Results 1 to 25 of 38
Jumper Cables
    Jumper Cables
    I know what I want when I can touch and feel, but haven't found what I want in stock locally
    I have decent set, 0 ga fine stranded copper cable, parrot clamps, 16' stretched. One of my clamps came off so I have to resolder the terminal that bolts to the clamp. I will be repairing them but I got thinking I really want a longer set, 25' or longer, even if I have to go up to 00 cable. 16' just isn't long enuf unless you can almost part nose to nose
    I have searched online and found what claims to be what I want, but then I read reviews and don't know what to believe. I really want to hear a review from a more known entity before I spend what I believe will cost $100+
    Or should I just order a $200 set thru NAPA
    Meriden, Ct
    Re: Jumper Cables
    Buy a lithium ion jumper pack and be done with jumper cables forever.
    Re: Jumper Cables
    no thanks, even though I've seen them work more times than not, 3 times in the past week, I have personally witness a fail that was saved with jumper cables
    One fail was saved with my broken clamp set and a pair of vice grips
    Lifer SteveM's Avatar
    Aug 2009
    Norwell, MA
    Re: Jumper Cables
    You’ve seen lithium ion packs fail three times in the last week?
    Re: Jumper Cables
    it has been -15į, 2, my son was moving some cars for snow removal, don't know how long they been sitting, he ended up going for his trusty jumper cables. The other was my Jeep that hasn't been started in 4 ? months, one of my employs had one in his car, It turned it over, and we tried repeatedly, just not turning fast enough, hook up my jumper cables to my chevy truck, it cranked at noticeably quicker speed and vroom it went
    it's not that the lithium battery doesn't have the energy, of all the ones I have seen, they have 6ga or 4 ga at best, cable coming out of the battery to the clamps, and that don't work any better than cheesey 6ga or 4 ga jumper cables, sure it'll start a daily driver that isn't having running issues, but no go to something that hasn't run in a while and the past 2 weeks of sitting has been below zero nights, and may not be the best running engine, and of course, stale gas. Maybe there are some out there with 2ga or 0ga cables, I ain't seen em
    Raymond NH
    Re: Jumper Cables
    I am very skeptical about wire gauge claims of any cables purchased online. There are a lot of outright lies out there. I can't imagine spending that much money on cables though, I've never had any issues using 50ish dollar cables and have a set of them in all 5 of the cars/SUVs/trucks in my family stable.
    Re: Jumper Cables
    If you have a Lithium Jump Battery donít leave it in your car in the cold. If you need to do that, buy an AGM pack. We have a Clore JNC660, course it weighs 9-1/2 lbs versus 10 ounces.
    Most people give up too early with Lithium jump packs. You might have to leave it connected for 30-120 seconds before the vehicle will start: those smaller cables canít flow current like larger gauge wire. Our old boat had two batteries and we had to wait five minutes.
    As to cold, we have an AntiGravity XP10 but recently purchased an XP1 as it is small enough to keep in an interior coat pocket for early season camping and cranking the snowmobiles.
    As to jumper cables, we bought a 2 ga copper 20í set from Northern Tool with a credit recently, price was $70. They work fine, but the exact model has been discontinued and the replacement seems to be $80.
    If you get a thumbs down from me, pm me, it was inadvertent
    Re: Jumper Cables
    Most people give up too early with Lithium jump packs. You might have to leave it connected for 30-120 seconds before the vehicle will start: those smaller cables can’t flow current like larger gauge wire. Our old boat had two batteries and we had to wait five minutes.
    that is the problem, Lithium jump packs only work, if the vehicle being started has a battery that will accept a charge over a time period, a jumper cable (of heavy enuf gauge) will start the vehicle regardless, you could pull the bad battery entirely and hook the clamps to the vehicles battery cables
    Re: Jumper Cables
    anyway, enuf talk about booster packs, I want info on high quality jumper cables 25' long. What is copper going for these days, $2.75/lb ?
    Lifer zxme's Avatar
    Mar 2007
    Mass
    Re: Jumper Cables
    Dihard Platinum ones work pretty good also. My set were stolen about 8 years ago and never really bought another good set
    Aug 2009
    Norwell, MA
    Re: Jumper Cables
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    Re: Jumper Cables
    I just used my $16 4g 20’ cables Monday to start my wife’s car. Those worked just fine for me and that car hadn’t been started since Friday. Maybe I’m just not over thinking it.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    LRRS #246 - Central Mass Powersports / Northeast Cycle / Woodcraft
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Jumper Cables
    The calculus of hate
    Lifer loudbeard's Avatar
    Re: Jumper Cables
    I canít believe thereís a thread about jumper cables. Whereís granddad to give us the cliffs notes on the latest consumer reports?
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Jumper Cables
    2 sets of #1 or #2 will give you more overall conductor capacity (the 2-#2 is very close to 2/0 in cross section, 2-#1 is closer to 3/0) as well as give you more versatility.
    2 sets will take up more space, as if nothing else, you have more clamps.
    Re: Jumper Cables
    I actually just bought a set from Target when on clearance and they do everything I need LOL
    seems like you have a more heavy duty need for them though...I just jump start my bike from my truck or *maybe* another car in a parking lot...and yes tip to tip is the only way with 16' cables
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2005 Kawasaki Ninja 500R **
    instagram @veshlife
    Re: Jumper Cables
    Yuasa makes a set of motorcycle size cables.
    Re: Jumper Cables
    Copper ? doesn't say, they are out of stock anyway
    if they truly are 0 ga copper, the scrap value is close to the asking price
    I suspect aluminum at the price point
    fine stranded copper cable is a must, with silicon sheathing for flexibility in sub zero temps, parrot clamps that work with GM side post crap as well, enuf length to jump someone nose to tail
    Re: Jumper Cables
    Just sent you a pm with just what you are looking for, on sale.
    We just tell our guests, “If you have any doubt your car will start in the morning, park facing out, or it will be here until Spring.”
    Re: Jumper Cables
    not what I am looking for
    #1, they are copper clad aluminum
    #2, they don't have parrot clamps
    Re: Jumper Cables
    Lol! Right to the point you old prick! This is how I picture you two discussing jumper cables.
    Re: Jumper Cables
    If anyone is interested in 25’ cables this is the link I sent. $200 on sale for $70. No dog in the fight.
    https://www.northerntool.com/shop/to...6113_200626113
    Re: Jumper Cables
    $200 is their fluffed up price they advertise to make you feel yer getting a good deal @ $70, look a little further into the Q&A and you quickly discover they are aluminum cables
    Re: Jumper Cables
    Wire is sized to conduct a given amount of ampacity, there is nothing wrong with using properly sized aluminum conductors. There is nothing wrong with copper clad aluminum. If your so damn concerned about using the most conductive metal, shut up and go buy some silver cables.
    Aug 2009
    Norwell, MA
    Re: Jumper Cables
    Perhaps oxygen free audiophile qualit cable stripped, rewound to combine for gauge and rejacket with unobtanium/Kevlar
    Or....Milspec Industries, Inc. - Professional Series Booster Cables
