Results 1 to 25 of 39
At home DIY dry age steak.
    Apr 2004
    Wilmington, MA
    So I picked up a steakager and threw in a 7? Bone in prime rib about 5 days ago. And just threw in 12 in long loin strip ( ny strips). Anyone else dip their toe in this little hobby? Might pull the strip in 20 days and prime 15 days later
    hmmmm......
    Re: At home DIY dry age steak.
    I do short few day bursts in the fridge, AB style. Works mint.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    I didn't know this was a thing. Keep talking about hanging your meat out.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Apr 2004
    Wilmington, MA
    Want to see my meat ?
    hmmmm......
    Apr 2004
    Wilmington, MA
    At home DIY dry age steak.-img_1726-jpgAt home DIY dry age steak.-img_1727-jpgAt home DIY dry age steak.-img_1727-jpgAt home DIY dry age steak.-img_1729-jpg
    hmmmm......
    Lifer LuvDog's Avatar
    Ashland, MA
    Nice looking meat
    2003 ZX7R
    1995 916
    2 things:
    -Evaporation. Fridge is a low humidity environment compared to being in a package of juices. Think of it like coffee. Lotta water, weak flavored coffee. Way less water, more flavorful, richer coffee. Same thing with steak. Juicy (overly that it) steak is NOT a good thing. That's just water diluting the flavor.
    -Enzymes. Age allows these little critters to gnaw on the meat a bit, changing the flavor and making it more tender.
    -Clayton
    2006 Suzuki SV650
    Apr 2004
    Wilmington, MA
    This is a good explanation.
    The Food Lab's Complete Guide to Dry-Aging Beef at Home | Serious Eats
    The prime rib will be be pulled after 21 days maybe 28 maybe 37 IDK.
    I threw in the loin to have something in the interim if i cant wait. The prime was 13 lbs about 140$ butcher helped me select the best one with a good fat cap etc. The loin was about 85$.
    We have a small fridge on our 3rd floor that i cleaned the interior with dawn and with a 50/50 mix of vinegar and water. Holding at 35.5 degrees and about 60% humidity which is slowly dropping to the salt block in there. Before the meat went in it was 10% humidity.
    hmmmm......
    Lifer ZX-12R's Avatar
    Candia, NH
    The AB method works well for me too and has a great results-to-cost ratio compared to doing a true multi-week dry aging.
    The things it can do with a thick NY strip is amazing.
    -Clayton
    2006 Suzuki SV650
    Apr 2004
    Wilmington, MA
    So I returned that steak ager.
    I purchased a plug in computer fan and a plug in UVC light.
    Remote sensor for humidity and temp and everything is humming at 40% humidity and 36 degrees. Strip loin will come off on Vday and the prime rib 14 days later.
    CAN NOT WAIT!
    hmmmm......
    Lifer loudbeard's Avatar
    What's your plan for cooking the prime rib?
    Apr 2004
    Wilmington, MA
    IDK. Usually for the holidays or such I make a prime rib with the method x method and works out great.
    But with this I'd like to cut up into steaks and whatever I dont use Vacuum seal it( keeps very well due to low humidity)
    If I do just "steak" it I havenever tried anything other than grilling. but redign seems people do reverse sear sous vide etc... may be too complicated for me my gas grill will get to 550 maybe 6 gor a good sear but no where near 800
    hmmmm......
    If you happen to do a whole rib roast with this one, let me recommend giving this article a read:
    Amazing Ribs: Perfect Prime Rib
    It's a pretty long article, and as with any Meathead article you end up going down the rabbit hole of several other great articles he links to during the read. Their approach is rather than using weight to derive an estimated cooking time, the thickness of the meat is more important. I've tested a number of his recipes (prime rib, leg of lamb, smoked turkey) and their methods are sound. Anyway, worth the read, he changed my life.
    Wouldn't you just use temp to know exact cooking time?
    Remote probe thermometer is a useful tool that every carnivore should own and utilize.
