Results 1 to 25 of 28
Door hinge hardware
    Door hinge hardware
    Have a door....
    Need to change hinges...
    Bought new hinges (with the same number of holes)
    The hole patterns don't quite line up.
    Return & buy new hinges?
    Or drill new holes?
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays
    Re: Door hinge hardware
    Have a door....
    Or drill new holes?
    Return and buy new if you can easily find ones that line up instead.
    If for some reason you have an odd pattern that nothing lines up to, drill new holes but that's not recommended. Presuming new holes will be very close to old holes and their integrity will be sacrificed by proximity.
    This time around take the old hardware with you when returning to match up easily.
    Just spent $185 on hinges today Pete. Lol
    Hi
    Seacoast NH
    How are y'all wearing out door hinges?!
    Lifer obsolete's Avatar
    Norf Sho
    https://www.adameve.com/adult-sex-to...ing-14462.aspx
    -Alex
    Norf Sho
    Have a door....
    Or drill new holes?
    Couple of options, I'm actually doing this today. Honestly, even if you hit the same holes the woods already chewed up a bit and you may just be fucking the holes up by reinstalling short screws.
    1. Get long screws to hopefully grab the stud behind the frame. Pre drill before doing that.
    2. Buy 5/16th dowel, cut into 2-3 inch lengths, drill 5/16ths hole where the screw holes are, wood glue the dowels, hammer them in flush, wait for it to dry, pre drill holes where need be, screw in long screws.
    I'm doing number 2 up at the cabin and it works great.
    -Alex
    Iím just changing out all the brass hardware for black.
    Lifer LuvDog's Avatar
    Ashland, MA
    spray paint
    2003 ZX7R
    1995 916
    Seacoast NH
    True story. How half the light fixtures in my house became “brushed nickel”.
    There's probably a dozen different sizes, shapes and styles of door hinges. Take one off and bring it in to home Depot or Lowe's and match it up.
    A Big Powerful Sportbike
    100 X slower than Gerard scootertrash's Avatar
    Alton Bay, NH
    My hinge tip that I learned a month ago. I had a friend at my house who is a builder. All the outside doors of my 15 year old house were starting to become tough to open. The top corner was rubbing against the door frame casing. He said that is a common issue. The door frame was (very slightly) becoming a parallelogram instead of a rectangle. He removed the top screw on the top hinge and put in a long 4" screw, which reached into the wall stud. Which squared up the door frame just a tiny bit. But what a difference ! A simple but effective fix.
    Norf Sho
    Quote Originally Posted by scootertrash View Post
    Another fix for misaligned doors are to pull the pin on the bottom and top hinge and bend the middle hinge then bend the fingers on the wall side of the top and bottom hinge with chanel locks to get them aligned.
    -Alex
    That “should” be standard installation practice when installing a new door.. actually there should be 1 long screw in each hinge.
    I had a hinge not line up like that... I filled em up with wood putty, drilled new pilot holes an knowing I had extra studs behind the door frame, used longer 6" screws, that was 30 or more years ago, the door still opens and closes. fwiw, the hinges I used on that particular door were heavy spring loaded hinges that automatically close the door, so nobody gets yelled at, "do ya live in a barn"
    Lifer loudbeard's Avatar
    I prefer to use an 8” screw when I’m drilling. Anyhow.
    Pete. This could have gone in your FRIKKEN HOMEOWNER thread without creating another. You’re a mod, be better.
    Not a cool kid Charlief's Avatar
    Ipswich
    Take a hinge to the store and try to match up as close as possible.
    If using the old holes…. grab some wooden toothpicks and wood glue. A little glue in the hole and shove a couple toothpicks in there. Install screw. That’ll give it some extra bite.
    Me no likey crash
    Norf Sho
    You know what they say about guys that talk about their screw size ?
    -Alex
    Iím guessing opposite of this?
    Door hinge hardware-b73424f7-c00c-425d-b74c-e0a8fa2bbcfc
    I thought we were doing the thing where the screw gets bigger. First it was 4” screws, then 6”, then someone was filling the hole with wood glue which was a bit weird because sticky isn’t so bad but too sticky and questions need to be answered.
    Norf Sho
    Can we all just agree to be gentlemen and at least spit on the hinge first?
    -Alex
    We can agree on that and also feel we should agree on my original point:
    Pete was a dick for making this thread. Original house thread would have served fine.
    That got lost in the whole screw size debate. My entire point of that post was that Pete is a dick.
    This discussion really deserves its own dedicated thread...
    Hypertarded
    Personally, I'd be looking for a new house at this point.....
    Burn it down and start over?
    I93/495
    Out of control leaf fire isn't unheard of....
    2012 Tiger 800 XC
