Results 1 to 12 of 12
anyone got the hookup for plumbing parts?
    I'm looking for a stack switch for an oil heater, model # RA117A1047
    the cheapest I found it for is $133.15 shipped on amazon.com, or a local plumber will want a flat fee of $500 to buy their own and install it
    it sure can suck to sleep at night and put my tush on a cold toilet when there's no heat in the house
    oh, and does anyone know how difficult it is to replace it?
    it just looks like a couple screws remove it from the main piping, and screw terminals hold down like 6 wires or so...what could go wrong?
    Lifer JohnnyV's Avatar
    Westborough, MA
    It would be kinda funny if you somehow happened to ignite a full tank of home heating oil.....
    Waterbury, VT
    With the part number in hand - check FW Webb, or the local plumbing supply places.
    JeffL on this board helped me quite a bit with my boiler - might be worth giving him a PM.
    SSearchVT
    Jun 2005
    thanks...sent JeffL a PM and going to check w' other places after work
    does anyone else know how difficult it is to install one?
    I talked to a couple friends and both of them told me to hire an HVAC tech to do it in case I f*ck it up.
    Dic on
    Do it yourself.
    Just make sure the breaker is off first.
    "Too bad ponies are assholes."
    OXX
    Waterbury, VT
    If you don't have the manual look up your boiler on line, and take a good look at the diagrams (a few times). Shut off the power (red switch plate - should be installed upside down, either in the boiler room, or at the top of the basement stairs - or the breaker) and the oil feed. Once you get the covers off the boiler it should be fairly self explanitary how to replace it. Digital pictures and hand made wiring diagrams if needed.
    SSearchVT
    Oct 2004
    Southeastern Taxachusetts
    Did you find one yet?
    I work at a HVAC company and can prob get you one at wholesale. Looks like a Honeywell part number....is it for a boiler or furnace?
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
    thanks for the tips guys, I ended up pulling the trigger on the one from Amazon, which ships from CT so it should get here pretty soon
    I'm at work right now, but I'll check for the model # when I get back up the business.
    it's a furnace
    we have heat!!!
    my friend and I went ahead and replaced the stack switch (you just disconnect the wires, unbolt/remove the old one, put in the new one, then screw down the wires) and there is finally heat coming off the radiators! the timing couldn't have been any better because while it was only in the 30's last week, tonight the temperature is 14 degrees...which would not only make it cold in the house, but would make it more likely that the pipes would freeze
    the only problem is, the radiator in the living room makes a rattling noise, and just sprays water out of the (overflow? overheat) valve
    also, when the contractor was working on the kitchen, he just unscrewed and detached the radiator altogether from the pipe coming out of the floor, so (even with the knob tightened all the way down) steam comes directly out of the pipe: is that steam toxic?
    can I just let the steam come out for a couple days?
    I can't quite wedge the radiator onto the pipe, so can I just get a cap on the pipe coming out of the ground and not use that radiator for the time being?
  1. HONDA PARTS HOOKUP?
    By KB in forum Pit Area
    Last Post: 09-30-07, 08:27 PM
  2. plumbing/hvac work needed
    By bigred875 in forum Off-Topic
    Last Post: 08-09-07, 09:49 AM
  3. PLUMBING & ELECTRICAL ?
    By jjs777 in forum Off-Topic
    Last Post: 05-28-05, 02:40 PM
  4. Plumbing advice - need tor un new pipes
    By ftrain in forum Off-Topic
    Last Post: 11-17-04, 09:13 PM
  5. used parts
    Last Post: 04-08-03, 01:58 PM
