Results 1 to 20 of 20
ISP that doesn't suck ?
    100 X slower than Gerard scootertrash's Avatar
    Alton Bay, NH
    When will someone offer internet service that doesn't suck?
    I've been with Atlantic Broadband (Metrocast) for 10+ years. Paying $80 a month for just internet. They claim it is "high speed" with 50MB bandwidth, but the best I can get using a wired connection is 5MB Up and Down. That's on a good day. After months of complaining, they sent me a "new" cable modem yesterday because they realized my old one was obsolete. The new one is over 5 years old and used. I tried to connect and the password didn't work. So I finally got into the setup of the modem and found that the SSID password was "Tony77" instead of the random numbers and letters on the label on the modem. So I have to assume it is a modem that used to belong to Tony and he returned it to Atlantic because he hated their service too. With the new modem I did go from 1MB to 5MB upload using their own speed test. But still far below what I am paying for. Their customer service is horrible, they really could care less.
    But I guess this is the price I pay for not living in a city that has fiber available.
    Does anyone use TDS for internet? Any good/bad experience?
    Ok, I'm done ranting.
    Re: ISP that doesn't suck ?
    I have TDS, but we're fiber optic. I'm surprised you're not. We have the 300/300mbps plan. At any given time we'll have at least one streaming TV service (sometimes two - we no longer have "cable"), two devices, and a computer all sharing. Very rarely a problem. Again though, that's their fiber optic package.
    Truth be told though, we weren't UNhappy with their broadband before they upgraded.
    Nov 2009
    Bristol County
    This depends strongly on what's available in your area. Many customers have exactly one cable internet option, and often FIOS isn't available as an alternative.
    Is the modem an 'all in one' device, with wireless and ~4-5 wired connections on it? Or is the modem a seperate device that plugs in to a router/switch/wifi? Are you performing the speed tests on a wired connection? To confirm for sure that the ISP is the problem (or maybe a cable outside your home), connect directly to the modem. Take a sample at a non-peak hour. In a perfect world, 3-5am is probably ideal but that isn't practical for most people.
    Have the model # on the modem handy?
    02 Aprilia Futura
    86 GPz900R
    The 50Mbps you are paying for is download speed. I'd test that again.
    Upload will be limited to 5Mbps or so on most cable ISP's.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    2000 Honda CBR929RR
    Alton Bay, NH
    Thanks for the info on TDS. I'll have to look into that some more.
    I used to have a dedicated cable modem from Metrocast (now Atlantic Broadband) and my own separate wireless router (very modern Cisco unit) but the latest modem they gave me last night was a combo unit. Has both wired and wireless in one unit. Brand is Pace. Model is D5001 I am pretty sure. (I am at work, not home right now). I even tried connecting my personal cisco wireless router to their new modem to see if "my" wireless is better than their wireless hardware. No noticeable difference.
    I used their speed test from the Atlantic web site. The best I can get up or down is about 5MB. That is wired or wireless. It's a bit faster with wired but not much. I tried on three fairly modern laptops. Two Windows10 and one Windows7.
    I'll try it some time on off peak hours. I am occasionally up at weird hours for work issues.
    It would be interesting to connect the modem to the line outside my house, to see if there is some issue with the cable in the house. But I don't think there is a junction outside. The house is fairly modern, around 10 years old. It's modern cabling in the house.
    Nov 2009
    Bristol County
    Re-read. He's got a 50mbps plan that he's seeing 5/1 on, but recently saw 5/5. But I think your underlying point is still valid that download speed is far more important for the home user unless they do a lot of streaming or high resolution video uploads.
    Quote Originally Posted by scootertrash View Post
    If you can get somewhere close to 50mbps wired non-peak, that at least proves everything on your end is working properly. You've got the right idea with trying to eliminate as much of your coax as possible too - just for testing.
    Google has their own speed test (just google 'speed test'). It's easy to get to, and I might compare results against the ISP's test. Although I'd probably still reference the ISP's own test when dealing with customer support.
    Also, watch out for the acronyms/abbreviations. When you say '5MB', technical people read '5 megabytes' but most ISP speeds are in mbps or 'megabit per second'. Yes, it's confusing and messes people up all the time, even those who know about the difference. 8 bits per byte, meaning 50mbps is actually 6.25MB/sec.
