Results 1 to 23 of 23
Ladders, aluminum or fiberglass?
    Finally gave back the aluminum extension ladder I borrowed from a buddy 9 years ago. Of course, as soon as I do this, I need to get up on the roof and clean out my chimney cap.
    I think it's about time to buy a decent ladder. Needs to go 2 stories up to get on my roof. I'm thinkin a 28' is right.
    Question being, aluminum or fiberglass.
    Aluminum is rather wiggly. Not exactly confidence inspiring. I'm not good with heights on wiggly ladders.
    Fiberglass is heavier? Not sure on that one.
    I'm thinkin fiberglass.
    Something like this decent enough for a homeowner?
    Werner 28 ft. Fiberglass Extension Ladder with 300 lb. Load Capacity Type IA Duty Rating-D6228-2 - The Home Depot
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    2000 Honda CBR929RR
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Re: Ladders, aluminum or fiberglass?
    I use fiberglass because they don't conduct. If I wasn't worried about being electrocuted I'd probably use aluminum. Fiberglass tends to get beat to shit if it's left out in the elements. The 28' extension and 10' step ladders I bought 7 years ago look pretty rough already.
    With that said, the ladder you linked would work fine, that's what I have at home. At work I have a 28' Featherlight ladder. Quite a bit lighter than an average ladder, sturdy, and you can fold the feet around without having to extend the ladder.
    0 Not allowed!
    Lifer union's Avatar
    Blackstone, MA
    I prefer fiberglass. I like them better because they they don't conduct electricity. They are heavier and the longer ones can be tricky to move around alone. I'm not sure which will flex more given the same length but any ladder will flex and it gets worse the longer the ladder is.
    The ladder you choose is the same one I have but mine is only 24 foot. It has been a good ladder for me. I would buy again.
    Another thing to consider is getting a stabilizer. Depending on how much over hang you have it may bump you out a little more and the ladder will be less likely to move side to side while you're on it. Werner Universal Stabilizer-AC96 - The Home Depot
    0 Not allowed!
    James
    12 KTM SMR 450
    07 CRF 250R
    LRRS/CCS #79
    NEMM #79
    GMD Computrack
    Diamondback Designs
    Robs Dyno
    I have a 40' fiberglass extension, it's freekin heavy, (needed to get to the peak of my barn) I would have prefered an aluminum extension ladder, but couldn't find one that was rated for over 275 lbs, my fiberglass ladder is rated for 350 lbs. You could get away with an aluminum ladder
    my fiberglass is hard to put up alone, almost impossible, an aluminum ladder is easy to put up comparatively,
    once up, I much prefer a fiberglass ladder, aluminum ladders feel to bouncy
    0 Not allowed!
    A little off topic, but what's up with the chimney cap?
    In terms of the ladder, what these guys said. Aluminum is lighter but a bit flexy, fiberglass weighs more but tends to feel more stable. I keep 32' and 24' fiberglass extension ladders and 12' and 20' foot aluminum roof ladders (really just one length of a 24 and 40 foot extension ladder with a ridge hook attached) on the truck and can get to most any chimney with that combination.
    0 Not allowed!
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    if you buy the correct grade aluminum ladder it will not feel flexible at all.
    D800 "PROFESSIONAL" SERIES ALUMINUM EXTENSION LADDERS - Lynn Ladder & Scaffolding Co., Inc.
    0 Not allowed!
    Quote Originally Posted by Rosco61 View Post
    Took the words right out of my mouth!
    There are different grades of ladders and I always felt the consumer grade ones were wobbly. Went to Lynn Ladder years ago when I lived in Marblehead and bought a Grade I ladder. The ones at the big boxes are usually Grade II or III. Type IA in the link is 300 lb rating. Makes an immense difference. It also helps with stability to get the spreaders at the top, and they're essential for painting.
    LYN-LAD STABILIZER - Lynn Ladder & Scaffolding Co., Inc.
    You often have to move them alone and I didn't plan to work on electrical so, aluminum.
    0 Not allowed!
    Lifer ZX-12R's Avatar
    Candia, NH
    My preference is for fiberglass as well and I have a 28' IA extension ladder that replaced an old 24' wooden one that weighed a ton. When you get into the heavy duty aluminum ladders, there really isn't much weight savings over a fiberglass. Fiberglass is non-conductive but over a long period of time can be degraded by UV light if not properly maintained. Aluminum is conductive but you can store it outside indefinitely and requires minimal maintenance.
