Results 51 to 75 of 86
Legal Advice: Basement Leaking in Recently Purchased House
  1. #51
    Re: Legal Advice: Basement Leaking in Recently Purchased House
    Are you swimming in the basement yet. Benn pouring here for like 20 hours
    Mar 2004
    Salem, MA
    FLEX SEAL! I heard you can shoot holes in a boat with a cannon and shit...
    Johnny
    Its an Italian bike...Ive had (have?) a few
  3. #53
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    My guess is he has been at work...
    Carla is probably having a blast down there.
    San Francisco
    Sump pump was still going strong this AM. A friend of mine is staying with me and says it's still going now too. I actually got up at 5 this morning with big plans to go to Home Depot and get another pump to replace the old ass one there. Then I remember I didn't get home til midnight the night before and went back to sleep. I live quite the exciting life if you couldn't tell.
  5. #55
    Lifer SteveM's Avatar
    Aug 2009
    Norwell, MA
    You beat me to it!
    I was going to suggest the tape!!!
    Mar 2004
    Salem, MA
    You beat me to it!
    Im surprised nobody had mentioned it yet....it is page 3!
    Johnny
  7. #57
    Lifer Falko's Avatar
    MoonTown
    As I mentioned earlier, my basement is a sieve. I've tried hydraulic cement, drylock paint, silicon caulking, etc. The water will just find its way in. While I live on a hill, my lot is flat enough that I cannot get the right pitch to run below foundation drainage. I'm seriously considering digging and exterior trench (french drain like) and installing a pit with pump outside. But the amount of water I would get would be astronomical and the power bill would be hideous. Water issues in NE can be an absolute bitch.
  8. #58
    Considering the stuggle I dealt with at my house, I learned that all you can do is divert water. There is no other solution...catch and divert.
    In other news, my pump has come on more often in the last two days than in the last 2 years when it was installed.
    This is gold! There is not a single product available that will stop the water if applied to the inside. It's one thing to stop dampness coming from the foundation on the inside, but you will never stop water infiltration.
    You need to deal with it from the outside, and under the floor slab. I have a 195 year old farm house with a field stone foundation, every time it rains, the walls are soaked. Gutters will reduce that water drastically in my case once I install them, but I also made a moat around the perimeter walls for the water to flow to a drain. I have a pump just in case, but so far, the water soaks into the ground before building up.
    A Big Powerful Sportbike
  10. #60
    I suppose I better hook the hose back up to my sump pump, haven't need it for a few years but maybe when the ground thaws this time I will!
  11. #61
    MoonTown
    1.5" of water Thurs into Friday will be giving the pumps a workout.
  12. #62
    When I bought my house, it has a dirt flood in the basement, native dirt, level or nearly level with the bottom of the footings, foundation is cement block with plenty of cracks and places for water to infiltrate. well above any water table, never saw a drop of water till I poured a concrete floor and made part of it living space with a carpet........ then it rained the the winter, any water that previously infiltrated the walls, immediately soaked thru the dirt floor. I had slopes that directed runoff directly to my foundation. The next summer, I did some serious excavation to correct that problem, and it seemed to have gone, till I built my barn and ran a waterline and conduit for phone & network cables. Started seeing water come in from the trench are of disturbed earth that was acting like a wick, but as nature has slowly compacted the earth in that trench, the problem has gone away.
  13. #63
    San Francisco
    Radio tells me torrential downpours tonight, oh boy!
    Considering taking out stairs and replacing with slide.
  14. #64
    MoonTown
    I did a diving board, more fun. Just watch out for the boiler, shallow there...
  15. #65
    My BIL live in a house on the side of a hill near Stowe, VT that had major water-in-basement problems.
    He eventually excavated from above the house around both sides, with drains below the house. A lot of work, but it was effective and he got his money back when they sold.
    “When it comes to the kitchen, I have a narrow band of competency.”
    Master Mechanic Roger Barr in “Chasing Classic Cars.”
  16. #66
    Seacoast NH
    Quote Originally Posted by Bonk! View Post
    You should also get a battery back-up for your pump, in case power goes out in a storm.
