Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Honda Lawnmower Won't Start
    South Coast MAsshole
    Re: Honda Lawnmower Won't Start
    tech did the following:
    1 technical service bulletin out for rear wheel brackets...warranty fix
    2 silica sand in fuel from fuel degradation...flushed fuel system
    3 swapped out spark plug...precautionary
    4 timing belt jumped due to hitting something...reset belt
    5 blade bent and dull...straighten/balance/sharpen
    6 flywheel key checked...it was ok (which i already checked
    ...still will not start...2-5 i will have to pay for since that was my fault...
    7...pulling valve cover tomorrow to check for stuck valves...i'm guessing this won't be warranty work either
    4 and probably 7 are the issues...the blade i would have just sharpened and bent back myself like i do each year and it would have been ok...i used a spark plug from an identical mower to test and i ground tested mine and they sparked similarly so i'm sure that was fine...silica sand settles and nothing was in the carb when i cleaned it so i'm sure that wasn't an issue either
    0 Not allowed!
    bike: FOR SALE: 2010 Bonneville SE 1,257 miles
    Point37s Garage Sale Thread
    Timing belt? On a push mower? We sure about this?
    "Silica sand" from fuel degradation? Never in my life encountered such a substance as a result of fuel....and silica IS sand.
    Judging by the fact that we are talking about a bent blade, I'm curious what as to what in the heck you hit, did it stop the engine dead and did the engine run after the blade bending incident?
    0 Not allowed!
    Jan 2012
    Mass
    The Honda's have a timing belt..
    Sent from my Pixel using Tapatalk
    0 Not allowed!
    Lifer ZX-12R's Avatar
    Candia, NH
    Many Honda industrial engines have an overhead cam with a timing belt. You can also see it in the video Point37 posted when they remove the valve cover.
    0 Not allowed!
    How did he reset the timing belt if he didn't take the valve cover off?
    0 Not allowed!
    771 Racing -=- FaceBook
    Backed by Heroic Racing Apparel
    A-ko - 1992 FZR400RR SP / Mistake - 1992 WR250ZD / Facade - 2003 YZF-R6
    Didn't watch the video but holy shit, color me amazed at Honda managing to reinvent the wheel. I imagine these belts have a service interval?
    0 Not allowed!
    Candia, NH
    This is right from Honda's website:
    Q: My GC series/Mini 4 Stroke series Honda Engine has an internal timing belt. How often do I have to change it?
    A: Never. Honda's internal timing belt is 100% maintenance free.
    0 Not allowed!
    Lifer Falko's Avatar
    MoonTown
    It lasts the life of the engine, give or take .23 seconds.
    3 Not allowed!
    yea personally i think the sand thing is bs...unless there was sand in one of the older gas cans...i'm not the only person who uses the mower but i know i didn't hit anything
    0 Not allowed!
    Be very interesting to see if these engines are around in 20 or 30 years like the GX's.
    0 Not allowed!
    Jun 2005
    Has anyone suggested not changing the oil and leaving it outside for a winter at Stoner's house?
    4 Not allowed!
    Lifer Stromper's Avatar
    Eastern Ct
    I always add a paper filter element fuel filter to everything like $2 on Amazon
    0 Not allowed!
    The calculus of hate
