Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Heating the shop: Big Buddy + outdoor propane tank
    Re: Heating the shop: Big Buddy + outdoor propane tank
    https://www.northerntool.com/shop/tools/product_200395479_200395479
    NESR is fubaring the link nicely...
    0 Not allowed!
    771 Racing -=- FaceBook
    Backed by Heroic Racing Apparel
    A-ko - 1992 FZR400RR SP / Mistake - 1992 WR250ZD / Facade - 2003 YZF-R6 / 2000 LS650P
    Lifer Falko's Avatar
    MoonTown
    Oops, didn't notice. Thanks.
    0 Not allowed!
    High maintenance priss
    Central MA
    Quote Originally Posted by Rosco61 View Post
    That is what you want. Pay once and do it correctly. Cost me around $1600 to buy and install the unit. 60.000 BTU so a smaller heater would be cheaper..
    I'm heating around a 24x26 space and two floors and it's a bit of overkill.
    Bit OT...
    Rosco - i'm installing one of these for a 2.5 car garage (36x22 but some interior space chews into this). 3 garage doors, walls/ceiling insulated and the area above garage is finished/heated. Plan on keeping minimally heated (40*) and kick it up when I'm going to be out there. I was gonna go with 60k BTU but your post has me thinking a 45k would still do the job. Your 2 cents?
    0 Not allowed!
    Dic on
    We have a propane fired Modine Hot Dawg. Is awesome.
    60K btu Natural gas Modine Hot dawg in my 20x22, 2 floor garage and it feels toasty in there if I set it at 60 degrees.
    0 Not allowed!
    "Too bad ponies are assholes."
    OXX
    Dic on
    Quote Originally Posted by Tekime View Post
    Problem: I don't want to keep the propane tank inside.
    Solution: I put it outside.
    Do you also coach them to ignore fire codes, void insurance policies, and unnecessarily waste space?
    Just asking if anyone had tips for hooking an external tank - it's pretty easy to just click past if you don't...
    Haha, you have obviously been to our place of work.
    0 Not allowed!
    OXX
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    Bit OT...
    I would still build it with the 60.000 BTU. It will just run a bit less and better a little overkill than not enough Juice.
    0 Not allowed!
    overkill on heating systems isn't good, an oversized system will be on and off rather than a longer, more efficient run of a correctly sized heating system
    0 Not allowed!
    Ship me the bike to CA and I can work on it at a chilly 62 (high of 66)
    Jk jk...I used to work all winter in MA with a household space heater in an attached garage - can you move into one for the winter?
    0 Not allowed!
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2005 Kawasaki Ninja 500R **
    instagram @veshlife
    Oct 2007
    Peabody Ma
    I am certain that is true.
    My brother in Law is a sales guy for a big store Like Webb and my neighbor is a Webb sales guy and they both sized my garage and recommended the 60.000 BTU. They said the 60 was just a little big for my space. So I figured it might work out for Kenna as well seeing as his space is bigger than mine.
    Maybe they are wrong as well but my system seems to work just fine going on 4 years now.
    0 Not allowed!
    A “little big” is good if you use it like we do: turn it on, wait until it warms up, do your work, shut it off.
    It’s 4 at Sunapee right now and I have to do some trailer work. Working without gloves in 4 doesn’t work so well.
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
    Lifer tsorfas's Avatar
    Sep 2011
    in my own little world...
    are those heaters that go on top of your regular grill sized gas tank any good?
    Are they safe to use in non vendelated space? 1.5 car garage.
    0 Not allowed!
    Central MA
    Those tank mounted heaters do work fine other than the obvious drawbacks (moisture, clearance, venting). A fan on low speed can help even out the temp.
    And ya - you definitely should crack a door or window if using those tank-mounted heaters. I believe 1sf for every 15k btu was what mine said.
    0 Not allowed!
