Results 1 to 25 of 49
How to fix a laptop that got coffee spilled on it
    got the coffee sopped up quickly, keyboard worked ok immediately following, a day later, the "2" in the numeric keypad stopped working, then the next day, a few more keys, then the next, I couldn't sign on cause I couldn't input my password
    0 Not allowed!
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Re: How to fix a laptop that got coffee spilt on it
    Perhaps try Plugging in a wired keyboard .
    Amazon.com: AmazonBasics Wired Keyboard: Electronics
    0 Not allowed!
    TIMMYDUCK
    Lifer Falko's Avatar
    MoonTown
    Spit or spilled??
    You need to remove the keyboard, hold it upright, and spray it with alcohol to wash it down. You have dried coffee in the key contacts.
    1 Not allowed!
    Lifer Stromper's Avatar
    Eastern Ct
    When all else fails a replacement keyboard is probably like $30
    Probably has to be named brand model number if not obvious is in the battery tray
    0 Not allowed!
    The calculus of hate
    Nov 2009
    Bristol County
    Laptop keyboards are typically pretty easy to remove if you have patience with any snap-fit plastic parts. Find the service manual for it, or watch someone do it on youtube. Usually a plastic bezel pops off revealing a few small screws. Clean any coffee residue out with alcohol or electric contact cleaner.
    The keys themselves can be individually removed as well. But that can be annoying. I'd probably get the keyboard itself out. Give it a good shaking. Then put it somewhere dry for a few hours.
    If this was fairly recently, hopefully it's just liquid left over messing with your key contacts. But a replacement keyboard off ebay is usually pretty easy.
    1 Not allowed!
    02 Aprilia Futura
    86 GPz900R
    didn't start having issues till the liquid (coffee with a ton of chocolate in it) dried
    0 Not allowed!
    Just pick up a replacement keyboard. If you let the chocolaty coffee dry in the keys before removing the keyboard and rinsing it out while it was still wet, you'll be chasing sticky/stuck/non-op keys for eternity.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    Lifer Not Sure's Avatar
    NH
    Was it decaf or regular coffee?
    1 Not allowed!
    Eastern Ct
    He said it had chocolate in it If you took it out and could give it a nice bath
    then an alchohol rinse it MIGHT survive
    There is almost a video for EVERY laptop service
    0 Not allowed!
    Spit or spilled??
    Aight, you tickled my peeve. (giggity)
    0 Not allowed!
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays, Ironstone Ventures
    GMD Computrack Boston | Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Street & Competition | MTag-Pirelli | OnTrack Media
    MoonTown
    Re: How to fix a laptop that got coffee spilled on it
    If it has chocolate in it, dip it in really warm water then a full alcohol bath to dry it.
    OR, at that point, buy a replacement keyboard.
    0 Not allowed!
    Depends on how much your time is worth.
    For the cost to replace the keyboard, I'm betting you won't bother disassembling, washing, drying, reassembling, trying it out, potentially doing it all over, etc.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    Ok, I ordered a new keyboard, on ebay for $35, plenty of videos on how to replace, but none for my exact Toshiba Satellite S75-A7222
    now, for my next question, I know theres a thread somewhere else and been asked before maybe, I have to run ethernet cable from my barn to my house, total distance by the time I add distance thru walls to the underground conduit, then thru house to where I want the router, will be about 160-175 feet, to a 200ft cable will leave me with a little extra
    I notice now that Cat 7 is available, should I go with this ?
    0 Not allowed!
    use Contact cleaner and flush it.... use some compressed air
    0 Not allowed!
    Cat 5.
    If you want to use Cat 7, just run Cat 5 and burn a bunch of money in a garbage can outside. It'll get you the same results.
    That Cat 5 will run full gig at 365 feet.
    1 Not allowed!
    -Clayton
    2006 Suzuki SV650
    Lifer loudbeard's Avatar
    You'll be fine with Cat 5e, it can handle Gigabit speeds at the length you're installing. It has a maximum run length of 100 meters. Cat 7 is used for 10 Gigabit networks, which would be fine for you but it's overkill. On your home network equipment you wouldn't be able to tell the difference and it's double the price.
    0 Not allowed!
    Here ya go: Amazon.com: 200FT (60M) Cat5e Direct Burial Waterproof RJ45 Network RJ45 Patch Cable CMXT Fully Tested Connectors Installed! - Black with Black Boot: Electronics
    There's 200' of direct burial Cat 5e with terminations for $40. You can just install a PVC sleeve on each end of the trench where it comes out of the ground and into each building.
    0 Not allowed!
    so cat 7 is ok ? I'm finding that it not significantly expensive, while 10gig speed is way more than I need now, but I don't ever wanna fish this cable again
    0 Not allowed!
    you can get cat 7 for the same price Amazon.com: 200FT S/FTP CAT 7 Gold Plated Shielded Ethernet RJ45 Cable 10 Gigabit Ethernet Network Patch Cord Cat7 (200ft, Black): Electronics
    and I don't need no trench, I have a buried conduit with a string in it
    0 Not allowed!
    It'll work fine.
    If you wanted to save $25, you could get a cheap 200' CAT5e.
    Or do the Cat 7.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    The one you posted is not direct burial. Same length Cat 7 direct burial is $80 for a pre-made 200' run.
    That said, doesn't matter anyway. Didn't read the part about you already having a pipe in the ground...so you don't need direct burial. Since that's the case, this $13 cable will suit you fine: Amazon.com: Cat5e 200FT Networking RJ45 Ethernet Patch Cable Xbox \ PC \ Modem \ PS4 \ Router - (200 Feet) Black: Computers & Accessories
    0 Not allowed!
    I'm sure cheaper cable will work fine, I don't know what the future brings, I don't want to fish the wire again, bad enuf I have to fish it at all, I was led to believe that using 4 pairs of the 25 pair cable I already have fished for telephone would work, but discovered it's not twisted pair
    0 Not allowed!
    not a "home" network, small office, 4 cad workstations, server, 4 printers, etc. as well as the "home" stuff
    0 Not allowed!
    Well fuck it then, with that work load don't stop with Cat 7, go Cat 8! No, better yet, Cat 10? Matter of fact, cats are assholes, Dog 6.7 is much better. Who's a good boy?
    1 Not allowed!
    You should probably go to a 40Gb connection just to be safe.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
