Page 2 of 2 FirstFirst 12
Results 26 to 49 of 49
High mileage oil - worth it or marketing scam?
    Raymond NH
    Re: High mileage oil - worth it or marketing scam?
    Pitch an oil analysis from a place like Blackstone Labs.
    Through their services, you could well end up extending oil change intervals with scientific proof backing it.
    My dad did that in the late 80s and early 90s with a 1986 Corolla sedan. He ended up getting 340,000 miles of mixed use out of it with oil/filter changes at roughly 12-13k using normal oil. Still ran reliably and without smoking when he sold it with 340k on the clock, but was noticeably less powerful than it was when new.
    0 Not allowed!
    We’ve used oil analysis for years. If an engine is going South it will often give advance warning.
    Interesting. My 09 legacy 2.5i is also rather loud on startup. Is this something to be concerned about?
    Don’t think so, it was 90’s car we had. As mentioned, make sure the oil level is up. Subaru 2.5’s only have something like 4.5 qt capacity, while the H6’s hold 6 qts or more and come stock with a oil cooler.
    You might try the Castrol High Mileage. If it was only a viscosity effect, they’d be rated differently. It worked for us, cheap experiment. If it’s only a seal enhancer that’s different, don’t know what I’d try: our engine didn’t leak oil.
    0 Not allowed!
    1975 BMW R90/6 | 2008 Triumph Tiger 1050 ABS | 2009 Honda CRF100F | 2009 Yamaha TrailWay 200 | 2012 Yamaha WR250R | 2016 Honda CB500FA | 2016 Suzuki GSX-R750
    Senior Member capitalcrew's Avatar
    Feb 2017
    Albany NY
    I've heard the long life oil has different additives to maintain viscosity and other properties longer. The last oil change in my wife's car I used the 15k mile oil and plan to change it at 10k. I just changed the oil in my truck this weekend at 6k (regular Castrol synthetic) and it was still transparent, dark but not that black you typically get. I also did the obligatory transfer case and differentials on both vehicles this weekend as well, only the 90k mile rear differential showed dirty fluid. Everything else looked new dumping out and I was 15k over on my truck for those services.
    I just did the 10k interval with the 15k mile oil for the first time. It came out better than my last oil change, but not as good as I would like to see. I'm still using the 15k mile oil, but I'll be changing it around 7500 this time I think. I use an ACDelco filter.
    0 Not allowed!
    Automotive Engine Oil Filter Study
    Motorcycle Oil Filter Cross Reference
    We try to use Purolater Pure One filters, have to check cross reference to see if they work on bikes.
    0 Not allowed!
    in an older vehicle, I would suspect oil that does not get "dark" That darkness, is visual evidence the oil is doing it's job, keeping contaminants in suspension especially soot blowing past rings and valve seals, rather than let it coat your metal parts with sludge
    0 Not allowed!
    Lifer Falko's Avatar
    MoonTown
    That was a 45k mile Toyota.
    I do wonder though how much of the "dark" then should the filter remove?
    0 Not allowed!
    I93/495
    Color isn't really a good indication of oil condition. Simply look at a diesel. You can change the oil and a few hundred miles later it's black as can be. That doesn't mean the oil isn't serviceable for thousands and thousands of miles more.
    The oil in my Camry is pretty "dark" right now at 7k. The last time I had it analyzed in the 9k range the comment was that it was that I could extend it a few thousand miles before sampling again.
    0 Not allowed!
    2012 Tiger 800, 2007 DR650, 2012 WR250R
    Oil analysis performed in a laboratory is the only way.
    Color of oil is not directly indicative of anything other than the engine has been run.
    0 Not allowed!
    Feb 2017
    Albany NY
    So would Blackstone's standard test tell you how much life is left in the oil?
    0 Not allowed!
    I93/495
    Quote Originally Posted by capitalcrew View Post
    No. A key component to that equation is knowing the TBN.
    0 Not allowed!
    Blackstone does indeed test for TBN at the customer's request so, Mark, the answer is "yes".
    Call Blackstone and speak with their tech team. They seem to be fairly passionate about what they do.
    0 Not allowed!
    I93/495
    Yes, but not that's not their standard test. It's $10 extra.
    1 Not allowed!
    My mistake. I missed the word "standard". Indeed the answer is "no".
    Carry on.
    1 Not allowed!
    Lifer tsorfas's Avatar
    Sep 2011
    in my own little world...
    I i my see the standard test on their website
    0 Not allowed!
    New tundras include oil change in first couple years of warranty, don't they? Now they don't have to change it as much. Same reason the fuel light comes on with like 4-5 gallons left in the tank. Free roadside assistance.
    I think it's weird the transmissions are "non-servicable".
    "non-serviceable"? I'd like to see what magic transmission fluid they are using that never breaks down or gets contaminated. I think what they mean is non-serviceable until the warranty expires.
    0 Not allowed!
    Sep 2011
    Quote Originally Posted by The Architect View Post
    Many companies are claiming that you don’t need to change the transition fluid any more. But of course they are smart with the wording “good for the life of the transmission” yeah so when that shit fails it’s the tranny that failed and the fluid lasted a second long as the tranny did right? Lol. F that. Zoom Zoom get it replaced every 70-80k
    0 Not allowed!
    MoonTown
    There are sensors to tell you if the fluid level gets the slightest bit low, I'm told. They recommend changing every 100k, so it's not like it isn't a sealed unit that isn't serviceable. You can have it serviced or do it yourself pretty easily. I plan to do mine in the next 20k miles or so. My wife's truck I just do a 3qt dump and fill every oil change. That keeps it looking fresh without having to do a full 12qt flush or whatever it takes.
    I just picked up a low mileage Lexus IS for scooting around vs the truck. I'm going to give it a good once over on fluids. It only has 40k miles but is 10 years old, so I think I want to do fluid changes all around.
    0 Not allowed!
    What is the over-under on this thread? Think it dies out in December, or makes it through the winter?
    0 Not allowed!
    MoonTown
    Oil discussions never die, they just get moved to new threads...
    2 Not allowed!
    I93/495
    It will have some legs. No one has even mentioned Rotella yet.
    0 Not allowed!
  21. #46
    Feb 2017
    Albany NY
    Welp. There goes the neighborhood.
    I still have the oil from my last change sitting in a bucket in the shop. Maybe I'll send a bit of that in. Not sure how much oil residue was in it from the last oil change though. Wonder how much that'll matter.
    0 Not allowed!
  22. #47
    High mileage oil - worth it or marketing scam?-vintage-1-quart-arco-graphite
    0 Not allowed!
  23. #48
    Bought two gallons last night!
    Bought 14 quarts of the Castrol Synthetic motorcycle oil . Had a bunch of discounts but it was still $100 purchase. Had four bikes to change in NH.
    Left Boston 8:30pm. Forgot th3 oil..... Bought Rotella T6 to change the dirt bikes. $20 a gallon at Hooksett WalMart.
    0 Not allowed!
  24. #49
    Lifer golden chicken's Avatar
    Boxborough, MA
    They mean you need special tools to do the job properly. Long gone are the days of simple drain and fill plugs or dipstick tubes.
    0 Not allowed!
