Page 9 of 9 FirstFirst 123456789
Results 201 to 217 of 217
Cutting the cord....
  1. #201
    Re: Cutting the cord....
    Which spectrum modem you have? Did you notice speed difference from Apple to Google Mesh?
    hmm, good question. no real markings on it but looks to be a Nokia 7368 ISAM ONT unit visually, i'll see if i can get more specs. Apple > Google came before Spectrum so can't say. loved Google Mesh from day one though, and i'm a die-hard Apple guy.
    0 Not allowed!
    I've been streaming netflix and amazon, etc for a while, but no real local news or programing, so I'm in the process of getting a digital antenna, my local stations will be from Portland, ME, I'm on the wrong side of the hill to get Manchester, NH, I couldn't get it with analog, I don't expect any better with digital broadcast. I might be able to get Boston, it's in the claimed range of some antennas
    0 Not allowed!
  3. #203
    Seacoast NH
    I either get Boston or Portland or neither. I never get Manchester either depending on the weather and mood of those little electrons. I honestly doubt you will pull in any of the Boston stations at all. You can forget about the fox affiliate. Iíve never pulled that one in.
    0 Not allowed!
  4. #204
    Lifer tsorfas's Avatar
    Sep 2011
    in my own little world...
    via ethernet cable and Google Speed tester: 218mbps
    via ethernet cable and Spectrum Speed tester: 440mbps
    via ethernet cable and AT&T Speed Tester: 448mbps
    via Apple Airport Extreme Wifi and all my devices connected Google Speed Test: 98mbps
    via Apple Airport Extreme Wifi and all my devices connected Spectrum Speed Test: 119mbps
    via Apple Airport Extreme Wifi and all my devices connected AT&T Speed Test: 120mbps
    upload speeds were around 20 with all 3 testers and wifi
    0 Not allowed!
  5. #205
    I either get Boston or Portland or neither. I never get Manchester either depending on the weather and mood of those little electrons. I honestly doubt you will pull in any of the Boston stations at all. You can forget about the fox affiliate. I’ve never pulled that one in.
    that make me lean toward a 60 mile antenna instead of a 150 mile range, the shorter range antennas are said to have better gain and not need signal amplification
    0 Not allowed!
  6. #206
    I have a 6 bay HD antenna on a roof get all majors TRUE 60 mile range, I do live on a hill
    Timmy, have we had quality improvement since last 2 years. It was worse than reg TV last time
    tell me more about your antenna
    0 Not allowed!
  7. #207
    Since stepping into the 21st century recently and getting a couple smart TV's, we find ourselves watching cable less & less. We've been researching certain networks, local news & sports options, pay per view choices, etc.
    The two new sets are both Roku, and that covers a lot. I can do without local news to a point, and we've found NECN on Roku - although it's a bit watered down and audio SUCKS with NECN. Big Shirl has found most of the networks she likes on free streaming as well, and can be happy with those. My biggest hang-up so far is NESN though. I *NEED* my Red Sox & Bruins LIVE.
    I guess my question is Fubo TV or You Tube TV to start the cord cutting process? If I remember, Fubo currently carries NESN & NECN, which I'm told is a helluvalot better than the NECN broadcast on Roku.
    0 Not allowed!
  8. #208
    Sep 2011
    The more devices, the less airtime per device. Simple as that.
    Get a mesh system, hardwired units if possible. And hardwire everything that can feasibly be hardwired.
    Why are you suggesting a mesh system? I read a bit on the google WiFi. I can see how it can be great if you have a large home but I have a 1700 sq ft two floor and a basement. I didnít read any benefits on mesh for multiple devices.
    Care to elaborate? Iím sure Iím missing something.
    0 Not allowed!
  9. #209
    If you have a ton of devices going to a single radio, that radio can only talk to one device at a time.
    If you add in a second radio, it's half the devices per radio.
    Really though, I wouldn't spend a dime on anything until you do some troubleshooting to find the root cause.
    1 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    Lifer loudbeard's Avatar
    It seems that my WiFi router Apple AirPort Extreme is getting worse with each update and somehow my range seems to be decreasing? Could it be that I have converted most of my house to a smart home with several devices connected (10+ phones and tablets, 20+ smart light bulbs, 5 computers/laptops, 2 nest thermostats, 2 smart TVs, fire stick, garage opener, door sensors, etc). Looking to finally replace it after 7 years.
    Looks like Archer C4000 is one of the top rated routers. Any feedback/suggestions?
    Another approach, get a 4-port switch off of the modem and split; run one router to handle all of your smart devices (use the old apple for this) and then add a second router to handle your other devices such as streaming TV. The old router with all of the home automation crap doesn't need instantaneous response time to 20 something devices, you're not switching anything that can't wait a few seconds. Funnel your on demand traffic into the new router (or mesh system.)
    1 Not allowed!
  11. #211
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    87 channels now on the M-Hat.
    Still free to all NESR members in good standing .
    Simply PM me.
    0 Not allowed!
    TIMMYDUCK
  12. #212
    Oct 2018
    Simply PM me.
    I thought I noticed some new channels yesterday..
    Also the app for Android tv devices is MUCH more user friendly.
    1 Not allowed!
  13. #213
    Sep 2011
    So I got a basic Linksys router of Amazon for $55ish. Connected that to the modem. Then connected the Apple router to the Linksys router. Set up the priority devices on the Linksys router and made the Apple router last in priority. I left things like the printer, some cameras, etc on the Apple router. Hardwired the main TV and Apple TV also. Tablets and phones of people visiting going to the Apple router network. Our stuff goes on the Linksys. Not only my speeds are incredible (yet super inconsistent - I can get from 40 up to 320mbps) on the Linksys but all the other stuff seems to be performing better. The 3 Antenna Linksys gives me coverage in the entire house all the way to my driveway and other parts of my yard.
    I had to unplug it and plug it back in twice but I like the TP app and the speeds with new coverage I’m getting.
    0 Not allowed!
  14. #214
    Oct 2018
    Any iPhone MadHat users having issues after upgrading to iOS 13? My app force closes when the guide is loading every time now.
    I’ve been in touch with support for two weeks and they say they’re looking into it, but I’m the only one that has notified them of a problem, so I’m wondering if it’s just something wrong on my end. The same thing happens on my wife’s phone FWIW.
    0 Not allowed!
  15. #215
    Senior Member Tas's Avatar
    Sep 2013
    Jaffrey NH
    Quote Originally Posted by petro View Post
    Iíve been in touch with support for two weeks and they say theyíre looking into it, but Iím the only one that has notified them of a problem, so Iím wondering if itís just something wrong on my end. The same thing happens on my wifeís phone FWIW.
    just updated my ipad and now my MadHat is cutting out......were there any fixes for this yet?
    0 Not allowed!
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    LRRS #246 - Central Mass Powersports / Northeast Cycle / Woodcraft
  16. #216
    Oct 2018
    Negative. Send them an email and let them know - support@madhat.tv
    0 Not allowed!
  17. #217
    Sep 2013
    Jaffrey NH
    Thanks for the email address. Sent off my request for help.
    0 Not allowed!
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
