Results 1 to 25 of 37
Heating the shop: Big Buddy + outdoor propane tank
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    That time of year again, and tired of going through 1lb propane tanks with my Big Buddy. Looking at getting a 12ft hose w/ regulator, storing a tank outside, and running it through the wall of my shop/shed.
    Large amounts of propane nearby make me nervous so I'm thinking 20lb tank, but a bigger tank might be nice. During the coldest months last year in the middle of projects I could go through 4 1lb bottles in a day easily.
    Still undecided on whether I should run the hose right through the wall, or get a fitment with valve to mount on the wall, and a second shorter hose indoors. Anyone have a setup like this?
    0 Not allowed!
    05GSXR75005SV65090DR350
    Lifer gixxer72's Avatar
    The desert
    Re: Heating the shop: Big Buddy + outdoor propane tank
    Quote Originally Posted by Tekime View Post
    I used the extension hose and a 20lb tank a couple feet away from the heater. Perfectly safe.
    0 Not allowed!
    Seacoast NH
    ^^^ Same.
    Unfortunately mine is a "little buddy" and doesn't do shit to heat my garage.
    0 Not allowed!
    Lifer Falko's Avatar
    MoonTown
    Just be aware with the tank outside they get cold. When cold and a quick drain on them will drop the pressure inside the tank. I ran into this issue with a large grill I have. It dropped pressure to the point I thought the tank was empty but when allowed to acclimate and get some temperature back, it was fine. I'd put a 50# tank in the corner and call it a day. Just be sure to shut it off when not in use.
    0 Not allowed!
    Mar 2016
    Falmouth, ME
    You're all nuts! I'm sure it would be fine inside, but with all the other flammables and the possible insurance issues storing indoors I'd feel a lot better with it at a distance.
    Yeah, my friend has a little buddy and last winter I helped him insulate his much smaller 5x10 shed and it couldn't even keep that heated up. The big buddy struggles with my shop (about 12x15 uninsulated) but cranked on high along with a small space heater it has kept the space usable down to negative temps. Things crank out an insane amount of heat!
    0 Not allowed!
    The desert
    Gas grill?
    0 Not allowed!
    Apr 2004
    Wilmington, MA
    people store gas in garages ( cars)... soooooo
    1 Not allowed!
    hmmmm......
    We have a propane fired Modine Hot Dawg. Is awesome.
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
    MoonTown
    If you go with an IR heater above you, they work really well. It heats you directly instead of heating the air to heat you. You can be in a 50F space with an IR heater aimed at you and you'll sweat. They are expensive though.
    0 Not allowed!
    I got more than adequate heat, and light at the same time in a similar space 12x16 uninsulated, with a Coleman 2 mantle white gas lantern, even in -25f temps, no need to wear more than a t shirt
    0 Not allowed!
    Lifer tsorfas's Avatar
    Sep 2011
    in my own little world...
    Why not kerosene? They last long time and do decent job
    0 Not allowed!
    kerosene is ok if you have the ventilation or stove pipe, it puts out quite a bit of CO, even a white gas heater or lantern, carbon monoxide is a concern, propane like a gas stove in a kitchen is clean
    0 Not allowed!
    Mar 2016
    Falmouth, ME
    Pretty happy with the big buddy - just want a bigger tank outside and trying to decide how best to do it. Safety-wise, honestly wish I had a proper fire cabinet for all my chemicals, and definitely not keeping the propane indoors lol. Way too much valuable stuff to play games with it, especially since I'm occasionally welding, cutting, using torches, etc. in a small space.
    Which reminds me, I need a new metal bin for waste rags. Many years ago my dad nearly lost his entire business to a fire over some stupid safety-ignorant employee leaving an epoxy soaked rag in a trash can. Along with a few other experiences in my life... well, I play it safe.
    Propane is under pressure and extremely explosive.
    These do look cool - try to avoid electric but do use a small space heater and wonder if I could replace it with one of these.
