Results 1 to 4 of 4
Excel Help
    Lifer loudbeard's Avatar
    Excel Help
    Quick question for an operation I want to do in Excel - basically I'm making a sheet for our parts inventory. Two columns, one is actual quantity, the second is minimum quantity. What I want to do is compare the two cells and if the actually quantity is less than or equal to the minimum quantity, I want to turn that cell red to indicate an order is needed.
    Things I can already do:
    1.) Create a third column that has a =sum(A$1-B$1) and then apply a less than or equal to conditional formatting to that. I do not want a third column.
    2.) Do each cell individually. I can make it work in that way, but when I try to apply it to the entire column I get an error stating I can only use as a single cell or when applied to a formula.
    TIA
    Re: Excel Help
    Nevermind! Immediately after posting this I found format painter. Done!
    Re: Excel Help
    Use format painter
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays, Ironstone Ventures
    GMD Computrack Boston | Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Street & Competition | MTag-Pirelli | OnTrack Media
    Lifer SteveM's Avatar
    Aug 2009
    Norwell, MA
    Re: Excel Help
    Conditional formatting
