Results 1 to 12 of 12
My Chimney has no flue liner
    Posting Freak Sidewinder's Avatar
    Nov 2004
    NH
    iTrader Score
    My lake house chimney has no flue liner it's ony brick, what are my options can I use a stainless steel piece or do I have to have one installed.
    I've checked google not to many people have run into this situation.
    What are my options?
    0 Not allowed!
    Bikeless
    iTrader Score
    1 (100%)
    Re: My Chimney has no flue liner
    If the inside dimension of the chimney is large enough, you can sleeve it with a stainless liner.
    How is the camp coming anyways?
    I'm thinking you should host a winter party/ice riding get together
    0 Not allowed!
    A Big Powerful Sportbike
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    iTrader Score
    1 (100%)
    If someone here doesn't know, someone here http://www.hearth.com/econtent/index.php/forums/ will.
    Edit. R7 is fast.
    0 Not allowed!
    Raymond NH
    iTrader Score
    I put a flexible SS liner in my parent's wood stove chimney a couple of weeks ago. It was very easy. I used a grinder to cut it to length after is was in place. Lemme know if you need any advice.
    0 Not allowed!
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    iTrader Score
    :IWS:
    0 Not allowed!
    Glen Beck is John the Baptist
    Nov 2004
    NH
    iTrader Score
    Mark and Stoink
    Do I sleeve the entire chimeny or is there a box that tapers to the diameter sleeve? Not sure how above the damper it slims down to the small 8" sleeve.
    The chimeny is 14" x20" roughly. So any size should fit.
    Mark its coming along slowly I'm doing all the work on weekends I'm at the finish stage Electrican and plumber are up next.
    I'm going to try and winterize it I bought some 6" foam boards to wrap under the house.
    0 Not allowed!
    Bikeless
    IDK jmgssunfire's Avatar
    Smithfield
    iTrader Score
    You can get a kit from Homedepot tell them the size if they dont know tell them to go into there peabody/slantfin catalog. Its near the back half of the pages... alls u need is 2 people to install on on roof one inside house... only know this because i had to sit threw a 2 hr meeting about it
    0 Not allowed!
    Nov 2004
    NH
    iTrader Score
    Thanks I'll give depot a try, 2 hr class on it? What do you do for a living?
    0 Not allowed!
    Bikeless
    iTrader Score
    Doug, theres a company, I can't remember the name that does chimney flue liners
    I've seen it done, they go up on your roof, insert a sock is inflate it with pressurized air, then they pour a masonry type liner, let it harden and remove the sock
    0 Not allowed!
    Nov 2004
    NH
    iTrader Score
    Randy If you remember the name let me know I've heard of the process but have not seen a company that does it.
    0 Not allowed!
    Bikeless
    Raymond NH
    iTrader Score
    The liner I used had a thimble for the 90 degree turn where the wood stove connected to the chimney. I put a 3 foot section of ridgid SS liner below the thimble. I hope this answers your question.
    0 Not allowed!
    iTrader Score
    1 (100%)
    Quote Originally Posted by Sidewinder View Post
    Abundant Life on route 4 in Chichester does linings...
    0 Not allowed!
  1. How to wash helmet liner?
    By Hauptman in forum General Bike Related
    Last Post: 08-07-09, 12:01 AM
  2. Adding to existing Chimney Any Masons?
    By Sidewinder in forum Off-Topic
    Last Post: 04-28-09, 02:39 PM
  3. Replies: 3
    Last Post: 11-29-08, 07:55 PM
  4. Prices for a Chimney
    By TheIglu in forum Off-Topic
    Last Post: 11-28-07, 11:15 PM
  5. Opinions on Joe Rocket Dry Tech Liner
    By ChicknStripEatr in forum General Bike Related
    Last Post: 09-06-06, 09:12 AM
