Results 1 to 7 of 7
Exhaust drone
    Lifer Falko's Avatar
    MoonTown
    Exhaust drone
    So the new truck ('16 Tundra) has some horrible exhaust drone at 14-1800 rpm when it starts to load a bit. I haven't had a chance to crawl under it to see what the PO did to the exhaust, maybe aftermarket don't know. Anyway, anyone know of a fix for this that doesn't involve a $1100 borla system? I've read a bit people install hemholtz (SP?) resignators with success, but I would need someone to hold my hand on that one.
    Re: Exhaust drone
    Sorry I can't help with your situation. But I had something similar recently happen in my '16 Silverado. Seems they use a passive exhaust valve so there'd be no distinguishing exhaust tones between the V8 & V4 when it kicked down. Had it replaced under warranty and can't stand the "drone" of the exhaust now at certain loads/RPM's. And I've lost a mile or two overall in the MPG department. Although I DO let the truck warm up a bit more now with the colder weather, so I'll have to wait 'til spring to really check that...
    Re: Exhaust drone
    When i got my BAM system it came with an additional pipe assembly to address the Drone. it is very simple yet effective. This goes on after the axle and before the spare tire.
    I drove around for a month before attaching to see "how bad could the drone be." yea . that bad. adding the to the exhaust made a world of difference!
    Exhaust drone-tundra-drone-pipe-jpg
    Dirty Deeds Industries - Performance Sound without the Drone
    Standard 8" System - DIRTY DEEDS INDUSTRIES
    Helmholtz Resonator - DIRTY DEEDS INDUSTRIES Helmholtz Resonator for $150 and how to install!
    MoonTown
    Re: Exhaust drone
    Yep, this is what everything is leading to. I'll call them to see if I have to buy a system or if I can just get the resignator. The drone is awful, the exhaust sounds good under power, but slight load at lower rpms and it has become unbearable.
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Exhaust drone
    My Toyota V6 has an intake howl
    The calculus of hate
    Meriden, Ct
    Re: Exhaust drone
    My '15 doesn't have a noticeable drone anywhere in the rev range. Although mine has the TRD cat-back exhaust, from the factory, as part of the TRD-Pro package.
    MoonTown
    Re: Exhaust drone
    Yeah, different exhaust system. The duals don't have the issue. Looks like I can do a resonator to alleviate the issue for now. I really want to get the Borla system for the truck, or possibly the TRD duals. I wish they did the duals into a one side exit.
