Page 5 of 9 FirstFirst 123456789 LastLast
Results 101 to 125 of 204
DIY toy hauler camper build
  1. #101
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: DIY toy hauler camper build
    No, but what do the rainbow colored strobe ones mean? I thought I might make new friends with my bright display.
    Rainbow colored is fine. I hear flashy lights, however, are not that we'll liked.
    1 Not allowed!
  2. #102
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
  3. #103
    Seacoast NH
    Yup. Probably about 50% more than what I have in my wreck, but 2x as many features and probably 48238x the build quality. Shoulda. Coulda. Woulda. Didn't.
    Besides. I love a project.
    0 Not allowed!
  4. #104
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    What do you have as a charge converter/fuse panel for the solar setup?
    0 Not allowed!
  5. #105
    Seacoast NH
    I don't have solar (yet).
    This is the power center I installed : Amazon.com: WFCO WF8712PB Black 12 Amps Power Center: Automotive
    All it does is convert 120VAC to 12VDC and break out circuits. It houses the breakers (2x 120VAC circuits) and fuses (4x 12VAC). It also has a smart battery charger built in that can charge and condition deep cycle batteries. However, I am not running with batteries at this point.
    I have no idea how it would be integrated into a solar setup. I think it can be. But I haven't looked into exactly how.
    0 Not allowed!
  6. #106
    Seacoast NH
    Just pressed go on the parts for a photovoltaic project for this. Found an scratch and dent deal on a 100W monocrystalline panel, added a Schneider/Xantrex 35A PWM charge controller, mounting brackets, inline fuses and misc connectors and assorted poop. All said I'm in under $300. Time to drill more holes in the roof!
    Was gonna cheap out and go with one of those Northern Tool cheapie panels. But this panel "only" cost 2x more and delivers 5x the power. I like set and forget and that would have required the charge controller anyway. Looking for enough to push the fridge and recharge the battery enough to give me lights, the roof fan and maybe a cell phone recharge, all with no shore power. I may never have to plug this trailer in again.
    Oh, I think I skipped the chapter where I added a 100AH deep cycle battery, box and low-power fridge/cooler last spring. Basically the same type fridge as Paul put in his sprinter but from Indel B, an Italian brand. Supposedly draws about 1A continuous. Holds at least a 12 pack. Life is good. Battery charges off the charger/converter I added when I first built out the trailer last year. Plug it in for 2-3 days before leaving and the battery is enough to survive a 2 day track day. Tested it at Thompson and at Stimilon and it was tities.
    2 Not allowed!
  7. #107
    Oh, sweet! for 300 bucks and some holes in the roof, this is a no brainer. You are going to love it. I can run my fridge 24/7. Ceiling/floor vents to keep some cool air in there at all times helps the fridge.
    1 Not allowed!
    Seacoast NH
    DIY toy hauler camper build-img_0729-jpg
    Renogy 100W monocrystalline panel
    DIY toy hauler camper build-img_0732-jpg
    Schneider-Electric C35 charge controller (35A max)
    DIY toy hauler camper build-img_0734-jpg
    Duracell 100AH deep cycle 12V battery, vented marine box
    I'm not entirely happy with the wiring just yet. Need to buy some more 10ga wire (using some 12/2 romex for now) and I'd like a disconnect to the battery. But it works. Charger went into bulk charge mode almost as soon as I hooked it up. After about 24 hours I noticed it was in float charge mode. I'm fairly confident I may never have to plug the trailer in again. I think the battery has enough to push the fridge through a 2-3 day event, supplemented by solar during the day. Then I can simply park the trailer at home and let the solar bring the battery back and maintain through the weeks between events.
    I have no inverter in this system. No 110VAC items I want to run. Although the electric blanket would be handy, so I may have to go there.
    DIY toy hauler camper build-img_0735-jpg
    Trailer as it stands. Track day/Stimilon/Boxshop/whatever ready.
    3 Not allowed!
  9. #109
    Seacoast NH
    Recently we've been talking of trailer power. I dug through my stuff and found this chart showing how I have my trailer electrical setup. Mine was implemented in phases. The black bits were phase 1; shore power plug, power distribution center, plugs, fan and outlets. Phase 2 was the battery. Phase 3 was the solar panel and controller. Phase 4 would be the inverter. I have not done this as I don't feel I need 120VAC very badly. But the inverter would let me run 120VAC loads off the battery. I'd probably need to add more batteries if I did that.
    Setup as is works the boobies.
