Results 51 to 75 of 103
Home Gym
  1. #51
    Lifer gixxer72's Avatar
    The desert
    Re: Home Gym
    This post was incredibly helpful, thanks for writing it all up.
    I don't have an unlimited budget, but if you were to go with a Rogue rack for either a basement or garage, what would you go with? I want something that can take a pull-up bar, but my unfinished basement ceiling is about 93" high. It's obviously going to lose an inch or two when I finish it, so that's gonna get real tight...
    You donít have enough clear vertical. The rogue rigs, racks and cages all have dimensions on the website.
    The monster lite rack is 92Ē, wall mounts are taller. If you get a cage that fits your space you can always use the spotter bar for pull ups with crossed and bent legs to keep your body/head lower.
    Re: Home Gym
    You don’t have enough clear vertical. The rogue rigs, racks and cages all have dimensions on the website.
    The monster lite rack is 92”, wall mounts are taller. If you get a cage that fits your space you can always use the spotter bar for pull ups with crossed and bent legs to keep your body/head lower.
    There are a couple of options that are 90" high, like the R-3 Power Pack... but that's going to be really, really tight. Are there any specific racks you'd recommend that are 90"?
  3. #53
    I93/495
    Re: Home Gym
    Why not just put an olympic bar across some of the higher holes and do pull ups off that?
    2012 Tiger 800 XC
  4. #54
    The desert
    Re: Home Gym
    Sorry, I donít. My last house had the gym in the basement and I had to place the cage so the top pulley assembly fell between the stringers. It was tight. But it worked just fine.
    This house has 10í ceilings so I had a ton of options and got the Monster Lite cage (smaller footprint).
    Re: Home Gym
    And get a rack or rig with a lower overall height, you mean? Sorry if this is a dumb question...
  6. #56
    I93/495
    Re: Home Gym
    If the racks are 90-92" and you only have 93" you run out of space for your head on a pull up if using the top "pull up bar". So why not rack the bar at something like 70" and hang off it with bent knees so you can still do pullups?
    Like this pic but with the bar mounted low enough so you still have clearance.
    Home Gym-pull-pullup-gym-1200x628-facebook
    2012 Tiger 800 XC
  7. #57
    New Haven-ish, CT
    Re: Home Gym
    If I put the barbell here at the top of my half-rack, it’s about 6’ high. I can bend my knees and do pull-ups from it.
    Home Gym-3081ae20-ee58-44db-8f3a-7ec5f2d4dded
    Re: Home Gym
    I’m an idiot, I didn’t even think of my head being even higher. Thanks for the picture, that looks like a good workaround!
  9. #59
    Mar 2004
    woonsocket ri
    Re: Home Gym
    I bought a treadmill from Dick's before everyone knew what traitors they were. It was originally $3500, but they were getting rid of the brand for another one and marked them down another $1000. Then they had the floor model and it was $1200, so I bought it. It showed 45 minutes of use on the clock. I can use Google Maps to put in a route and run it using street view. The treadmill will change elevation according to the actual elevation of the road I'm supposedly on.
    My actual screen of a route in Hawaii on street view.
    I also have a very low ceiling and wanted a squat rack. They were always way to tall. I found this bench and rack on Craigslist. I think I paid $300.
    The weights I bought mostly on craigslist when they weren't asking stupid money for them. The barbells up to 25 lbs also came from Craigslist. The rest I bought one at a time from Dicks before they were actual dicks.
    I also bought a Precor stretch trainer. I used to use one at a Golds Gym and thought it was awesome. I also got that from Craigslist for $200.
  10. #60
    Lifer BSR6's Avatar
    Re: Home Gym
    I'm just seeing this reply now...
    Honestly, I can't say which exact rack I would go with from Rogue. They've always been out of my budget so I never immersed myself in the variations from one model to another. I can say this...Go with a full rack. Believe it or not, half racks actually take up the same amount of space but lack the safety and the many options a full cage gives you. If you're worried about height there are shorter options. The only catch with something shorter is you'll have to lift your feet when doing pull-ups.
    I wouldn't dwell on getting a super high end rack. Go with something that has the right dimensions. I would love a Rogue just because I like nice things, but in reality, my 2x2 does just about everything a Rogue would do.
