Results 1 to 15 of 15
Hitch Receiver Pin Help!
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    I put a locked hitch receiver pin on my truck before the winter. I was lazy and left it on the truck. It has a "weather cap", but at some point the cap came loose and dirt/mud/sand/snow got into the lock. Now I can't get the key into the lock to open it.
    This is the pin/lock setup Model No. 2848DAT | Master Lock
    Suggestions on how to remove it? Take an angle grinder/cutter to the pin? To the Lock? Something else I haven't considered?
    Thanks!
    (mods: if there's a better place for this thread, please move as appropriate)
    0 Not allowed!
    I93/495
    Re: Hitch Receiver Pin Help!
    Quote Originally Posted by noxin View Post
    Thanks!
    Engine Degreaser/Cleaner through the red tube thingy to try and flush the crap out followed by penetrating oil to try and free stuff up. If that doesn't do it or it's too far gone to bother dealing with, whatever you have that is easiest to cut through the thinnest area you can access and then just buy another.
    1 Not allowed!
    2012 Tiger 800, 2007 DR650, 2012 WR250R
    Apr 2008
    Boston, MA
    Yeah, I'm not planning on saving it unless I can get the key in.
    I might try and cut the lock side off first.
    Just wanted to make sure I wasn't being batshit crazy
    0 Not allowed!
    Lifer loudbeard's Avatar
    Angle grinder.
    1 Not allowed!
    Hypertarded
    these random lock picking/breaking/drilling vids have been poping up on my youtube page recently, it appears for your application a section of pipe will be SUPER easy:
    top vid should work, this one just shows easiest spot to cut.
    1 Not allowed!
    Apr 2008
    Boston, MA
    hahaha, here I thought I read it was a hardened steel pin. I'll need to get a section of pipe and see if I can just break it off.
    0 Not allowed!
    Lifer ZX-12R's Avatar
    Candia, NH
    Hardened just means it will snap instead of bend.
    1 Not allowed!
    Lifer tsorfas's Avatar
    Sep 2011
    in my own little world...
    Did that genius move as well. Nothing a $14.99 harbor freight grinder can’t fix in a few.
    0 Not allowed!
    Or, you can use my plan: Start with a similar locking pin... leave said pin in for a couple years. Tada, absolute theft deterent as the pin is now rust-welded to the hitch and will NOT come out. I can take the lock off, but there is no moving the pin. I lifted the rear of my truck by that pin trying to rotate it with a jack.
    1 Not allowed!
    771 Racing -=- FaceBook
    Backed by Heroic Racing Apparel
    A-ko - 1992 FZR400RR SP / Mistake - 1992 WR250ZD / Facade - 2003 YZF-R6 / 2000 LS650P
    Apr 2008
    Boston, MA
    If I didn't need a different size ball to move the "other" trailer, I would just leave it. Hell, I even thought about putting a larger receiver on the small trailer to make it easier.
    0 Not allowed!
    Just get one of the quick change ball setups.
    0 Not allowed!
    -Christian LRRS/CCS #316 ECK Racing GMD Computrack Boston | Pine Motorparts/PBE Specialists | Woodcraft | Street & Competition | OnTrack Media
    So how do you secure a trailer to a car effectively? Big-Ass chain?
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
    Lifer Falko's Avatar
    MoonTown
    I've seen people lock the safety chain to the reciever. If someone wants it, they'll get it. Knew a guy in Fla that had the locking pins on his hitch and trailer. The thieves simply unbolted the ball and probably dropped it into a different receiver.
    When vacationing with our boat, I put a snake chain through the wheels and locked it. Not a perfect solution but would take a little time to get the trailer.
    1 Not allowed!
    Hiram, ME
    Ha! I have a draw bar that it so rusted into my dad's old minivan that I pulled(hammered) the pin out, chocked all four wheels on the fully loaded tire trailer, and tried to pull the draw bar out that way...only to roll the trailer up and over the chocks...
    ...so now I'm doing this, and putting a 1-7/8" coupler on my little HF trailer so that everything uses and has a 2" ball.
    0 Not allowed!
    Apr 2008
    Boston, MA
    So, the pipe trick worked in about .... 3 seconds It's absolutely stunning! Really drives home that these types of products simply deter those not determined to take someone else's crap.
    Thanks for everyone who provided feedback.
    0 Not allowed!
