Results 1 to 25 of 38
Down-draft ranges
    Seacoast NH
    Down-draft ranges
    Long shot, but I remember NotSure had one of these years ago. So maybe there's some experience out here in NESR land.
    I have a kitchen that was designed and built in the late 80's. It features a Jenn-Air brand electric range that is a slide-in with a down-draft ventilation system. There's an electric fan under the unit and venting is plumbed underneath, through the floor joist cavity to a vent about 3' off the ground on the side of the house. There is no cabinetry or vent or anything above the range; it's located on a peninsula in the cabinets & countertop. Quite nice.
    The range is over 30 now and ready to retire. Naturally I did a massive remodel year before last including custom granite countertops. All the cabinetry in this house is custom. Kind of high-ish end. I'm now feeling trapped into replacing with a similar slide-in, downdraft model. Seems there now only 2 on the market; a JennAir and a Kitchenaid. And I think Kitchenaid owns the JennAir brand now, so these are likely the same with different facia. (Although reviews say the Kitchenaid is much better?!) They are expensive. But whatever, is what it is.
    Kicker is neither look to fit. These things have grown in the last 30 years and looks like the required depth for these units is now 28+". My countertop cutout depth is 24". Bust out the cutoff wheel and trim that countertop you say? Problem is the whole peninsula cabinet is only ~25" deep.
    I cannot leave the range proud of the cabinets even a little as there is a dishwasher 90-degrees from the range. It is a crazy tight fit between being able to open the dishwasher and clear the oven door as it is.
    I'm now thinking about building a custom extension to the cabinet to make it deeper. I have about 11" of overhang on the back-side to work with. But this will mean moving a heating register. Project creep. Bigtime.
    I suppose another alternative is install a range hood over a non-down-draft slide in. No idea how I'd vent that.
    Anyone know of other options?
    Re: Down-draft ranges
    Non venting filtered hood is likely your cheapest option.
    Lifer loudbeard's Avatar
    What if I told you that you didn’t need to vent a range hood to the outside world? I assume the range is installed on an interior wall and venting a hood would be a lot of cutting. Anyhow, most range hoods come standard with a filter system that allow you to recirculate the air back into the room. Very common in apartment and condo installations. All you’ll have to figure out is mounting and electrical.
    Hah. Beat me to it with your economy of words.
    I'm into haiku
    Lifer Falko's Avatar
    MoonTown
    Seacoast NH
    I know you guys won't believe me, but I'm not looking for the cheapest solution to this.. this time. Wife is calling the shots on this one, therefore the budget grows accordingly. If it were me that 30 year old range would get used forever.
    As it is I pressed her and this is like her 3rd or 4th priority. So we'll probably kick this can out until spring.
    Seacoast NH
    Probably not. I have maybe 1 1/2" of room between the back of the existing (apparently shallow) range and the back of the cabinet. So I'd assume something like that isn't going to fit without lots of modification.
    I didn't mean to call you cheap. Your spending habits have certainly... evolved. LOL. I think it might be yous BEST solution as well as the cheapest
    Is there a second floor above the range, or attic? If it’s attic space, there are some nice overhead options, that can be vented easily.
    I’d only use a filter vent as an absolute last resort, hated that option in my last house.
    Also, are you searching the slide up sizes online, or are you dealing with a kitchen and countertop store? I’ve found there are usually many more options available on products, that don’t show up online, if you were to go to a store that deals with this stuff every day.
    A Big Powerful Sportbike
    Is there a second floor above the range, or attic? If itís attic space, there are some nice overhead options, that can be vented easily.
    Iíd only use a filter vent as an absolute last resort, hated that option in my last house.
    Also, are you searching the slide up sizes online, or are you dealing with a kitchen and countertop store? Iíve found there are usually many more options available on products, that donít show up online, if you were to go to a store that deals with this stuff every day.
    We have a filtered vent, hate it. It doesn't work as well. Somewhere in my list of things to do around the house is venting it outside
    Sent from my SM-N910P using Tapatalk
    I don't have a vent above my stove. I JUST installed a stainless commercial kitchen shelf and put a microwave up on it. it's only been 10yrs (since I re-did the backsplash).
    You guys are making me want to spend money on my house now. Money is for motorcycles and bicycles dammit!
    I have a filter unit above my stove. It sucks. And blows.
