Results 1 to 25 of 26
Injet printers
    Dec 2009
    Injet printers
    Anyone have experience using either the Epson Ecotank or Cannon Megatank inkjet printers? Im considering buying a printer with the large capacity ink reservoir but wasnt too impressed with the quality the demo printed out (1st generation Ecotank). Id be BS if I spent the +$3xx only to find it regularly skipped lines or had paper jams. Id considered buying a CISS kit for my HP inkjet but the kits seem a bit cobbled together.
    Hanover, NH
    Re: Injet printers
    Is there a reason you don't want to go with laser?
    Dec 2009
    Re: Injet printers
    It's been years since I'd looked at one outside an office environment due to the cost. Do they make sense for a home printer, especially with color?
    Re: Injet printers
    Quote Originally Posted by 02redhawk View Post
    they may have changed but i would steer clear of these types of kits. i destroyed a high end, large format Epson by installing one of those kits. i didn't cheap out either. pissed doesn't even come close to my reaction. i smashed the shit out of ALL of it i was so disgusted.
    i don't have any experience with those particular inkjets but for all of them i've used, clogged heads, skipped lines and paper jams just seem to be part of the deal. we had much better luck with color lazer in a mixed-use small office of designers and reg users.
    what are you typically printing?
    Re: Injet printers
    depending on your needs and budget, yes, there are some nice options available these days.
    Lifer Falko's Avatar
    MoonTown
    Re: Injet printers
    I'm still running a Samsung 310C for my home printer. It is a color laser and does a nice job.
    I also have a large format inkjet, HP, for 11x17 dwgs. It has to be run once a week or does a shitty job. I wish I could afford an 11x17 laser...
    Nov 2009
    Bristol County
    Re: Injet printers
    Yep. I just bought a color laser Brother multifunction with wifi for a little over $300. Simple black & white laser single function are like a third of that. The catch is that on average, they're all larger units.
    I can't comment from a frequent use POV, since I rarely use a printer. But I had a basic cheap B/W laser for years before this. Maybe inkjets got better, but I'm still sour on waiting for the heads to clean, and finding blotches and streaks on the print out. Even when it came out right, never looked as laser anyway.
    nedirtriders.com
    holland ma.
    Re: Injet printers
    I have a newer ecotank and its not great. As you mentioned it does skip lines but i only see that in full color copies and its not that it skipped it, its that it skipped certain colors in a line. Still looks like shit but for the low end stuff i use it for its ok. Truthfully i try not to useif i can help it. 99% of my printing is done on an older brother mono laserjet printer. Things a tank and has never given me an issue. My ecotank has already been serviced once and it didnt fix dick. When it dies im going to get a nice brother color something or other.
    Re: Injet printers
    we just bought an Epson WF7610 about 6 weeks ago, ink cartridges are much larger than the HP OfficeJet it replaced (but smaller than the cartridges in our DesignJet plotter)
    2 paper trays, + bypass stack
    prints & scans, borderless, 2 sided up to 11x17
    I will put it to the true test next week publishing a wetlands impact application
    Re: Injet printers
    any printer will paper jam with damp paper. We keep a dehumidifier going, winter is not as bad with heat on, other 3 seasons, we are pulling 2-3 gallons of water out of the air every day in our 900 sq ft office space
    Lifer loudbeard's Avatar
    Re: Injet printers
    Interesting fact, as printers become larger and faster laser technology is cheaper. That said, quality is not as good. The best quality and highest speed production printers are....INK JET! Of course this really only becomes true when the printer is at least the size of a vending machine (laser desktop kicks the shit out of ink jet desktop) and I typically work on machines that are about the size of a half ton pickup sliced in half longways. These are all digital machines...offset is a different thread.
    Edit: I realize this has nothing to do with this thread...but it's winter.
    Lifer SteveM's Avatar
    Aug 2009
    Norwell, MA
    Re: Injet printers
    Just bought an HP M477dfw for my office.
    HP
    Dic on
    Re: Injet printers
    just bought two of these for our office.
    Attached Thumbnails Attached Thumbnails Injet printers-varioprint-6330-titan-fsr_800x338-png
    "Too bad ponies are assholes."
    OXX
    Re: Injet printers
    not to side track but do you guys work for a print house? i need high quality digital and offset printing from time to time, would be nice to know some locals.
    Dic on
    Re: Injet printers
    Yep! Send a PM. We have offset in Marlboro, MA and we do digital color and B/W in East Providence.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    OXX
    Re: Injet printers
    rad . danke!
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Injet printers
    I have a samsung 460 laser 4 color been happy and it came with full cartridge
    EVERY ink jet was DRY by the time I used it
    The calculus of hate
    Dec 2009
    Re: Injet printers
    Thanks for all the great info. You saved me from making a poor choice. As someone on this forum reminded re recently "buy once, cry once". Sounds like I need to start looking at a color laser.
    Injet printers
    rad . danke!
    We also have digital color in Marlborough...actually better digital color than in East Providence, its a new Canon VP10000. Can do up to 13.9x30. Our offset press is a 5 color machine that will do 24x48 with some smaller 3 color presses as well.
    xxaarraa
    Guest
    Re: Injet printers
    After years of wrangling with stupid inkjets that always ran out of ink just when you needed to print, or always dried up and needed the head cleaned and aligned, and paying through the nose for their factory ink cartridges (Epson, Canon etc they all charge an arm and a leg for their tiny cartridges), I finally got a laser printer for the house and couldn't be happier. The thing is fast.
    I got B&W only, but color laser is not that expensive these days. Highly recommend going laser route. Toner lasts longer than ink cartridges and never dries out.
    $129 buckaroos. Amazon.com: Canon imageCLASS MF244dw Wireless, Multifunction, Duplex Laser Printer: Electronics
    Dec 2009
    Re: Injet printers
    Ordered a color laser. Thanks for the great imput. My only question (being that it is winter) what oil should I use with it?
    xxaarraa
    Guest
    Re: Injet printers
    If it's a 2 stroke printer, run Rotella T6 at 32:1
    If it's a 4 stroke printer, run Rotella T6 at stated oil capacity on the oil pan.
    Hell, even if it's an electric printer, still run Rotella T6 just to be safe.
    Re: Injet printers
    Faaaaack that. Get some Silkolene 0w20 and double your pages per minute by not having to pump that heavy diesel targeted crap around your delicate digital wonder.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    xxaarraa
    Guest
    Re: Injet printers
    Do you realize that Silkolene is like $25 bucks a quart retail? Even if you find a deal online, its near $20 bucks a can.
    For $20, you can get 8 gallons of Rotella or printer oil for life!
    Re: Injet printers
    I have a gallon of Pro R 0w20 right beside me, it's what I ran in my pit bike. I'm fully aware of the wallet draining properties. Still faster than Rotella, when I'm printing my newest online Waifu I don't want to wait for the oil to come up to temp before I've got new wall art.
