View Poll Results: Chainsaws: What Brand do You Use? And Why?
Voters
80. You may not vote on this poll
  • Stihl
    34 42.50%
  • Husqvarna (from a Dealer)
    29 36.25%
  • Japanese (Tanaka, Shindaiwa, etc.)
    0 0%
  • Chinese (any Big Box Store Brand; Husky, Jonsered, Earthquake, BlueMax, etc.)
    12 15.00%
  • Other: I know I missed a few, Just post it below
    7 8.75%
Multiple Choice Poll.
Page 45 of 45 FirstFirst ... 5253536373839404142434445
Results 1,101 to 1,122 of 1122
Chainsaws: What do You Have?
  1. #1101
    Re: Chainsaws: What do You Have?
    If you get the thing cold first, the metal will expand faster than the wood once you hit it with heat.
    took yer advice, left the Peavey out in the snowbank a couple days, got a bottle of MAP gas for my torch, I heated the head for maybe 5 minutes, 2 whacks with a sledge, and it popped right off
    now to get the new handle as snug as the old one, my axe handle techniques of drawing the head on to the handle isn't working, I'm thinking I may have to whittle
    1 Not allowed!
  2. #1102
    Anyone have a Stihl MS461? 76cc.
    Thinking about one with 25 bar and ripping chain for the Alaska mill. Only one for sale locally guy is asking $900. New price with full wrap handle is about $1,150. Seems like they sell for $700-750 on ePay. Worth it?
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
  3. #1103
    1 Not allowed!
  4. #1104
    I bought this MA310 in the spring of 2007, and average 5-6 cord of wood per year and this thing still runs like new. I dropped this large white oak a couple months ago, the base was just shy of 3’.
    I also bought the Stihl all in one sharpener, has the file for the tooth, and flat file for the rakes... takes about 5 minutes to sharpen a chain with the 20” bar. I was surprised to find the chain cuts as good as having a new chain.
    I’ve been taking better advantage of the tools available as well and using the JD 510 to pick up the oak logs with the backhoe and hold them about 2 1/2’ off the ground to cut up... back saver for sure.
    Chainsaws: What do You Have?-6fffd352-3636-449e-9d72-06f67bd79908
    0 Not allowed!
    A Big Powerful Sportbike
  5. #1105
    Wish we had more Oak to burn, it's only about 10-20% of our supply. We mostly harvest leaners and that's a lot of Birch, lately.
    0 Not allowed!
  6. #1106
    Did a test run with the Alaska Mill today. Cut down a 16” dia tree and cut three 10’6” logs. Then used this 12” for a test, as that’s about the size of the bridge supports we will use, and I’ll need to flatten the tops for nailing.
    Didn’t buy any special frame or use an aluminum ladder. Just screwed a plank to the top to use as a guide.
    The Alaska mill works well. I’ll definately raise the work when doing it for real. I just used one wedge in the end, going to need a couple more. I was using a Stihl MS271 (50cc) with an Oregon ripping chain. For any log much bigger than this, you’d definitely want more power, but if you take your time and let the saw do the work it’s sll good.
    You end up with a flat face, as advertised. I’ll try the edging mill tomorrow. EDGING MILL - G555B *Previously Mini Mill* - Granberg International
    4 Not allowed!
  7. #1107
    Cabot, VT
    Good on you for giving it a try. I've got a 5' maple log I want to slab. Thinking SV650 powerhead.
    0 Not allowed!
  8. #1108
    Seacoast NH
    That ain't bad.
    I have a gazillion ft of pine. Kind of sort of would like to use something like that to rip 4x4 posts to build a tree-house or something.
    0 Not allowed!
  9. #1109
    no need of a tool for the 2nd square cut..
    turn the log 90 degrees.
    use a carpenters triangle to set up the flat guide (Ladder,plank, whatever)
    use ASM for the square cut.
    GO TO 10:07!
    YouTube
    0 Not allowed!
  10. #1110
    Already have the tool. It minimizes handling, as you mill one side, then the other without moving the log, then you can start planking.
    FYI I think the “Beam Machine” is simpler and probably better.