    -Clayton
    2006 Suzuki SV650
    Yes but it's only half of the story. Traditional calculations would say something to the effect of "20 minutes per pound at 325." What the Meathead is suggesting is that the weight isn't actually a factor because the shape of various cuts of meat differs so greatly. The turkey example is one of the best. If you leave the turkey cavity hollow, you have approximately a 3" thick slab of meat to cook through. If you stuff the cavity, you end up with a solid hunk (giggity) that's 10 or 12" thick. In the latter case, you end up with a dried out breast by the time the stuffing reaches 160 because the meat cooks from outside to in.
    Another good Meathead article: What Influences Cooking Time?
    All that said, we can agree having good temperature measuring tools is critical. I run a Weber Smokey Mountain 18.5" with an Auber temperature controller. Basically I have 3 air intakes on the bottom of the smoker, I close 2 of them, and then put an electric fan in the third. The fan is switched on/off by a temperature controller, which also has a thermocouple I can position wherever I want in the smoker. It does an awesome job, regulates the temperature within +/- 10 degrees and with a full load of charcoal I can run at 225 for about 11 hours. For a meat thermometer I use the Weber iGrill 2. I can use up to 4 meat probes and it connects via bluetooth to just about any smart device.
    i can't wait for the meat to dry.
    just found a place that wells wagyu ribeye bit pricey at $28/lb BUT so frigging good off the grill.
    go faster cdovego's Avatar
    Weymouth
    Duncan steered my lady unit towards an infrared wireless thermometer that pairs up to my phone and the best smoker made. Duncan knows meat and now I'm fat.
    Central Mass Powersports #123
    Cooking turkey so the breast is still tender and juicy while the dark meat is cooked properly?
    Spatchcock.
    Or, foil tent over the breast for some of the cooking time to radiate heat away from it until the dark meat catches up.
    That, and NEVER put your stuffing in the bird. What is this, Good Housekeeping? Next up you'll tell me you don't brine your poultry. UP IS DOWN! BLACK IS WHITE! DOGS AND CATS, LIVING TOGETHER!
    -Clayton
    2006 Suzuki SV650
    Weymouth
    Mind putting up a link to the steakager you got? Do you like it?
    Apr 2004
    Wilmington, MA
    Dry Aged Beef | How To Dry Age Beef | Dry Aging Steak At Home
    its ok. I had no idea of how to dry age beef so i picked this up
    Its key components are
    1- fan
    2- uvc light
    3- carbon filter( cheap)
    4-temp / humiduty probe with an app to monitor
    It worked fine till I realized that its small. I joined a fb group for dry aged beef and learned that with a purchase of a uvc light and fan and remote "sensorpush" I could use my 3rd floor frig to dry it.Or even buy a frig seperately and have as much room as i want. Not so much for more meat but just to keep good airflow etc
    I returned the steakager because the meat i put in there was too tight and the air flow did not look good.
    Now you cant really age your meat in your everyday frig as it will pick up all the frig odor of the foods( why steakager has that carbon filter but even they say to not really use it in your daily frig, more a beer fridge) in there and the opening and closing will not control the temp or humidity right.
    hmmmm......
    Weymouth
    Appreciate you sharing your feedback. I fell down the smoker rabbit hole due to Duncan and aging the meat is naturally next step. Let me know if you come up with a stand alone unit that makes sense.
    Apr 2004
    Wilmington, MA
    some pics of my meat and setup.
    its nota beer fridge, just a frig/freezer on the 3rd floor
    you can see the uvc light ad fan on 2nd rack
    and the blue square- that's the sensorpush, i can get alert and set ranges on it for humidity and temp
    top rack is the NY sirloin ( fat cap on bottom)and below that the prime rib( fat cap on bottom). Very nice bark on it. When its trimmed some folks grind that with burger meat and its supposedly delicious.
    At home DIY dry age steak.-frig-jpgAt home DIY dry age steak.-frig-jpgAt home DIY dry age steak.-img_1837-jpgAt home DIY dry age steak.-img_1838-jpgAt home DIY dry age steak.-img_1840-jpgAt home DIY dry age steak.-img_1841-jpg
    Seems folks like this frig for a starter EDGESTAR vbr240. Wine frig's are too warm and other smaller fridges dont get cold enough.
    hmmmm......
    Spatchcock.
    Come at me, bruh
    Lifer obsolete's Avatar
    Norf Sho
    AB method? Alton Brown's paper towel method?
    -Alex
