Results 1 to 22 of 22
Any ideas on how to add a rough texture back to sanded bricks?
    Posting Freak
    Nov 2014
    Someone (definitely not me) went a little overboard sanding and removing paint from some bricks, and now some of those bricks are buttery smooth. Trouble is, they're adjacent to some natural/rough bricks. Any ideas on how I might renew their original rough texture?
    Oct 2007
    Milton, MA
    Re: Any ideas on how to add a rough texture back to sanded bricks?
    Could you carefully sandblast them?
    Posting Freak
    Nov 2014
    I should have done that from the start, but at this point Iíd rather not. Iím thinking a very abrasive wire brush might get me close enough.
    Lifer LuvDog's Avatar
    Ashland, MA
    Wire wheel? Just a hammer and pick. Do you have pictures of what you’re trying to match?
    2003 ZX7R
    1995 916
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Ice axe.
    It really depends on what sort of "rough" you're looking for.
    Lifer G21forme's Avatar
    Lakes
    Chisel
    [/IMG][/URL]
    Lifer gixxer72's Avatar
    The desert
    Birdshot
    Junior Member PurplePackage's Avatar
    Oct 2020
    Chelmsford, MA
    acid etching, but don't wash it off, let it melt the brick
    https://www.youtube.com/watch?v=jeYxjrMdAiw
    always acid into water, never the other way
    New Haven-ish, CT
    Do they still have paint on them (or repainted), or are they bare brick now?
    -Matt
    are you sure they weren't smooth to begin with, I've seen some brick mfg'ers with very smooth textures, especially old bricks, there were brickyards all over that are no longer in existence.
    Quote Originally Posted by Bonk! View Post
    I'd be EXTREMELY careful doing that. Sandblasting bricks is primarily used for cleaning purposes. Jack that pressure up too much and you could turn them to dust!
    Posting Freak
    Nov 2014
    Thanks! I don't have a ton to do...realistically it's like 3-4 bricks that need help. I think wire wheel and chisel might be what I'll try next.
    They were rough to begin with. Hard to explain, but some were painted, some were not. I stripped some with chemicals, some with wire wheel, and some with too aggressive wire wheelin'.
    Member Studio X's Avatar
    Jun 2015
    Republic of VT
    When bricks are fired, the process creates a glazed, super hard shell. The inside remains relatively soft. Wear away the crust through weathering, scrubbing, sanding, acid etch, physical blows or whatever and you expose the soft interior that will dissolve/crumble fairly quickly when exposed to the elements. Be very careful when "cleaning" or you'll end up replacing them sooner rather than later (and matching existing brick and mortar when they do need replacement is a non-trivial task.)
    x
    2012 D675R / 2010 Tiger 1050
    Posting Freak
    Nov 2014
    Quote Originally Posted by Studio X View Post
    x
    Good tip, thanks! The exposed area on the ones that are smooth definitely feels like it could crumble.
    x
    This is solid info. Never sandblast brick, or even pressure wash up close. The masons we work with always use an acid cleaner, a scrub brush, and lightly power wash it away. They also seal it a couple days after the wash.
    A Big Powerful Sportbike
    Jun 2015
    Republic of VT
    I don't know what your masons are sealing brick with but it has been demonstrated that if too water tight, the moisture that inevitably gets behind the brick veneer though condensation, cracks and/or water vapor migrating from the inside will freeze in this climate and significantly accelerate brick and mortar disintegration.
    This was a HUGE problem in the 60's and 70's with historic restoration work when people thought they were protecting fragile brick structures by spraying the exterior with a silicone solution. All they did was trap the naturally occurring moisture within the wall. Brick is porous. It needs to breathe.
    I donít know the product they used to seal the brick, it was in a 5 gallon bucket tho. Majority of our work is new commercial construction where the brick is just a veneer with a decent air gap on the backside. Maybe the condensation is thought to be eliminated with air from the inside?
    New Haven-ish, CT
    Idiot, bricks don’t have lungs.
    -Matt
    Jun 2015
    Republic of VT
    Have you ever disected one? Not likely!
    x
    Lifer obsolete's Avatar
    Norf Sho
    I don’t know the product they used to seal the brick, it was in a 5 gallon bucket tho. Majority of our work is new commercial construction where the brick is just a veneer with a decent air gap on the backside. Maybe the condensation is thought to be eliminated with air from the inside?
    I'm not sure brick veneer is made the same as real brick. It breaks up differently, but that could be due to the size difference. I'm curious if they make it differently.
    -Alex
    on commercial projects, the veneer is a whole brick, not those fake slices
    Jun 2015
    Republic of VT
    If it is real (clay) brick, it has to be fired. The glue-on stuff can be made of composite material.
