Results 1 to 18 of 18
laptop set up multiple displays
    Apr 2004
    Wilmington, MA
    I swear tech is killing me these days.
    I thought it was simple.. Wanted a dual monitor set up at home like I do at work
    Meaning I open my laptop see the desktop(display area 1, then have another 2 seperate monitors with an extended desktop(display 2 and 3)
    Well I bought the 2 monitor stand and 2 decent monitors and an HDMI splitter that said it could extend the desktop.
    it does extend the desktop from the laptop but the 2 new standalone monitors when i go into display settings show only as Display 2, i dont see display 3. I do see display 1 my laptop built in.
    i assume it is part of the HDCP compliance?
    How can i Bypass it or is that even the issue?
    All I want is 3 parts of my extended desktop like I do at work
    sigh.. has not been a good couple of days
    hmmmm......
    Lifer Falko's Avatar
    MoonTown
    Re: laptop set up multiple displays
    I had that issue. I had a docking station at work, and one at home. The docking station at work would allow a three screen set up but the one at home limited me to two. I thought they were the same docking station. Contacted IT and got a bunch of blah blah translated as "Yeah, no idea but I can't say that so here's some shit that you won't understand and covers my ass." Two screens is enough for me at home because I don't have to hide NESR on the laptop screen like I do at work.
    An HDMI splitter will only show as one display to windows, with an oddball extra wide resolution.
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX
    Lifer virtualbong's Avatar
    Framingham, MA
    Do you have any other outputs outside of just HDMI? VGA? DisplayPort? That would be the only other option and easiest imo that I can think of. You may find a tutorial on youtube as well.
    YouTube
    Apr 2004
    Wilmington, MA
    so I ordered up this
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    hopefully this wil resolve the issue.
    I found USB to HDMI splitters but they relied on USB C and the wife's laptop doesnt have that.
    I also ordered up a mini display port so I'll have 2 cables from laptop each to a different output monitor
    we will see
    hmmmm......
    That will let you see the same thing on two monitors. It won't extend your desktop to have 3 usable monitors with 3 different things on it.
    Splitting signal is still using the same signal. If you have Facebook up on one monitor, now you'll have Facebook up on two. What's the point of that?
    You need a graphics card that can support multiple display output. What ports do you have on your laptop? You'd need a dedicated port for each monitor. Meaning 2 HDMI ports, or one HDMI and one DVI/DisplayPort/etc.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    2001 Kawasaki ZRX1200R
    2000 Honda CBR929RR
    https://www.amazon.com/Adapter-Multi...a-669794096556
    USB3 display adapter, HDMI out. Done. Stop playing with splitters.
    Apr 2004
    Wilmington, MA
    I'm an idiot.. for some reason i was looking at the USB 3 dapter kurlon is linking to and ordered this splitter by accident
    Not sure if My wife has USB 3 I looked under usb serial bus controller in the device manager and only saw usb root hub (USB 3.0) I "think" that means she has it.
    No blue output or marking on her USB output or SS next to the usb design
    if she has USB 3.0 then Kurlons link is what I need
    or for my wife to steal a docking station from work
    hmmmm......
    If your laptop doesn't have USB3 it's a true antique, but that adapter will work on USB2 and USB1.1 as well you just get slower video out of it.
    USB C is NOT USB 3.
    -Clayton
    2006 Suzuki SV650
    2000 Honda CBR929RR
    Apr 2004
    Wilmington, MA
    USB C is NOT USB 3.
    corrected... typo
    hmmmm......
    Lifer loudbeard's Avatar
    To piggyback on this...
    I run a single 32" LCD monitor..err...TV. I have this "oddball extra wide resolution" where it stretches the screen width-wise. I've done some Googling about it and haven't really come up with a solution, might you have one?
    What model TV is it, and what resolution is your machine defaulting to on it? I've seen 4k sets that claim to be 4096 x 2160 when their native res is 3840 x 2160 resulting in a squished image, but a quick change in OS settings to 3840 cleans it up. Almost all sets these days will go 1:1 pixel mapping when fed native res too which is a nice improvement from the bad old days when TVs assumed EVERYTHING needed scaling and post processing... blech.
    Nov 2009
    Bristol County
    Isn't that a 16:10 versus 16:9 aspect ratio problem?
    02 Aprilia Futura
    86 GPz900R
    Nothing fancy. It's a Vizio (actually 39") D-LED, 120 Hz, 1920x1080 maximum resolution, 1080p. In the Control Panel I have screen resolution set to 1280x1024, which is the highest available.
    Set it to 1280x720 instead.
    Apr 2004
    Wilmington, MA
    Soo purchased the multimonitor USB-3 cnnection.. on my new Thinkad X1 carbon laptop from work ( where I have 3 monitors ( 1 of which is my built in disply)
    I cant get multi displays.. clone / mirror or otherwose. my laptp doesnt even recognize them
    ughh
    any other ideas? I used the 2 HDMI into the deivce with 1 HDMI coming to my laptop, displays are on. etc..
    hmmmm......
    If you got that USB powered HDMI splitter, it will not show up as two displays.
    If you got the USB display adapter, and it doesn't work after installing the drivers, you've got something with your laptop blocking it.