    DIY toy hauler camper build-trailer-power-page-jpg
    1 Not allowed!
  10. #110
    Excellent post
    0 Not allowed!
    Cabot, VT
    How much do you charge to do this? I already have a hole in my trailer from a bar end, so that's done.
    0 Not allowed!
  12. #112
    Seacoast NH
    Remember, I measure once and cut twice.
    DIY toy hauler camper build-20150418_132951-jpg
    2 Not allowed!
  13. #113
    xxaarraa
    Guest
    Is your truck fridge a regular old dorm room issue, or a fancy ARB-type compressor fridge that costs hundreds of dollars? I imagine the latter, if you are running it off the battery, but just checking.
    0 Not allowed!
  14. #114
    Truckfridge is a brand. Check em out. Super efficient danfoss compressor at half the price of ARB. It's a no brainer.
    1 Not allowed!
    Middle of Nowhere
    You can grab a tf49 for sub $500 bucks that will run for a few days on a 150ah battery, toss a solar panel on that and you are setup fairly nicely
    0 Not allowed!
  16. #116
    Seacoast NH
    I have the Truck Fridge brand TF41 portable. It works off 110VAC or 12VDC and is super efficient. Hence I can run a weekend (plus) off one 100AH battery and do not need to bother with an inverter in my system. The fridge was the only 110VAC load I really felt I needed. So my view was that I was going to pay for the fridge or for the inverter, battery and extra wiring/hardware. I decided the fridge was a better investment for me.
    With the solar I don't worry about the battery much at all anymore. I figure the net sum between the fridge & my other loads and the solar charge is more than enough for me to run that single battery for a long weekend.
    I can highly recommend the TF41. It's small, but works well. Good for 1-2 people for a weekend. Cannot load up with a whole 12-pack at once. But you can replace cold ones as you drink 'em and still live the dream.
    I also bought the optional mounting plate. Skip that. It sucks. The retaining system doesn't work well and I have already broken several of the clips. I need to figure out a better solution for mounting. But the fridge is great.
    0 Not allowed!
  17. #117
    Walpole
    *subscribed*
    Sent from my Pixel XL using Tapatalk
    0 Not allowed!
    2018 Harley Road Glide
    2000 Ducati 900ss
    2018 Onewheel XR
  18. #118
    Middle of Nowhere
    I have a tf49 in my westy. I can fit a pint of ben&jerrys in the freezer, it makes ice in 100 degree plus temps and keeps beers nice and cold. Its quiet to boot!
    0 Not allowed!
  19. #119
    xxaarraa
    Guest
    The truckfridge seems to be the same price as some arb or edgestar models? Do you guys like them because they are just a better product because they don't seem cheaper to me?
    0 Not allowed!
  20. #120
    Really,? they are half the price of ARB for the same size.
    0 Not allowed!
    Seacoast NH
    ARB 10800352 (37qt) : $765 on amazon
    TruckFridge TF41 : $549 direct
    ARB 10800472 (50qt) : $851 on amazon
    TruckFridge TF51 : $599 direct
    Not half, but pretty sizable cost delta.
    Both are excellent products. The truck fridge is a rebrand of an Italian brand. I can't remember which.
    0 Not allowed!
  22. #122
    Middle of Nowhere
    If you want a Truckfridge I have found the best pricing from westyventures
    All of these prices include free shipping!
    For example The TF51 is 550 and the TF41 is 520
    Westy Ventures / Parts
    0 Not allowed!
  23. #123
    xxaarraa
    Guest
    Quote Originally Posted by snwbrdr435 View Post
    I must have been looking at incorrect models, thanks both. I have been meaning to bite the bullet and get a compressor fridge even for my overlanding setup.
    Any idea how the fridge would perform if placed outside in the bed of a pickup? It will be under a tonneau cover, but still, exposed to outside tempteratures. Would it still keep things cool? I am asking because when we go overlanding/camping, I can't afford the room the fridge takes up inside the cabin with two 100 lb dogs, but I can put it in the bed of the new pickup underneath the tonneau.
    0 Not allowed!
  24. #124
    Seacoast NH
    I have left it in the cab of my (all black, black interior) truck on a sunny day. It doesn't perform miracles, but it works. Beer was cold, but it wasn't making ice.
    My trailer isn't conditioned. So inside temperatures are the same as outside for me. It works well in that space; shaded from the sun, with lots of air to circulate.
    0 Not allowed!
  25. #125
    I have a toploader ARB and it would absolutely be perfect for what you describe. It's pretty amazing the range of temps it can work in. The TF would seem to be nearly identical.
    0 Not allowed!
