Page 13 of 13 FirstFirst ... 345678910111213
Results 301 to 313 of 313
Midsize SUV Shopping/Research
  1. #301
    South Coast MAsshole
    Re: Midsize SUV Shopping/Research
    dealer called yesterday and told us it would be in on the 13th and that they would be in touch soon...i ordered smart liner mats and toughpro cargo mat on amazon (car doesn't come with mats)...i should have them before the car is here...i'm waiting to order oil change parts and a wireless carplay adapter until we get the car and run it a bit...can't think of anything else i need at this point...maybe a cell phone holder but i would wait on that cause carplay may make it unnecessary
    Point37s Garage Sale Thread
  2. #302
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    If you have carplay coming into the head unit, then you really dont need a phone holder, as the cars display will show you all the info you need to know, the last 3 cars ive had with car play and we just toss the phone in the cupholder.
    Quote Originally Posted by jhawley View Post
    I guess it’s CarPlay capable if you plug the phone into the usb port in front of the cup holder...if you want wireless, it needs an adapter plugged into that port...I’ll probably get the adapter...she can keep her phone in her bag that way or like you said put it in the cup holder or the wireless charge pad in front of the cup holders
    This car has way too many bells and whistles for me...too much electronics to learn...I hope they are intuitive and all work fine for the life of the car...I bet there is a manual just for the infotainment system
  4. #304
    The OEM infotainment systems seem pretty lame. The Ford Edge we rented had very limited display options and app support.
    My 2005 Outback has a KENWOOD DNX996XR, which was about $1,000 2-3 years ago. Has wired and wireless CarPlay, Garmin GPS, DVD, backup camera, steering wheel controls, touch screen, etc., etc.
    https://www.kenwood.com/usa/car/excelon/dnx996xr/
    ďWhen it comes to the kitchen, I have a narrow band of competency.Ē
    Master Mechanic Roger Barr in ďChasing Classic Cars.Ē
  5. #305
    that's a pretty nice setup...coming from not having an infotainment system to now having one i'm sure the oem one will suffice...going to spend enough on the car...only getting stuff that i feel are must haves for efficiency/safety/convenience...i figure if it can handle gps apps, phone calls, music and podcasts then we are good...
    so much to learn...
    https://www.kiatechinfo.com/ext_If/k...ntent_pop.aspx
  6. #306
    8/27
    the check engine light came on in the grand marquis...plugged in the code reader...misfire in cylinder 1...consulted the internet to diagnose (link below)...went to autozone and picked up a new spark plug...gapped and replaced spark plug in cylinder 1 and swapped coil pack from cylinder 1 with cylinder 2...erased the code...if the code comes back on cylinder 1 I know itís not the spark plug or the coil pack...if it comes back on cylinder 2 I know itís the coil pack
    9/8
    Drove it since 8/27 and noticed itís still misfiring so just waiting for check engine light to come back on...comes back on today...plugged in the code reader...misfire on cylinder 2...so I ordered a new coil pack...should be back in action by early next week...hopefully Iím right and hopefully we have the new car by then
    https://www.700r4transmissionhq.com/...grand-marquis/
  7. #307
    Lifer JohnnyV's Avatar
    Westborough, MA
    8/27
    the check engine light came on in the grand marquis...plugged in the code reader...misfire in cylinder 1...consulted the internet to diagnose (link below)...went to autozone and picked up a new spark plug...gapped and replaced spark plug in cylinder 1 and swapped coil pack from cylinder 1 with cylinder 2...erased the code...if the code comes back on cylinder 1 I know it’s not the spark plug or the coil pack...if it comes back on cylinder 2 I know it’s the coil pack
    9/8
    Drove it since 8/27 and noticed it’s still misfiring so just waiting for check engine light to come back on...comes back on today...plugged in the code reader...misfire on cylinder 2...so I ordered a new coil pack...should be back in action by early next week...hopefully I’m right and hopefully we have the new car by then
    Just because the CEL doesn't come on, that doesn't mean there aren't codes being generated. If you feel it misfiring you can scan it and pull the miss code, or dependent on your code reader you can leave it plugged in and monitor real-time.
    Good to know...thanks...I thought the light had to come on for a code to be read
  9. #309
    (4) Try not to be a dick. PurplePackage's Avatar
    Oct 2020
    Chelmsford, MA
    you can swap coil packs around to verify one went bad. it will throw a different code. same for injectors and spark plugs. also can do a compression check while the plug is out.
    Thanks...Thatís what I did...but I put a new spark plug at the same time since itís a cheap part and I didnít want to pull cylinder 2 spark plug if I didnít have to...the less I have to touch the less of a chance that something goes wrong...just want to get it squared away and ready to sell soon since the new car will be coming home this week
  11. #311
    oh ffs...the ford modular
    replace all the coil packs (cheapo amazon packs are fine...buy spare), plugs if you're very careful (be wary of stripped threads needing a re-tap & heli coil using the kits out there...if none strip out, be sure not to over torque them)...replace the PCV w' a motorcraft & clean the IAC/replace it if you have high idle and clean the MAF sensor using a MAF sensor cleaner spray from autozone. "modular maintenance" You can fit 35's without rubbing if you...oh wait, wrong group.
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2017 KTM 690 Enduro R**
  12. #312
    i was going to replace all the spark plugs but i decided the less i touch the less chance i screw something up...we plan to sell the grand marquis once the new car is home...the new car should be home tomorrow so "the boat" will be going up for sale shortly...it is a little rough starting (which is why i was going to replace all the plugs) but other than that and the misfire which should be fixed tonight once the new coil pack comes in today it runs pretty well for it's age...not sure what we should ask for it...i will have to consult KBB, CL and marketplace
    Midsize SUV Shopping/Research-1-jpg
    Midsize SUV Shopping/Research-2-jpg
    Midsize SUV Shopping/Research-3-jpg
  13. #313
    heading up to pick up the car today...i'm sure there will be lots of electronics questions
