Page 5 of 5 FirstFirst 12345
Results 101 to 103 of 103
Home Gym
  1. #101
    Re: Home Gym
    It certainly helps with accountability, ADD folks like me and strength endurance. That's why I dig it.
    Same for me really. I never would have expected that I would love it, but here we are! It's not perfect - there are some movements that I think are pretty dumb (e.g. butterfly pull-ups which I can't do anyway) - but it's been a great 9 months so far.
  2. #102
    Lifer 01xj's Avatar
    CT
    Re: Home Gym
    Think I'm ready to pull the trigger...
    Home Gym-untitled-jpg
    Paired with this bench https://repfitness.com/products/ab-3...justable-bench
    Have some Dicks gift cards I can pick this up. Not the best, but using the gift cards towards the weights is kind of ideal. Especially having them in stock locally.
    Lifer BSR6's Avatar
    Re: Home Gym
    I have almost the exact same set up only I don't have the lat attachment and I bought a different bench (also made by Rep Fitness).
    Something to consider with the bench...If you go with just a flat incline and forego the decline option you get a much smaller and less expensive bench without sacrificing quality. Also, decline benches tend to have wide base pads allowing you to hang by the back of your knees when you are in the decline position. This can be a problem for other positions such incline or even flat as the wider pad can force your legs into an awkward angle.
    I've also found there's no need for decline work as the alternatives are actually better.
    Long story short...I started with a FID bench and ended up just going with an FI bench due to the above. The bench I ended up with was a lot cheaper but still great quality and the few inches less it is in length made a big difference.