    Lifer ZX-12R's Avatar
    Candia, NH
    You're pretty much hosed on this one. They still make 24" ranges but none of them have a downdraft vent and your options in electric are pretty limited. You won't be getting any fancy bells and whistles and you still have the pleasure of dropping a respectable amount of money. In 30" options, like you already figured out you are stuck with JennAir or Kitchenaid downdraft models and neither of them are great options.
    Many 30" cooktops are shallow enough to fit in your peninsula but you would have other modification issues since they are wider than your current opening (assuming it's 24" wide too) and your countertop isn't set up for a cooktop. For instance, GE makes a 30" downdraft cooktop that is 22ish inches deep: GE Profileô Series 30" Downdraft Electric Cooktop | PP9830SJSS | GE Appliances . Assuming you got it to fit, you would also have to find an in-wall oven that you could mount underneath it.
    I'd keep using what you're using and fix it when it breaks.
    And I lived in a house with a non-venting hood. It completely sucks. My house is vented to the outdoors and I'll never go back!
    Seacoast NH
    When they say "30-inch" or "24-inch", they are referring to the nominal width of the unit, right?
    If so my setup is a 30-inch. It's almost exactly 30" wide. This isn't a camp or studio apartment range or anything like that. The cutout width matches the spec on most of these units. The only woe is the depth of the unit.
    Is suspect my options are:
    • Build out back of peninsula - I have about 12" of overhang in the back. I could easily build a box and install it there. Would give me about 11-13" of extra depth to play with
    • Overhead vent hood - Frame out a bump in the ceiling to house the ducting, duct over to the wall, closeup the old vent underneath
    The only problem building out the back of the peninsula is there is a heating baseboard there. But those be moved.
    After trying to get my wife to focus on options standing in the appliance section at Lowes this afternoon it was decided this isn't a priority. Back to pissing time and money away on motorbikes.
    Look for us to be cooking on a hot-plate before long.
    Seacoast NH
    The 30-year old Jenn-Air range burned my wifes pies the other day, so this is a thing again. Also half the range-tops decided to only kind of work while making t-day dinner for the in-laws. No bueno!
    Fuck this stove, honestly.
    Googling my way through my options again.
    Seems I could make a new Jenn-Air or Kitchen Aid (only two down draft ranges left in the market) work if I were willing to cut stuff up (and I am). But reviews say those stoves suck.
    There are pop-up "down-draft" vents that will fit with a full slide-in range. But everyone says they suck.. or don't suck enough.. and they are definitely expensive as hell.
    Door number 3 is install an overhead "island" range hood. Joists run the right way and there is space. Would put a fugly range hood in the middle of the room and possibly block access to a cabinet. Wifey likes this idea not at all.
    Nuclear option is to demolish the whole kitchen and start over. Even if we had that kind of money.. we can't seem to come up with a better layout.
    Why the hell did I not address this ancient range BEFORE dropping all that dough on new countertops?!? That was a rookie mistake eh?!
    Down-draft ranges-dsc_0147-copy-jpg
    Lifer gixxer72's Avatar
    The desert
    Well thatís a tough call. Get some design help and gut it?
    Boss has been not quietly hinting she wants a kitchen redo (itís 12 years old). The appliances are all industrial size - Iím choking on the cost. I think Iíd rather sell the house...
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Well that’s a tough call. Get some design help and gut it?
    Boss has been not quietly hinting she wants a kitchen redo (it’s 12 years old). The appliances are all industrial size - I’m choking on the cost. I think I’d rather sell the house...
    My kitchen is OEM 1977 mostly. Needs some love but I always see the cost in bike parts and choke.
    Lucky the wife has gotten into riding too
    Dec 2009
    Since nothing else seems to be lining up maybe have something fabricated. I'm assuming bar stools slide up to the granite counter. Typically there is a foot between the top of the stool and the underside of the counter.
    Could you tuck a 2-3" diameter length of duct under the counter and vent out the wall to the right just below the counter? The duct would run laterally just above where your knees would be when sitting on the bar stool. Cover the duct behind a bit of brushed stainless (45 degree wedge where the counter meets the back side of the cabinet). You'll still have to core through the counter for the downdraft but it sounds like you've done bigger projects.
    Looking at it again this probably would draw enough air to do the job. What about a recessed ceiling mount kit?
    Seacoast NH
    Counter behind range is not currently used for seating. But I've always thought it could be. Right now the dog food and a bunch of junk lives under there.
    I've always meant to buy a couple stools and make for some breakfast seating there. But have never gotten around to it.
