Page 4 of 4 FirstFirst 1234
Results 76 to 88 of 88
Harbor Freight Trailer Containment Thread
  1. #76
    Re: Harbor Freight Trailer Containment Thread
    Returned another of the replacement replacement wheels yesterday to HF.
    You'd think people making wheels would keep the most important aspect of a wheel in mind. IT IS ROUND
    Also, the old rims would pretty much self center on the hub. New wheels have a larger "hub ring" and it takes multiple tries to get it centered using just the lug nuts. I wish I had just pulled the bad tires off the old rims and asked for new tires.
    Garandman, let me know if you end up finding a good place to get diamond plate aluminum. My wood is getting tired.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    Cat herder
    Dec 2014
    Low Earth orbit
    Overshare.
    Just measured the HF bracket and it is roughly 9” high and 4” wide. It only extends under the fender around 3”. So the above may not be long enough. These might be better.
    Mounting Bracket for Trailer Fender - 13"/14"/15" Wheels - Galvanized Steel - Qty 1 CE Smith Accessories and Parts CE26098G
    Or the RedLine.
    If you get a thumbs down from me, pm me, it was inadvertent
  4. #79
    Cat herder
    Dec 2014
    Low Earth orbit
    eTrailer has some brackets made for other fenders that might work, probably cheaper than you can make them. I may try them.
    Mounting Bracket for Trailer Fender - Qty 1 CE Smith CE26061G
    Mounting Brackets for Trailer Fender - Qty 2 - CE Smith CE26061G-2
    Thanks, Dana.
    Yeah, I found the stuff at eTrailer. Bonus is that they also have rotomolded fenders that are a lot lighter and won't vibrate the brackets to the point of failure. (I chucked the fenders in the weeds along with the brackets). I'll probably just go that route. Yay winter projects!
    While my tire survived the incident it's going to need replacement. Thinking I'll just pass on HF... buy a tire and spoon it on myself, or just go to my regular tire shop.
    These guys are right down the street from me in Dot:
    http://www.jfreeman.com/aluminum-sheeting/
    They sell 4,x10’ sheets, so I can have it cut in half for the 5’x8’ Trailer. Going to cost $300 for a 4x@10 x 0.125” but light, strong, corrosion-resistant setup.
  6. #81
    Quote Originally Posted by adouglas View Post
    The same Chinese-made Carlisle tires HF is using for replacements is for sale on Amazon for about $30. The same tire is available US made, for substantially more. TheIglu has had bad luck but the two we got run perfectly.
    We purchased an Aluma utility trailer and plan to sell our HF once we get the other one set up. It sure served it's purpose. I'll have the spare and two HF chocks FS then as well.
  7. #82
    Got in the Bearing Buddies (model 2047) to replace the dust caps.
    Standard US 1 hubs have a dust cap diameter of 1.98 (50.3mm). The HF hubs are 52mm (2.047). Visited a number of auto parts stores, none of whom had the metric bearings, seals, dust caps or bearing buddies required.
    Attached Thumbnails Attached Thumbnails Harbor Freight Trailer Containment Thread-78a3d708-0f19-4d8e-8eb6-839fe1d20f00
  8. #83
    We put 10 D rings on this trailer before covering: Four down each side, one front, one back. They proved terrifically useful. But they corroded pretty badly, particularly the two behind the rear wheels.
    My last act before moving this on to my nephew was to replace them all with stainless steel versions, with stainless 1/4-20 bolts and nyloc nuts. $2.50 each.
    Stainless Steel D Ring Tie Downs - 700lbs SWL (4x)
  9. #84
    Cat herder
    Dec 2014
    Low Earth orbit
    Where'd you source the Bearing Buddies? And were there any complications with install?
    Got them from eTrailer. Block of wood, BMF hammer and you are done in 10 seconds.
    Bearing Buddy Bearing Protectors - Model BB2047 - (Pair)
  11. #86
    FWIW Lowe’s has the 5’x8’ wire mesh landscape trailer discounted to $650.
    https://www.lowes.com/pd/Carry-On-Tr...p-Gate/3005264
    The HF 1720 folding kit is now $450 and the 1195 $350, so less compelling than previously.
  12. #87
    San Francisco
    I’m posting mine for sale shortly, in post number 6. I believe I have two spare tires and a ramp or two to sweeten the deal. I’m thinking the $3-400 range.
  13. #88
    My nephew hasn’t been using the trailer, which has been in his barn since fall. So I’m going to sell it. 4x8 1,750 capacity model with the new/recall tires and wheels, spare with carrier, new bearings and seals, LED lights all around, 2” receiver.. Have certificate of origin.
    I’ll offer FS here first later this week. Could include one or both of these HF wheel chocks. Probably keep aluminum bar.
