Results 1 to 3 of 3
Parasitic Battery Test
    Posting Freak
    Oct 2007
    Milton, MA
    I've got something that is a slow drain on my truck's battery. Day-to-day it's fine, but if it sits for 4 or 5 days the battery is dead. The battery itself, and the alternator, checked out fine. Is there a way to do this test without taking it to the dealer?
    0 Not allowed!
    Senior Member cdseven95's Avatar
    Re: Parasitic Battery Test
    open hood, shut door, unplug hood light if it has one.
    unbolt neg battery terminal put one probe of meter on wire, one of neg post.
    put meter on amps.
    lock door with remote if you have one.
    wait a couple minutes to see if you get a amp draw in range of what is specified for your truck
    1 Not allowed!
    Just went through this with the Triumph. They checked across each fuse. Eventually determined the grip heater relay was always on.
    An example.
    1 Not allowed!