    Can anyone tell me about these. What could/should we be looking for in a backup for this?
    I also have a wet basement in my world.. although, fortunately not mine. Home has french drains around the perimeter of the basement and a sump pump. After the recent rains this AM she found one of the basement walls "peeing" onto the slab. Sounds non-critical as the pump is keeping up and the basement is actually draining. So.. that's good. I guess.
    This weekend we are going to arm her with a backup pump. I have no experience with sump pumps myself. My plan is to look at the existing pump tonight and simply try to match or exceed specs.
    I'd also really love to give her some more peace of mind with some sort of battery backup for the pump. It cycles A LOT! I think it may be running on the order of 2x per minute. She has a generator.. but that's obviously useless if she's away at work or something when the power fails. This is a rural home where power failures are a real concern. With the pump running this frequently I'm thinking the battery system may be worth the investment.
    WTF am I looking for/at here?
  17. #67
    Calculate out running load of the pump vs how much battery you'd need to run for 10 minutes. You might decide against battery backups for this application afterwards.
    Battery backups are EXPENSIVE if you want it to run for any length of time.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Safe to assume she's also on a well?
    If not, as a backup, these are nice... http://www.zoellerpumps.com/en-ap/pr...home-guard-max No electricity required.
    As Clayton says, it's just math to figure out what you need if you want to put a UPS on the pump that's there.
    I've also heard of a lot of people putting in a backup 12V pump, connected to a deep cycle battery that's just always on a trickle charger. Something like 017198 - Zoeller 017198, 12V DC Backup Pump Only With Terminals For Basement Sentry I Backup Sump Pump Systems - Pump Products
    Backup pump is set "higher" than the AC one, so it only comes on when the AC one fails.
    Ashford, CT
    Like Randy said, tell her to get a REAL backup generator that does everything. The type that starts itself up and switches itself over to run the whole house. If she's got natural gas on the street, hook to it, if not, get propane and get on automatic delivery. Last thing you want is to be gone for a few days in a rain storm and lose power without knowing. And the generator will be a heck of a lot more useful when she loses power even if a sump pump isn't required at the time.
    Jeff
  20. #70
    Seacoast NH
    Rural home. No natural gas. Private 220V well.
    Standby generator would be cost prohibitive. Although I can see where that would be considered the "right" solution. That seems a lot less likely to happen though.
    Looks like the 12VDC backup pump systems run about $500 all in. Advertising about 10-12 hours of continuous use.. or 24+ if cycling. That seems pretty reasonable to me.
    Although at this point she's telling me she'll just not put anything on the floor in the basement and cross her fingers.
    I93/495
    Starting a sump pump is a pretty big spike in draw isn't it? Cycling time on a battery might not be as long as you think.
    2012 Tiger 800 XC
  22. #72
    The backup pumps are usually quite a bit smaller than the main pump and the backup systems use deep cycle marine-type batteries. Probably enough power to get through a day or two of cycling but likely not much more than that.
    Seacoast NH
    Starting a sump pump is a pretty big spike in draw isn't it? Cycling time on a battery might not be as long as advertised.
    We saying those things lie? False advertising?
    Seacoast NH
    That's exactly what they are claiming. There's also an audible alarm reminding you to get the genny out and get off of backup.
    I agree the pumps look light duty. I wouldn't expect it hold up long as a primary duty pump.
    Right now I think I'm inclined to pull the plug on her pump and see how bad it gets after an hour or two. Maybe this is a problem not even worth fixing.
    Lifer loudbeard's Avatar
    Single phase motors use capacitors to mitigate inrush current, a standard inverse time breaker is sized at 250% of the full load current per NEC 430.52. If it's an instantaneous trip breaker, they are sized to 800% so there is a potential to see that amount of spike on a single phase motor, but inrush only occurs for a few hundred milliseconds. Repeated stopping and starting can definitely hurt you, I'd recommend using a 2 float system to establish a zone of control rather than a single float which can cause a motor to chatter.
