Results 1 to 14 of 14
Moving a truck with no fluid in rear differential?
    Why am I still here?
    I need to pull the rear axles on my van. I don't think I have enough space in my driveway to do both sides at the same time. Will I regret turning the van around in my driveway with an empty rear differential case so as to do one side at a time?
    Re: Moving a truck with no fluid in rear differential?
    Nah. Plenty of residual oil for the move. Just don't go buy a case of beer while "turning it around".
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    TWINS! xrocket21's Avatar
    Central Maine
    Id feel fine just turning it around :o
    Seacoast NH
    Why are you pulling axles?!
    As posted about many months ago, the backing plates for the parking brake shoes are rotted out. There are aftermarket 2-piece backing plates that make this a 15 minute job... available for every truck/van on the market EXCEPT mine. So the axles must come out. I had finally resolved to have a shop do it until talking to my brother the other day. He convinced me that I was being a puss.
    buy another van
    I had an axle swapped between 2 identical pickup trucks...was more expensive than it's worth on an '01 F150...but I had a rare 7 lug 10.25" rear end and now I have limited slip
    1994 Yamaha YZ250 CA Street Legal 2-smoke :smoke: ** 2017 KTM 690 Enduro R**
    xxaarraa
    Guest
    Are you putting Rotella back in?
    Depends on how many burnouts you do in the process.
    “When it comes to the kitchen, I have a narrow band of competency.”
    Master Mechanic Roger Barr in “Chasing Classic Cars.”
    Lifer Falko's Avatar
    MoonTown
    Just run some Slick50 in there for a few miles before you drain it.
    No, Amsoil.
    In other news, I'm an Amsoil dealer.
    -Clayton
    2006 Suzuki SV650
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    As long as the van is mounted with snow tires you will be fine.
    Are you putting the van in the truck? I'm confused.
    Lifer bryco13's Avatar
    Oxford, MA
    While it's up on jacks, it'll be a perfect time to register it as an off road vehicle.
    Miles? Pics? Title?