    0 Not allowed!
    Lifer ilikenapalm's Avatar
    Connecticut
    What are y'alls thoughts on this thing? 30,000 BTU Tank Top Propane Heater
    I have one kicking around, but I've never used it... I'm assuming I'd have to vent the space and all that? Do you have to vent with your Big Buddy systems?
    0 Not allowed!
    Quote Originally Posted by ilikenapalm View Post
    it's propane, I would use it without ventilation, no different than cooking a turkey in a gas oven in your kitchen.
    if it makes you nervous, put a CO detector in your shed
    0 Not allowed!
    a hundred years ago, that was the fear mongering going on about gasoline powered automobiles. Propane tanks are designed to handle the pressure,
    you have more risk with the little 1lb tanks you've been using
    0 Not allowed!
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    That is what you want. Pay once and do it correctly. Cost me around $1600 to buy and install the unit. 60.000 BTU so a smaller heater would be cheaper..
    I'm heating around a 24x26 space and two floors and it's a bit of overkill.
    0 Not allowed!
    Mar 2016
    Falmouth, ME
    Picked up a 12ft hose w/ regulator and a fresh 20lb tank at Home Depot for $23. I think they only fill to 15lb (or maybe 18lb) to allow for expansion, but even at HD rates that's less than half what I'd spend on 1lb bottles.
    Amazon.com: 12ft Big Buddy Hose with Regulator: Home & Kitchen
    For now, just going to run it through the wall and get a collar of some type, then
    No mongering required here, I'm naturally paranoid. I don't store much gasoline indoors either. Pressurized fuel can leak and disperse though.
    Actually just a few months ago on a camping trip my friend's tiny propane canister had a leak, created a gas cloud and soon as it reached a hot ember in the fire it ignited in a massive, instantaneous fireball around him and half the campsite. Minor burns all over his face, melted his shirt, burned off his eyebrows, and turned the fuel canister into a jet of fire (which he promptly threw at my feet). Luckily I acted fast and ninja kicked it into the woods, and the force of my mighty blow extinguished the fire. Could have been way worse though and that was just a few oz of fuel.
    Quote Originally Posted by Rosco61 View Post
    Pretty badass! For now my $100 Big Buddy, a few hundred bucks in propane, and a few hundred in electric bills for the space heater are keeping me just warm enough. Someday when we have a permanent garage setup I'll be looking at better options.
    0 Not allowed!
    Is there an example? We have a remote shed with no power. Have an extra wood stove but it’s a soapstone stove that takes a long time to heat up or cool down.
    //No mongering required here, I'm naturally paranoid. //
    You know what they say, “I know I’m paranoid, but am I paranoid enough?”
    1 Not allowed!
    Lifer loudbeard's Avatar
    I try and coach my employees against this as a matter of course, but this thread is a perfect example of creating a solution for a problem that doesn't exist.
    0 Not allowed!
    Apr 2004
    Wilmington, MA
    I mean how many threads on NESR based on that model? lol
    1 Not allowed!
    hmmmm......
    I'm more concerned about screwing those silly little bottles directly TO the heater more so than running a hose to it. I cringe when I use those 1lb. cans and try to avoid them at all costs. If I can run my hose to one of the 20lb cans on the camper, I do whenever possible. Granted, I'm not running the hose through a wall and trying to heat and enclosed space. Although my Portable Buddy heater is THEE SHIT in the hunting blinds (in which case, I stick to the 1 pounders).
    0 Not allowed!
    Mar 2016
    Falmouth, ME
    Problem: I don't want to keep the propane tank inside.
    Solution: I put it outside.
    Do you also coach them to ignore fire codes, void insurance policies, and unnecessarily waste space?
    Just asking if anyone had tips for hooking an external tank - it's pretty easy to just click past if you don't...
    0 Not allowed!
    MoonTown
    https://www.northerntool.com/shop/to..._425114_425114
    0 Not allowed!
    MoonTown
    Time of year for heat in the work space. If you have a small spot like at a work bench to heat, this would work pretty well and good price. Install it behind or over you though, they seem to be more effective than hitting you in the face.
    https://www.northerntool.com/shop/to...5479_200395479
    0 Not allowed!
