Page 8 of 9 FirstFirst 123456789 LastLast
Results 176 to 200 of 204
DIY toy hauler camper build
  1. #176
    Re: DIY toy hauler camper build
    I would get a real AGM from Napa. They have a good price at around 300? But a 99 dollar battery is just a lead acid and not really a deep cycle. At that point, 2 6V trojans would be a better choice. (maybe the best choice anyway).
    0 Not allowed!
    Seacoast NH
    What charges the battery when you are plugged into shore power? The WFCO unit appears to have that capability, but how does that impact the solar charging setup? It appears it is capable of charging the deep cycle battery via the input/output hot to 12vdc line, but is it smart enough not to overcharge like the solar unit is? Is the Schneider smart enough to stop charging from solar while the WFCO is pushin electrons?
    I don't know. I almost never plug into shore power now that I have the solar.
    I don't know or can't remember if I ever figured out if it is a problem to have the RV load center/charger and the solar charger plugged into the same battery at the same time or not. But I currently have it set that way. So theoretically if you plugged my trailer into shore power the RV unit would start to try to charge the battery with the solar doing the same. As far as I know there is no way to disable the charger portion of the RV unit.
    I'd remove the RV unit at this point. Except that it serves as the 110VAC and 12V load protections. It has the breakers and fuses for those circuits. It is also convenient for wiring. ... And a UL sticker, which makes me feel a bit safer than something I cobble together. In the end it is cheaper than a bunch of individual 110VAC and 12VDC boxes and such bought individually.
    105Ah deep cycle marine battery ($99 at SprawlMart) x2 if capacity isn't enough eventually
    That's what I have. Mine came from batteriesplus. But yeah. 3rd year or whatever and it still tests as good.
    Two thoughts:
    - I don't have a battery meter, thus I have no idea how low I actually draw my battery. I just surmise that I'm okay as it continues to take a charge and test well. I do make sure to keep it topped off with water and I do bring it into the basement in the freezing weather and keep it on a tender. I believe I may actually be under-utilizing the ~100Ah. But I have nothing to confirm that
    - If you are thinking of more capacity then strongly consider 6V golf cart batteries. By my math when I did it you could get 4x the capacity for 2x the cost with a pair of 6V batteries. Downside is initial cost as you have to buy two cells to get the 12V voltage you need. Nothing will charge a single 6V load and naturally the loads want 12V as well. Add a 2nd 12V battery later and you'll still be paying 2x the cost but only get 2x the capacity
    100w solar panel up top (also x2 if capacity isn't enough)
    Solar charge controller
    WFCO 12amp unit for 120v shore/gen power input and 12v/120v distribution
    MaxxFan 5100k vent fan (5 amp max draw)
    LED 12v lights for interior ceiling/exterior loading
    USB for phone charging off 12v system
    12v heated blanket ($9 at wal-mart, draws just under 5 amps)
    Strongly recommend the brand name vent fan with hood, not the shitty e-trailer fan I bought.
    You'll need some misc brackets and such for mounting the panel, plus the wiring harnesses, fuse and such.
    Can't remember if I linked to it before or not. But this is the charge controller I have. It works well.
    West Marine is a great source for wire, terminal connectors, blocks, etc.
    Sounds like you're on the right track. Doeit.
    0 Not allowed!
  3. #178
    Seacoast NH
    Why? $300 is a hell of a lot of money for this.
    IMO AGV is not required here. Service the battery annually and vent your battery box and a cheap wet cell will do fine. I am pretty sure this is the battery I have. It works just fine.
    6V batteries do give much, much better $/capacity. But as I say, you have to buy 2 just to start your system.
    0 Not allowed!
  4. #179
    Just the venting.
    0 Not allowed!
    RE two chargers, one batt, as long as they're decently designed, there isn't an issue having them both going at the same time. They'll both stop when they see the voltage come up to the charge target, if you can adjust those targets set one below the other if that gives you more piece of mind.
    0 Not allowed!
    771 Racing -=- FaceBook
    Backed by Heroic Racing Apparel
    A-ko - 1992 FZR400RR SP / Mistake - 1992 WR250ZD / Facade - 2003 YZF-R6 / 2000 LS650P
  6. #181
    Seacoast NH
    It's not really a big deal.
    Amazon shopping history knows all:
    Vent kit
    Box vent
    + some RTV or silicon caulk..
    0 Not allowed!
  7. #182
    And IF you need the capacity. AGMs perform better over time in applications like this.
    0 Not allowed!
    Seacoast NH
    That sounds right. Now that I think harder I think there may have been some pots on the solar charger that let me tune this. I can't remember.
    As I say, I almost never plug into shore power anymore.
    Maybe the load center isn't even needed. Just go 12VDC for everything and run an extension cord from shore or a genny in the rare instances where you do need 110VAC?
    0 Not allowed!
  9. #184
    It would be nice to have the ability to charge the batteries during the day with the generator, but also have the ability to turn that functionality on/off while also leaving the generator going.
    I guess a simple 120v circuit off a decently protected fuse protected power strip, plus a Battery Tender, would achieve the same result. Keep the 12v solar system on it's own loop.
    Now for 12v, do you guys ground to chassis, or run a negative?