    Lifer BSR6's Avatar
    Re: Home Gym
    Number 9 here you go. At 82" high this should be perfect for you. Titan's are Rogue knock offs. The quality isn't nearly the same, but functionally there's no difference.
    https://www.titan.fitness/racks/powe...0210219_244932
    There's is a 2x2 option as well if you want to go a little cheaper. This is pretty much identical to what I have. It's also available in an even shorter version at 71".
    I strongly recommend you browse the rack accessories to see what kings of options you have. Below is the link for the 2x2 accessories.
    https://www.titan.fitness/racks/rack...es/t-2-series/
  12. #62
    The desert
    Re: Home Gym
    Well of course the shit showed up today, 2nd time Iíve been out of bed in six days...570 lb pallet!
    It took every fucking thing I had to get it offloaded and unpacked. Quality of components is absolutely fantastic and USA made. In this case you do get what you pay for.
    The Hydrow is scheduled to arrive tomorrow.
    Attached Thumbnails Attached Thumbnails Home Gym-f676a904-4271-4297-ad83-5c921b96083f
  13. #63
    The desert
    Re: Home Gym
    Done, except for a set of 10/90 adjustables. Clean and simple setup for powerlifting.
    Attached Thumbnails Attached Thumbnails Home Gym-7a3a15a4-09fe-41df-9fbd-02d15e9a4ed7
    Re: Home Gym
    I need another home gym program delivery as i've have put this one to bed. By far the toughest program to date. The Beach program.
    Home Gym-20210204_112134-jpgHome Gym-20210204_112125-jpg
  15. #65
    Re: Home Gym
    Looking good man!
  16. #66
    Re: Home Gym
    I just bought a skipping jump rope. Fuck me, I can't do double unders.. the last time I tried this shit I was about 12 years old.
  17. #67
    Seacoast NH
    Re: Home Gym
    Jumprope; fastest way to prove to yourself you have zero coordination and are a clumsy fuck that shouldn't be left alone with anything this side of a spork
    Re: Home Gym
    It took me more time than I'm willing to admit to for me to be able to do 20-25 single unders without tripping over. I can't believe how hard this shit is at my age.
  19. #69
    Re: Home Gym
    Hello darkness my new friend. I hate doing pullups -- because I can barely do them -- so I thought I might as well buy a pullup bar.
    Home Gym-img_0059-jpg
    Haven't bought a rack (yet) as I'm enjoying working out at a gym with people and learning stuff. I suppose I'll get one before winter comes. I did the Murph yesterday... took me 54:20 doing ring rows and kneeling pushups.
  20. #70
    Re: Home Gym
    Looks like it can double as a tire rackHome Gym
    Sent from my SM-G981U1 using Tapatalk
  21. #71
    Re: Home Gym
    It would if I had any!
  22. #72
    Re: Home Gym
    Any recommendations for a weighted vest? Preferably something comfortable (relatively speaking) as I plan to run in it.
  23. #73
    Re: Home Gym
    I ended up with this which works well.. I tend to run a few 5Ks with it half-filled (it's about 11.5lbs). I added this to the basement recently though:
    Home Gym-img_1156-jpg
    It's pretty good so far.
    Attached Thumbnails Attached Thumbnails Home Gym-img_1156-jpg
  24. #74
    Lifer BSR6's Avatar
    Re: Home Gym
    I'm just now seeking the updates that came after my last post. That's one sweet set up.
    If you want to train right on a bike indoors get some rollers. Since buying a decent set I can't/won't use anything else.
    Something to consider...I just added a third row of uprights to my rack. Despite making the rack bigger, it actually saved me a lot of space. Now I can store all of my plates on that third row which freed up a ton of space around the rack. It's also a lot easier to load and unload the plates as they are stored at a more ideal level as opposed to being on the floor or on a separate storage solution away from the rack.
    Re: Home Gym
    Quote Originally Posted by BSR6 View Post
    I go back and forth on the bike stuff.. I have had that trainer for years (and the bike was free) but honestly don't ride it much. I need to get back on it, but I've been really struggling with fit issues... though that's true when I ride outside as well. More than 1 hour on the bike and my crotch really starts to hurt, more than 2 hours and it's almost unbearable!
    Post some updated pics of your setup. I haven't got any weights yet.. been going to the local CF gym 5 days a week for classes, but once the weather (and the baby!) come I might get a rack for home. We'll see
