Page 5 of 7 FirstFirst 1234567 LastLast
Results 101 to 125 of 172
Heat on for the season...
  1. #101
    Re: Heat on for the season...
    Still sleeping with the window open here in tropical CT
    44 this morning outside. Climbs to high 50s fast. But with the new baby we have to keep the temperature consistent at the house.
    Still nope. I don't remember ever firing up the stove before Halloween, some years well into November. Yeah, we have a furnace as well. But I try my best not to run it. I've got this alarm in my body that makes me cringe if/when the furnace kicks on.
    The way I see it is if this was March/early April, we'd all be basking in these temps.
  3. #103
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    psycho, i closed my windows at night last week. heat kicked in this morning for the first time. happy birthday to me with a gas bill.
    New homeowner chiming in with thermostats of my own... so now imma big boy.
    Imma hold out till my girlfriend's feet get frostbite... which, if you ask her, happened last week.
    Then Imma throw a pair of thicker socks at her.
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays
  5. #105
    New homeowner chiming in with thermostats of my own so now imma big boy...
    Then Imma throw her a pair of thicker socks.
    This. Is. The. Way. What kind of thermostats you rocking? You should be able to get a discount on learning thermostats through mass saves.
    Yeah imma give mass save a call at some point. I'd like to insulate over the top of the garage since all the walls are but the ceiling isn't. And I don't think there's the standard thickness over the ceilings in the rest of the house either.
    I looked at www.masssave.com and it looks like they're only doing VIRTUAL consultations now? I was under the assumption they would come out to your house... Musta changed that at some point?
    Current thermostats are a pair of these doohickeys. The LuxPro PSP 511 LCA.
    I haven't even begun to learn about em yet.
    https://pro.luxproducts.com/wp-conte...NG_Manual1.pdf
    Unfortunately we've got a separate one for the central air system... some kinda Carrier Infinity unit, but wudevs.
  7. #107
    Dublin, NH
    Turned the mini split on to quickly warm up the house this morning. Radiant and baseboard are still off, though (even though my furnace is always on...). Need to finally bring the wood in this weekend.
    2015 KTM 1290 Super Adventure
    2017 Honda CRF250L Rally
  8. #108
    I could not be happier with my hybrid oil/heatpump FHA system with ecobee learning tstat. I just set a high and a low temp and forget it. AC or heat reacts appropriately. In the shoulder moths heat is via the electric heat pump, when it gets below freezing it switches to oil. I gave up on being miserly with the tstat. House is comfy, I'm happy.
    ACs came out today, used heat last night.
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC / 2016 KTM 500XC W
  10. #110
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    That's good to hear. Replacing my 1965 lennox FHA oil furnace this winter for Heatpump with propane backup. Working from home more now, so I really want central air, and there's like $1000/ton rebates in CT on switching to heatpump.
    They do FaceTime/Zoom and then they come to finalize and take measurements
    I broke down and turned the heat on when I got home from work today. It was 64 in the old farm house and felt damp. Ill keep it on for the month of October, November 1st the oil gets shut off for the next 6 months and we switch to wood.
    A Big Powerful Sportbike
  13. #113
    I93/495
    Looks like the house bottomed out at 59 this morning. It's back up to 60 now. I guess I should pull the air conditioners out.
    2012 Tiger 800 XC
  14. #114
    Lifer obsolete's Avatar
    Norf Sho
    What type of oil are you guys burning in your furnaces? Rotella?
    -Alex
  15. #115
    I93/495
    I've been known to burn diesel in it when I've run out before
    2012 Tiger 800 XC
  16. #116
    Same. Otherwise coconut oil. My furnace is vegan.
    sometimes, I have a drip system setup to get rid of drain oil in my wood furnace, but don't use it much, cause I don't do much of my own mechanic work, I do have 5 gal of used hydraulic fluid from my Toe-Hoe
  18. #118
    Canola
  19. #119
    This thread could have easily been “who lives with kids in their house” lol
    I am kinda confused on the heat part with kids... Did you have a warm house growing up? I know mine wasn't and we all survived. What's the logic here?
    Happy wife, happy life?
    I started a fire yesterday, only cause I was working in the cold damp cellar working on my hot water heater, too hot to sleep last night cause of it
    gonna have to figure out a new way to start fires, for the past 20 years or more, I bought cheap Grade D shingles used for shimming, a couple shingles split up was all the kindling I needed to go right to big chunks, when a bundle was $7 , then they went to $9, then $13 last year, still worth it, 2 bundles last me the season. I knew they were going to be more this year....$39 for Grade D, more than premium shingles were just a year ago, Fuck that. gonna have to start Stoneman's splitter up again, and make me a barrel of fine splits, I als have some real dry hemlock branches. that I was going to use for fire pit fires
  23. #123
    Ya a lot of things were done different 30 years ago. People also used to not have car seats and survived.
    But yes. I have a newborn at home and I’d rather follow the doctors advice about what temperature the house needs to be in for her.
    And that of course.
    And that of course.
    I'm curious as to what cooler temps would possibly cause.
    Stubbornness apparently?