    The Werner ladder you posted is an excellent one and you benefit pricewise from the economies of scale because Home Depot carries it.
    0 Not allowed!
    Why am I still here?
    I just finished a primary research project with tradesmen where this topic unexpectedly came up over and over again. The professional choice is fiberglass, hands down. That being said, they all complained about the fibers eventually becoming exposed causing an itchy mess.
    0 Not allowed!
    It will be stored in a heated garage, so outdoor storage with UV issues isn't a concern.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2000 Honda CBR929RR
    Jun 2016
    Exeter, RI
    I always buy fiberglass unless I know the ladder will live outside. In general, I don't trust aluminum ladders because they are more susceptible to accidental damage by getting banged around. If the ladder drops or gets hit by something, any bend or kink can be a failure point. Fiberglass is more forgiving to typical usage/storage abuse that I see in my garage. Weight is less of a factor as its not something i use daily.
    0 Not allowed!
    I wouldn't buy an aluminum ladder, most importantly because they conduct electricity. They are also more wobbly and in my opinion, harder to set up/pull down with the rope. Aluminum is not as slippery as fiberglass, so the ladder "sticks" more when pulling it up. Fiber glass is heavier, but manageable once you figure how to do it.
    0 Not allowed!
    A Big Powerful Sportbike
    Quote Originally Posted by freezinvt View Post
    The screen that covers the vents to keep critters out might be getting clogged. I'm not getting the draft I used to. I sweep from inside my house with fiberglass poles, so I can't visually check it without using binoculars.
    I'll need to have a ladder handy either way once winter hits.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2000 Honda CBR929RR
    that reminds me, I have to get my 21' Gorilla ladder back that I loaned to my son,
    0 Not allowed!
    Lifer Stromper's Avatar
    Eastern Ct
    Fiberglass does NOT attract lightning
    0 Not allowed!
    The calculus of hate
    Aluminum is not as slippery as fiberglass, so the ladder "sticks" .
    I find that silicone spray lubricant helps quite a bit, especially on my Gorilla ladder
    0 Not allowed!
    WMC original sdog30's Avatar
    Burgy
    Wow.
    I live on a ladder, literally. I'm a roofer. Really surprised the consensus is fiberglass. I can't stand fiberglass ladders. Definitely not as well built as a good aluminum ladder. Not sure I'd be hitting wires with either, just don't hit power lines or clean your chimney in a lightning storm.
    I think aluminum is very sturdy and lighter than fiberglass. That being said, we only by from Lynn ladders.
    1 Not allowed!
    12 Ducati Multi, 17 Husky FS450, 15 KX450F sumo, 15 Husky 250SXF tard, 14 KTM 250SXF
    LRRS/CCS #66
    I'm not a professional roofer, nor do I want to spend big $$$ on something I'll use once a year.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2000 Honda CBR929RR
    I didn't want to either, but when I need it, I need it, my 40' Type 1AA ladder cost me nearly $800 and I've used it 3 times in the 10 years I've had it ..... you could always rent a Lull
    0 Not allowed!
    Lifer Falko's Avatar
    MoonTown
    I grabbed a ladder from work, aluminum, that was at the end of its service life (insurance thing??). Been using that for 10+ years. The catch broke on one side, I jam a piece of 2x4 in there once extended. Yeah, living on the edge, bitches. Anyway, for a couple times a year, I couldn't tell the difference between aluminum or fiberglass. They'd both enable me to put up my Christmas lights and burn the birds nest out of my woodstove chimney.
    0 Not allowed!
    Nah. I don't rent stuff. Waste of money. I let my neighbor buy one and just use it from time to time.
    Doesn't help a lot in the middle of winter because the Lull is 4wd, therefore prone to get stuck (wish it was 2wd).
    Still need a ladder. Don't need a professional ladder. I won't be using it hourly, daily, weekly or monthly. Probably once a year. I'm thinkin that fiberglass jobby I linked will work fine for my needs.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2000 Honda CBR929RR
    I'm sure it will, you weigh a lot less than me, and the peak of yer roof isn't as high, if I was in your situation, that is the exact ladder I woulda got
    0 Not allowed!
    I used to have a job in college where I power washed the peak eves of our town library, in a wind/rainstorm, with a 40' aluminum ladder at full extension.
    I have ZERO interest in being at the top of a 40' ladder ever again.
    0 Not allowed!
    -Clayton
    2006 Suzuki SV650
    2000 Honda CBR929RR