    02 Aprilia Futura
    86 GPz900R
    Dublin, NH
    Try a speed test from another provider, like speedtest.net or fast.com. On speedtest.net select a well-known ISP endpoint, like Comcast. I've found that some peers are just really slow.
    2015 KTM 1290 Super Adventure
    TDS here too, used to have Metrocast, they were first with fiber on my street, land line phone was on TDS copper, when TDS put fiber up my way, I switched to TDS, nice to have a choice of 2 different companies with fiber on my street, not many people have more than one fiber option
    Damn you were pretty spot on here. Hadn't checked in a long time. Charter with 57.4 down and 5.01 up with 25ms lat.
    I just got 9.4mbps down, and 16.1 up, from wi-fi connection, will my hard wired computer be faster ?
    I pay for commercial, not residential, upload speed is suppose to be = to download speed
    Dec 2009
    While not adding anything useful to the conversation I suspect most people believe their contract guarantees "XX MB/sec" when the language in the contract actually says "Up to XX MB/sec". No guaranty that you'll ever see those speeds.
    I pay for 200/20, I can pull 300/25 at times. Spectrum cable.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX
    Alton Bay, NH
    Thanks for cheering me up...
    Re-read.
    -Clayton
    2006 Suzuki SV650
    2000 Honda CBR929RR
    If you're consitently not getting close to what you're paying for, and are not getting any resolution via Metrocast's support, file an FCC complaint. I've done it twice with TWC/Spectrum when they let my local node get oversubscribed with no plans to improve.
    the above test was from my laptop via wireless
    from my hardwired desktop, I'm getting 31.9 down, and 27.3 up
    I believe I pay for 50 down, 50 up
    *up to...
    Nov 2009
    Bristol County
    Re-read.
    5 up and down. Maybe we're talking past each other here. Either way, hopefully OP got something out of it.
    Quote Originally Posted by 02redhawk View Post
    I thought you had to at least theoretically be able to see the max at some point. Even if that's only at 3am on a Sunday night. But wouldn't surprise me if that's not how it plays out in the real world. It's definitely true that on a cable ISP, you may not see the max speeds at peak usage.
    If that's fiber, I'd think you should be able to get pretty close to 50mbps then. It's possible for the computer or cable to be a limiting factor, but seems unlikely to be the problem at 30mbps trying to get to 50. To answer your previous question, it's almost always faster wired. Consumer wireless technologies typically aren't as fast, even in a perfect configuration. But in practice, many wifi speeds are lower than they could be due to interference or radio-wave blockage. At 10mbps down on wifi, you've probably got room for improvement. Check what your wifi supports, like 802.11g means best-case maximum of 54mbps. If it's the very old 802.11b, that would explain it and you're actually running up against the maximum. Nothing wrong with 802.11b if it's meeting your needs, but you'll probably want to upgrade soon.
    02 Aprilia Futura
    86 GPz900R
    I just turned off my streaming radio, got 73.1 down, 29.9 up, I don't know what Anne has streaming from wireless in the house.....
    my modem and router are probably old, I have 2 devices that throw a wireless signal, the modem, supplied by TDS, and the router I bought, my house is about 100 feet away from the wireless, at the limits of range, usually I connect to my router, but during inclement weather the signal is week, sometimes the TDS modem throws a better signal, but usually we are streaming 2 devices in the house, while browsing on 2 more
    yes, my router is old, maybe 10 years, TDS modem is newer, when I switched from Metrocast, to TDS, has it been 5 years ?
    my plan at some point this summer, is to run a hardwire to the house, I have a conduit, with my telephone extension, I left a string to pull another cable, then I will hardwire my Roku, and have a network cable at my desk, and a closer wireless source, in the house, I would also like to boost my signal to reach 500 feet, then I could connect anywhere on my property
    yes, I have fiber, as I posted before, a somewhat unique situation, there are 2 fiber optic lines on the poles on my street, the first, installed by the Cable TV company a long time ago... late 80s/early 90s more recently, the Phone company replaced their copper with fiber. with deregulation, both companies offer all 3 products, TV/Phone/Internet
    Same on our side of the hill. We also have TDS & Atlantic Broadband available, both fiber as you know. We had TDS back in the old days when the local server was still Worldpath. We've stuck with them through dial-up, DSL & now fiber. Even bundled their cable service before we cut the cable. Still not hearing good things about AB over our way. And as I've said, TDS has been pretty rock solid even with all the shit that's usually running now.
