carrying mix.
    For sharpening The Stihl FG2 bench mount sharpener is tits. If you can find one snag it, they stopped selling them in the states but you can still get them from europe. I would never use a grinder to sharpen a chain, takes too much off. With an FG2 I can hammer out chains in no time. I think Smutty has one now too?
    1 Not allowed!
  11. #836
    iTrader Score
    I quit sharpening my own chains a few years ago, occasionally I do but rarely, I keep 3-4 chains on hand and swap em out, and bring the dull ones t a local saw shop that charges $6/chain
    when I do sharpen my own, I find the roller type guides work best,
    0 Not allowed!
  12. #837
    iTrader Score
    11 (100%)
    Filing is a one-direction process. Too many people drag the file in both directions and that is what kills the file.
    1 Not allowed!
  13. #838
    North Shore Ma
    iTrader Score
    1 (100%)
    Those do work, but I usually am cleaning out the saw at the time of sharpening. When I dull a chain/saw i put that saw down and pick up a different one.
    0 Not allowed!
  14. #839
    Cabot, VT
    iTrader Score
    6 (100%)
    Into the tooth or away? I always pick up my file on the return stroke.
    Quote Originally Posted by snwbrdr435 View Post
    When I dull a chain/saw I put that saw down and pick up a different one.
    That's what I do. With bikes.
    0 Not allowed!
    99 + 02 SV650 ex-race - 91 FJ1200 street - 05 YZ450F ice - 03 KDX220R woods - 00 WR400 MOTARD!
  15. #840
    North Shore Ma
    iTrader Score
    1 (100%)
    It's a solid technique for many avenues in life.
    0 Not allowed!
  16. #841
    MoonTown
    iTrader Score
    Yeah, I should have mentioned I only file one way. I think I just bought cheap files. I'll get a couple more and keep at it. thanks.
    0 Not allowed!
  17. #842
    iTrader Score
    11 (100%)
    From the handle side of the file, the pushing action is what does the filing.
    0 Not allowed!
  18. #843
    Candia, NH
    iTrader Score
    Away from the tooth.
    0 Not allowed!
  19. #844
    Central Maine
    iTrader Score
    3 (100%)
    I gotta say, with practice, I can now somewhat sharpen a chain. Good enough to get me by. I do a once a year pro-sharpen, and then I can keep the edge on them for the season.
    I also wasnt flipping or de-burring my bar at all.
    0 Not allowed!
  20. #845
    iTrader Score
    4 (100%)
    I'm staring at my man card. May have to turn it in: have not sharpened a chain....
    0 Not allowed!
    "Good judgement comes from experience, and a lot of that comes from bad judgement.
    General Simon Bolivar Butler
  21. #846
    iTrader Score
    Going on a bike ride this weekend to my alma mater, Paul Smith's College, pancake breakfast at the sugarbush in the morning , Stihl Timbersports Qualifier in the afternoon, events in hotsaw, block chop and single bucksaw, I'll take some pics and videos
    0 Not allowed!
  22. #847
    MoonTown
    iTrader Score
    Good, I loves me some pancake vids.... Be sure to get a close up of the syrup, hope it's real maple, not that corn based crap.
    1 Not allowed!
  23. #848
    iTrader Score
    been showing the Stihl 025 (not adjustable carb, not much of a fan when running rough) w/16" bar around the Cabin some love. Not as powerful as 026 with a 18" but the 025 is a little lighter to hump around.
    0 Not allowed!
  24. #849
    iTrader Score
    I'll be sure to get a video of the evaporator boiling vigorously, I am assuming they have already pulled taps, but maybe not, budding is a bit later in the Adirondacks than it is around here, but they still have plenty of sap to finish boiling
    I will also be making a donation to the college in memory of Chris Carstanjen, a former member here (Captain Tupperware) and also an alumni of Paul Smith's that was killed on 9/11, as well as visiting my granddaughter who is currently attending Paul Smith's
    0 Not allowed!
  25. #850
    iTrader Score
    0 Not allowed!
