Results 1 to 12 of 12
Crown Vic Spark Plugs
    Stoughton,Ma
    iTrader Score
    So I'm changing the spark plugs on a 2000 Ford Crown Vic with the 4.6 in it. I ran into a little trouble in the process of changing them. There are coils on top of the plugs and then there is a rail on top of the coils. Does anybody know what this rail is for and how to remove it. I just don't want to yank on it too hard and end up breaking something. I'm trying to find a picture to help out what I'm trying to describe. Has anybody changed plugs on a crown vic before?
    0 Not allowed!
    I got nothing......yet
    badgerbadgerbadgerbadger drop's Avatar
    Bradford, MA
    iTrader Score
    1 (100%)
    Re: Crown Vic Spark Plugs
    Quote Originally Posted by rwc0920 View Post
    do not pull on or remove that rail - it's the fuel injector rail.
    use a 7MM socket to loosen the bolt holding the coil pack down, then pull the coil pack out. remove the old plug and install the new one as usual.
    0 Not allowed!
    - Jamie
    2009 K 1300 S
    Senior Member Priv's Avatar
    Massachusettes
    iTrader Score
    1 (100%)
    Quote Originally Posted by drop View Post
    those rails are huge money!
    0 Not allowed!
    Bopida Beepoo
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    iTrader Score
    Clean the boots real well and use dialetric grease on both ends
    0 Not allowed!
    Glen Beck is John the Baptist
    daideó Rambunctous's Avatar
    iTrader Score
    3 (100%)
    I get a kick out of the manufacturers telling consumers 100000 miles between tune-ups. Ever try taking plugs out of a engine with that kind of mileage or more if they put it off. Good luck. Reinstall with anti-seize with a torque wrench at 14 ft lbs.
    0 Not allowed!
    Waterbury, VT
    iTrader Score
    They do their testing and qualifications in a dyno cell, and take the plugs out for measurements every 10k miles or so. Fast forward to the poor bastard that lives in New England and drives the car in the winter - and believes he doesn't need to touch them for 5 years... Aluminum head, steel plug, light spray of salt water, heat and cooling cycles - sometimes it's better then welding the damn things in. There's a reason there is a special tool (specifically sized EZ out) made to remove the snapped plugs out of the head on Fords...
    0 Not allowed!
    SSearchVT
    Stoughton,Ma
    iTrader Score
    Ok, I'll try it out again. Last time I tried, it didn't seem like there was too much room between the coils and the rail. It didn't look like it could be pulled out without removing the rail. But I'll give it another shot. Ill take some pictures and post them so you guys can get a better look.
    0 Not allowed!
    Sep 2007
    Middlebury VT
    iTrader Score
    The domestic manufactures really promoted this feature a few years back.
    0 Not allowed!
    Just Registered VinceF2's Avatar
    Feb 2002
    iTrader Score
    -1 (0%)
    I'm guessing the Crown Vic 4.6 is setup like my Mustang 4.6... that being the case you can do the plugs without removing the fuel rail... have done it twice now... once for maintanence... again for Nitrous
    0 Not allowed!
    Woooooosta
    iTrader Score
    haha i do those at work, A LOT. Its super easy, if the boot gets stuck in the cylinder head (which more then likely it will) use needle nose pliers and pull em out, dont rip em either.
    If you need a boot or 2 let me know i might be able to gather some up for you.
    0 Not allowed!
    iTrader Score
    Funny I think the same way. Are you my twin?
    The Parts departments always ask "well how many miles are on the car?" Like it matters. Do you want the $ for the 4 spark plugs or not. It sure beats having to pull the engine apart because of a frozen plug. If I can pay a little $ now it is going to save a lot of money later.
    0 Not allowed!
    Stoughton,Ma
    iTrader Score
    Quote Originally Posted by bluej511 View Post
    alright will do. thanks.
    0 Not allowed!
  1. 07-09 600RR Spark Plugs....
    By JRide in forum Bike Maintenance
    Last Post: 07-07-09, 03:34 PM
  2. Spark Plugs
    By akira700 in forum Bike Maintenance
    Last Post: 10-10-08, 08:18 AM
  3. Cleaning Spark Plugs
    Last Post: 02-14-08, 06:40 PM
  4. spark plugs
    By oreo_n2 in forum General Bike Related
    Last Post: 04-14-03, 07:32 PM
  5. Resistorless Spark Plugs...
    By Stoneman in forum Off-Topic
    Last Post: 07-22-02, 09:36 AM