    Need to find a ceiling LED light, and a switch panel with 3 switches.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    Seacoast NH
    I ran negative. The trailer lights and factory inside lights (small, useless) already use the chassis and I didn’t want any crossover there.
    0 Not allowed!
  11. #186
    Hmmm, not sure the math is adding up for me on the golf cart batteries.
    Looks like about $240 for 2x 235Ah 6v batteries.
    Using deep cycle marine 2x 105Ah 12v, it's $197.
    So going with a pair of 6v, it's $240 for 235Ah.
    Going with a pair of 12v, it's $197 for 210Ah.
    Trojan T-105 Duracell models of 6v, it's $203 for 215Ah.
    Where are you guys seeing that it's WAY cheaper per AH to go with 6v golf cart batteries? Am I missing something?
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    Ashford, CT
    Literally pick up a 6v golf cart battery then pick up the marine 12v and you'll see the difference pretty quickly. Those marine batteries aren't a true deep cycle.
    0 Not allowed!
    Jeff
  13. #188
    Seacoast NH
    These are prices/specs from batteries-plus's website:
    Duracell Ultra BCI Group 31M Deep Cycle Marine & RV Battery (SLI31MDC) - 12VDC x 105AH - $ 109.99
    Duracell Ultra 6V Deep Cycle Golf Cart Battery (SLIGC125) - 6VDC x 235AH - $ 129.99
    2x the 12V cells => $219.98 for 210AH
    2x the 6V cells => $259.98 for 470AH
    More than twice the AH for only about 20% more $. The problem is you HAVE to go with 2x 6V cells to start where you can do a single 12V cell and then add on later if you need/want with the marine and RV cells. I think the group 31 and group GC2 cells here are of comparable size.
    I went with the single marine and RV cell listed above. (Pretty sure it is the same model.) It's done me okay. I believe this is a "true" deep cycle battery. It is not one of the starting/deep-cycle hybrid batteries. They have an almost identical hybrid battery as well. Definitely be careful and get a real deep cycle not a hybrid.
    I couldn't find any reasonable prices on AGMs when I looked. I don't remember what the premium was. But it was enough to rig up a vent and deal with maintaining the battery.
    0 Not allowed!
  14. #189
    Uh, don't you lose half the AH capacity when doubling the voltage in series, Bubs?
    1 Not allowed!
    -Clayton
    2006 Suzuki SV650
    Seacoast NH
    Fuck me with a rusty pole. No wonder I got a D in EE-301.
    Disregard my inaccurate bullshit. As you were.
    0 Not allowed!
  16. #191
    Still a better path to use 2 6v deep cycle batteries as far as longevity and ability to truly deep cycle, so don't feel bad.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    /Need to find a ceiling LED light.
    eTrailer has a bunch in the RV section.
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
  18. #193
    We are going to replace our boat battery this season. It's a BMF (I'll look up the size) Exide Marine, new in 2015. Kept on a Battery Tender off-season September - May.
    There's nothing wrong with it: I subscribe to the "Large ocean, small boat" school of boat maintenance so I'm buying a new AGM. If someone wants it for their trailer I'll give it to you for whatever the core charge is these days, probably $15-20.
    0 Not allowed!
  19. #194
    There is a thread about this on the Sprinter forum. The 6v golf cart batteries last many more deep-discharge cycles than starting/deep cycle hybrids: like 200 vs 30. Avoiding deep discharge with a one battery system can be a challenge.
    0 Not allowed!
  20. #195
    For someone not looking to break the bank with a Pitbull TRS system yet (eventually, just not this year), what chock would you use to keep the bike from moving back and forth in an enclosed trailer? I have E-Tracks to tie down to, but nothing to prop the front tire up against.
    It would ideally be removable so I can move around without tripping over it. This is also my living space.
    Thinking one of these little guys would do the trick. Anyone used one?
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    Lifer loudbeard's Avatar
    0 Not allowed!
  22. #197
    Seacoast NH
    I have those. Not made by pit-pose but they are functionally identical. I have 2. I planned to buy a bunch more key-hole mounts and position them in a few different places but haven't had the need. One primary on the back right and one secondary on the left offset forward and I'm good to go. They work very well and stow nicely when in camper mode.
    0 Not allowed!
  23. #198
    If it could rotate 90 degrees, it would be perfect.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    Member Zolden's Avatar
    Jul 2005
    NJ/NY
    One of these came in my semi built out trailer. It is better than nothing but it is way too large allowing lots of play in the wheel. So it won't really hold the bike up for you entirely on its own while strapping down (like the awesome chocks in a Kendon). And mine does not really lock into the mounted plates, it just slides right out if knocked slightly on one side.
    But like I said, without it I would have had problems bringing both my bikes on a first outing. The supermoto was fine strapped down against the ramp door without a chock, but a big heavy v-twin needs more stability.
    0 Not allowed!
    '19 Husqvarna FS450 Race
    2017 Aprilia Tuono Factory
    2007 Aprilia RSVR Factory (For Sale)
  25. #200
    There isn't a great E-Track pre made solution. Check this link. Not the entire cargo box, but if you look at the item photos you'll see a pair of square mounting plates with an E-Track clip. These + steel flat bar + chock of your choice and you make whatever solution you like for very little headache. Problem is....I haven't found those backing plates as an individual item, just part and parcel to and item such as above.
    0 Not allowed!
