Results 1 to 6 of 6
Plow repair?
    Plow repair?
    I just bought an older ATV with a plow and am slowly going through it. Wiring issues, I can sort, light plumbing fixes, etc. Got it mostly there but I do see one issue that exceeds my capabilities - The plow itself. The wear edge bar has been on too long and the plow itself is getting worn. I can flip the bar to get more life out of it, but I suspect one or more of the bolt holes in the plow may be open. Anyone had this type of damage repaired before and know ballpark costs?
    771 Racing -=- FaceBook
    Mistake - 1992 WR250ZD / 2000 LS650P / 2019 KTM 150SX / 2016 KTM 250XC
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Plow repair?
    I don't know exactly what you need, but if it requires a bit of steel to be melted into a hole and then threaded I might be able to help.
    Re: Plow repair?
    Or find a big washer and just weld it on where the hole used to be. Don't overspend on something cheap like a plow. They aren't much gnu.
    Hell, just bolt on the new edge and skip that hole.
    -Clayton
    2006 Suzuki SV650
    2004 Suzuki Vstrom 650
    Re: Plow repair?
    Makes sense, one of these days I'll learn to weld...
    Mar 2012
    Chichester, NH
    Re: Plow repair?
    Welding is easy. Welding well is a completely different matter.
    I can weld.
    I can grind better than I can weld.
    5 Not allowed! Not allowed!
    Re: Plow repair?
    For this porpoise, welding bad will do just fine.
    Blowhole.
    -Clayton
    2006 Suzuki SV650
