Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 174
DIY toy hauler camper build
  1. #76
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    Re: DIY toy hauler camper build
    Yea, but insulation does more then regulate temperature it also helps sound deaden things. I went from a van with drafts to one fairly sealed up. I usually will only crack a window to keep moisture down if its somewhat warm out, as in over 30-35 degrees.
    0 Not allowed!
  2. #77
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Also radiant loss is not the same as infiltration loss. Radiant loss doesn't provide any moisture exchange, where infiltration does.
    Assuming you could have no radiation loss (you can't) you could control both temperature and humidity with infiltration.
    0 Not allowed!
  3. #78
    Electric blankets are waaay more efficient than trying to heat the air all night.
    this!
    something like 80w vs. 1,500w
    just don't crank up too high or you wake up in sweat
    0 Not allowed!
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke ** 2001 Suzuki GSX1300R Busa ** 2005 Kawasaki Ninja 500R **
    instagram @veshlife
  4. #79
    Middle of Nowhere
    unfortunately electric space/blankets is a no go since I am almost never on shore power. Great for the track that has hookups but being self contained is awesome.
    0 Not allowed!
  5. #80
    separate solar power cell and deep cycle battery?
    0 Not allowed!
    instagram @veshlife
  6. #81
    Electric blankets are possible with the smallest of house battery setups. Space heater, NOT. I run my electric blanket without worries. But it has a timed shut off. I wish it didn't actually. I have to press the button if I wake up cold.
    0 Not allowed!
    Middle of Nowhere
    Don't have the solar yet but I do have about 280amp hours of house batteries. Used to charge cameras laptop and will be running a few other items in the near future. I guess I could use an electric blanket but I already have various 0 degree sleeping bags a few 30s and a -25 bag. Just make a nest. Works.
    0 Not allowed!
  8. #83
    Seacoast NH
    This weekend I made my bed. Well, started on it anyway. Busy weekend with friends and family, so not much progress. But progress.
    Dad convinced me not to use the mountain of 1 by pine I have in my basement and to go buy poplar instead. Bit of a harder wood than pine and should hold up better. Dad lent me his very nifty Kreg pocket screw contraption and I used that for the joints. A little disappointed at how it came out as I did a poor job selecting the wood to use for the side rails and wound up with two bits that twisted a little. I expected to be able to take the twist out easily with the pocket screw system. Did not work out that way. I now have a mess in one corner I'll have to fill. But otherwise the whole thing is glued and screwed and should be ready for some abuse. I plan to lay down bits of hardboard to keep the mattress from sagging through the slats rather than adding more slats (read: weight) to the setup.
    DIY toy hauler camper build-20150510_134813-jpg
    I have a plan for detachable wood legs that will attach with 3/8" dowel. Will be located into the floor of the trailer using dowel as well. There will be no hinges used. This plan is either incredibly dumb or mildly clever. We'll see which.
    1 Not allowed!
  9. #84
    Ah, nothing better than a bed ready for some abuse! LOL
    2 Not allowed!
    Seacoast NH
    Can't believe I posted that.
    2 Not allowed!
  11. #86
    nice
    don't forget the stripper pole
    0 Not allowed!
    instagram @veshlife
  12. #87
    Raymond NH
    Deep cycle battery, heat troller and a Gerbings jacket would make cold nights and lack of 120 VAC moot. I hear those jackets are useful for other things like riding motorcycles too.
    0 Not allowed!
  13. #88
    Cabot, VT
    Note to self, do not accept any food or drink from Bubs Saturday night...
    4 Not allowed!
  14. #89
    Seacoast NH
    Saturday? You think I'm going to wait that long to spring my trap?
    1 Not allowed!
  15. #90
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Welded tubular steel and floor anchors
    0 Not allowed!
  16. #91
    Seacoast NH
    Last night I installed it. I am not as much of a genius as I often think I am. Going to buy some hinges on the way home and make the setup hinged just like everyone else that does this.
    But the bed is damned comfortable. So looking forward to not sleeping on the ground anymore!
    Ordering twin sized bed sheets from amazon (who else) last night I noticed there is this thing now called a heated mattress pad. Wholey genius! Someone buy that man a beer.
    1 Not allowed!
  17. #92
    Raymond NH
    That's how I use an electric blanket, it goes under the normal mattress pad so that I don't feel the wires. It's much more effective when the heat is under you.
    0 Not allowed!
  18. #93
    Lifer loudbeard's Avatar
    Didn't want to mention it as its something of a trade secret, but electric mattress pad is the hot setup. All the fast guys are running it.
    0 Not allowed!
  19. #94
    Seacoast NH
    Here and I thought helmet fans were cutting edge.
    0 Not allowed!
  20. #95
    Senior Member Tas's Avatar
    Sep 2013
    Jaffrey NH
    So THIS is why I'm so slow! We have both and i prefer the electric blanket. Think I'll switch and we'll see how I do this weekend. Thanks for the ancient Chinese secret. I won't tell.
    0 Not allowed!
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    LRRS #246 - Central Mass Powersports / Northeast Cycle / Woodcraft
  21. #96
    Cabot, VT
    I thought the helmet fan was the crucial link?
    0 Not allowed!
  22. #97
    Seacoast NH
    DIY toy hauler camper build-img_0006-jpg
    DIY toy hauler camper build-img_0012-jpg
    Lights are installed too. LED strip lights are sooooo cool.
    2 Not allowed!
  23. #98
    Sep 2013
    Jaffrey NH
    I picked up a second helmet fan on Saturday if anyone needs one.
    Are they neon? You know what neon means don't ya?
    0 Not allowed!
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
  24. #99
    Cabot, VT
    No, but what do the rainbow colored strobe ones mean? I thought I might make new friends with my bright display.
    1 Not allowed!
  25. #100
    well done player on words!
    when I was renting a room w' no heat and it got to a not-so-cozy 38 degrees overnight, I ran one of these and felt so toasty...got 'em on clearance for $18 at Target after winter was over too
    0 Not allowed!
    instagram @veshlife
