Page 3 of 3 FirstFirst 123
Results 51 to 56 of 56
Non-ethanol gas stations?
  1. #51
    Re: Non-ethanol gas stations?
    Fine for the gear, for the user around their exhaust not so much.
    As long as they don't have cats in them.
    Good point, I forget that more and more things are getting cats now. Plus, 118 octane most of the stuff he listed will be way down on power from the slower burn rate, likely acting rich.
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC / 2016 KTM 500XC W
  3. #53
    I93/495
    Quote Originally Posted by oVTo View Post
    Haffner's in Hudson NH has an ethanol-free 110 octane pump, but it has lead in it.
    Is the lead OK for chainsaws, snow blowers, lawn mowers, etc?
    How much is it? Might find 100LL at an airport cheaper.
    2012 Tiger 800 XC
  4. #54
    MOGAS (Hampton Airport and others) is not leaded.
    In upstate NY and No Ethanol Premium is $4 at the Stewart’s.
    “When it comes to the kitchen, I have a narrow band of competency.”
    Master Mechanic Roger Barr in “Chasing Classic Cars.”
  5. #55
    Lifer obsolete's Avatar
    Norf Sho
    Haffner's in Haverhill on 125 basically Plaistow has it. I don't know anymore info but that's a closer run to visit for you.
    -Alex
  6. #56
    I've started to buy premixed gas for my saw, mostly so that I don't have to think about pouring contaminated gas in from a can that gets reused, ya it's eeeekspensive, but I'm not going thru so much as I get older, it doesn't seem to get stale like pump gas, Husqvarna brand is $23 for a 110oz can, so that puts it at about $25/gal, generic is $20/gal.
    cold starts are the same, a couple pumps on the primer, and choke, however restarts with the 94octane premix are a pia as it takes 3 hands to do it, (or 1 foot & 2 hands) throttle has to be held wide open on restarts with the premix gas, whereas pump gas, is just one pump on the primer, then pull, and it's idling.
    otherwise, the premix performs much better, sounds like it gets a few more rpm, and certainly keeps em up when the bar hits the wood