    Warming to the idea of a vent hood. Venting or otherwise. It would be too close to the cabinets to the right of the sink, so those would have to go. Wife does not like that as cabinet space is already short. (Or we have too much shit, one of the two.)
    Not excited about loosing the open sight lines. But whatever. Pretty confident I could run a vent out over where the cabinets to the right of the sink are. Existing vent is under those cabinets routed through the basement.
    Next option is to start moving stuff around. Next-best layout we can come up with is to move the range over to the inside wall where the fridge is. Fridge would move opposite the island where the countertop is in the left side of my photo above. There is a microwave in that cabinet. It would move to an integrated unit in the range hood. Peninsula would have to get chopped down at least a foot as there isn't enough space for the fridge as is. We'd loose a ton of cabinet space where the microwave is now. We'd make some of it up in the peninsula where the range is today. But probably not enough. Not sure how we'd address that.
    I think this layout (range to the left of the sink, fridge opposite the peninsula) is what my neighbors have. They have almost exactly the same floor-plan in a full colonial (we are a dormer'ed cape). The space behind you in that photo is different as where I have a deck they have a 4-season family room and it is offset from the house different.
    Problem is I'd have a massive hole in the peninsula.
    Can you match granite countertop? Is that a thing? This is nothing-special granite. It's one of the "stock" styles at all the home-centers. Their cheapest "A" category stone.
    Re: Selling instead of remodeling. I tried that. Didn't break my way.
    I have re-designed 2 kitchens now. Create an ikea account and use their 3d design tool to get a very real idea how it will look, and how much cabinet space you lose. I think you could do the stove/micro where the fridge is and adjust the peninsula. Cutting the countertop and adding a new piece should be no problemo. you will be needing to add or customize existing cabinetry for sure. I think it would be a better design anyway.
    Seacoast NH
    Ikea. Cool suggestion. Will do that.
    The design as is is pretty close to optimal. U-shaped, nearly perfect 3-point "work triangle". Biggest problem is slight lack of counter space. Some of that I blame on us; we seem to love our appliances and piles of crap. We also insist on stacking dishes over the dishwasher for some reason. Somehow they magically fall into the dishwasher and someone actually runs it, sometimes.
    There is a joint in the countertop between the dishwasher and the section that makes up the peninsula.
    (Paint quality) Cabinetry I can do. I've been building out something of a cabinet shop in the basement as is.
    Seacoast NH
    Paul. Did you use the Ikea cabinets? Or just their design software to get ideas going?
    My wife and I are planning a trip to Ikea this weekend. I have never been to one of their stores. She is beyond excited.
    Honestly I've been doing some reading and yootoobing re: ikea kitchen furniture and I'm kind of excited too. Lightyears ahead of the cabinetry we have.
    I'm falling further in further in with the idea of nuking the whole kitchen from orbit and doing it over again. Lots of slick slides and corner options. So cool. Also I'd like to do nothing but drawer lowers. So sick of crawling in and out of lower cabinets.
    Naturally, I haven't looked much at price tags yet.. so.
    Yes, I have now done one with kinda pricey kraftmaid semicustom, and one with Ikea. They are VERY different concepts. The Kraftmaid cabinets are solid construction. I could stand on the cabinets without breaking them. Ikea use the philosophy that they only need to be strong enough for their intended function once assembled and installed. The seem shockingly flimsy while you are assembling and installing, but once they are up, they do the job as well or better than the expensive stuff. I say better because they have more design options and the hinges, slides, lighting and other accessories are generally nicer than what you get on the store bought semicustom. The finishes on Ikea are generally not natural. They excel at the foil based paintlike finishes.
    I think if I wanted hardwood finishes, I'd pony up for traditional cabinets, if not, Ikea FTW. Although, there are now companies specializing in custom doors for Ikea base cabinets.
    Attached Thumbnails Attached Thumbnails Down-draft ranges-20190807_174236-jpg   Down-draft ranges-20190107_111609-jpg
    Seacoast NH
    Painted is what we are after. Aim is to keep it in line with the grey scheme I already chose. Same subway tile too.
    My thing is I don't like the flat euro/contemporary panels I've seen. I like a traditional raised panel, maybe shaker.. maybe.
    I see you have shaker fronts. Those from ikea too?
    Plan is to reuse pulls as well as we like what we have there too.
    May I compliment you on your choice of cabinet layout. Drawers, drawers and more drawers.
    Is that one of their panel front dishwashers too? Slick. I hear it is basically a Whirlpool.
    I have noticed the secondary front market. No shortage of options. Works for me.