    I’m looking at used MS441’s and MS461’s, with 25” bar. You lose a couple inches with the Alaska mill setup and the trees I’m planning to harvest are 20” or more. The MS271 isn’t too heavy and is great for bucking with an 18” bar, but you are in the tree for a longish time felling. Even though I’m only cutting Hemlock or Pine.
    0 Not allowed!
  11. #1111
    Felling/Milling power problem solved. 77cc, 6bhp, 25” bar.
    Was advised to paint the ends of logs before milling to prevent checking. I cut them 6-8” long just in case.
    0 Not allowed!
  12. #1112
    Lifer ZX-12R's Avatar
    Candia, NH
    You'll like the 461. It has a lot of power for its size. If you want a silly fast firewood saw, throw a 20" bar on it, go up a tooth or two on the drive sprocket, and file the rakers down on a fresh chain. It will fly through anything you cut down in this area of the country.
    0 Not allowed!
  13. #1113
    A new MS461 (77cc Pro grade) is $1,040 new and nice used ones sell for $800+ regularly.
    Guy just listed one in Gilmanton NH for $600.
    Facebook Marketplace: Stihl ms461 - Sports & Outdoors - Gilmanton, New Hampshire
    0 Not allowed!
  14. #1114
    Lifer SteveM's Avatar
    Aug 2009
    Norwell, MA
    I have a home use echo 18” which runs just fine. However, the chains seem to go dull very quickly. I am not interested in sharpening the teeth. Are there better made chains that will stay sharper longer?
    0 Not allowed!
  15. #1115
    Oil thread alert!
    In my limited experience, Stihl chains last longer, but are harder to sharpen: I suspect there’s more chrome in the steel. We use thrm but have the shop sharpen them.
    Oregon chains are standard on Husqvarna, and the dealer recommended them if you are sharpening yourself. According to GIS, they also make Echo chains. If you bring the chain or saw to a Stihl dealer they should be able to fit one.
    Stihl chains are marked green if they are low kickback. They also have yellow-marked chains that cut better, with higher kickback risk. Just switched myself.
    If you go to echo-USA you can look up the operator manual, which will give you chain pitch and number of links.
    0 Not allowed!
  16. #1116
    026 did the duty. The I could not get the poulan chain to cut well
    2 Not allowed!
  17. #1117
    ive never drop a chain off to get sharpened. whats the going rate. i do
    pretty well with the cheap -o-hand-file. Was thinking of getting them all evened up.
    OR
    pick up a 120v grinder as i am finding myself cutting around the house and cabin more often. Recommendations on what i should be looking for?
    0 Not allowed!
  18. #1118
    If you are buying your own sharpener, plan on a couple hundred for something decent, IMO. Many of the cheaper sharpeners I've seen have a design flaw in the pivot point and eventually the grinding head starts walking all around after several uses...same with the chain clamps.
    I had my eye on the Oregon sharpener.
    On the pro-sharpening, I've paid anywhere from $5 to $14 per chain.
    0 Not allowed!
  19. #1119
    $7
    0 Not allowed!
  20. #1120
    Eddie’s in Derry, $5. PowerBarn in Bradford NH used to be $7, then $8, and recently $10. Huskie dealer in Peabody charges $8.
    0 Not allowed!
  21. #1121
    Think this will be an almost exclusively full time cutter saw, but an interesting technical achievement. The smallest fuel injected motor we have is a Yamaha 250: this Saw is 79cc! MSRP is around $1,750.
    Features.
    MS 500i - Innovative new chainsaw with electronically controlled fuel injection
    First ever chainsaw with STIHL Injection Technology. The best power-to-weight ratio on the market, and the simplest operation. Ideally suited for the harvesting and processing of large timber. All thanks to its unique lightweight design and outstanding acceleration. New bumper spikes, HD2 filter, captive nut on the sprocket cover for easy chain change, controlled-delivery oil pump, and tool-free fuel cap for safe and easy filling with fuels and lubricants. Available from spring 2019
    0 Not allowed!
  22. #1122
    Candia, NH
    The 500i is a beast. 80cc with the power of a 90cc and the weight of a 60cc. No verdict yet on the system's long term performance.
    0 Not allowed!
