Results 1 to 8 of 8
heating problem
    I Dance With Will
    Oct 2002
    unknown
    heating problem
    i have a gas heat unit. the pilot light is on but it does not turn on? anything else i can check? it was never turned on since i moved in this summer. thanks
    "fuckit!"
    heating problem
    Obviously make sure the on/off switch is on? It's usually a red switch.
    Ours has a reset button on the side of the furnace that every once in a while needs to be reset, locate it and try that..
    Sometimes gas & oil heaters have power vents, if the power vent isn't working properly, the furnace will not turn on
    A Big Powerful Sportbike
    Just Registered beet's Avatar
    May 2002
    Meriden CT
    + theres a button you push 2 light the pilot light
    www.bostonmoto.com
    Forum Rules
    heating problem
    If the pilot's lit, turn the thermostat UP!
    Jon and Clara's Dad snaggle's Avatar
    Mar 2002
    Walpole,NH
    heating problem
    Make sure it is plugged in and has power to it.
    '04 600RR
    I Dance With Will
    Oct 2002
    unknown
    heating problem
    thanks much. there is a door switch at the bottom and was not push all the way in.
    "fuckit!"
    I Dance With Will
    Oct 2002
    unknown
    heating problem
    you think so?
    "fuckit!"
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    kHAM:
    nO SMOKING WHILE YOU'RE CHECKING THINGS OUT..
    boom
    -Suf Daddy
    Suf Daddy.
  1. I've got a problem
    By Punjistick in forum General Bike Related
    Last Post: 09-10-05, 06:57 AM
  2. car problem
    By Kham in forum Off-Topic
    Last Post: 07-26-05, 04:53 PM
  3. pc problem
    By oreo_n2 in forum Off-Topic
    Last Post: 03-08-05, 07:59 PM
  4. idle problem on car
    Last Post: 03-05-04, 06:20 PM
  5. What's the problem?
    By nhroketboy in forum Off-Topic
    Last Post: 03-01-02, 10:09 AM
