Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Pneumatic impact wrench question
    Feb 2008
    Rhody
    So I grabbed one of the Harbor Freight impact wrenches, FWIW it's the compact EARTHQUAKE XT
    Anyway, the thing can't loosen a lug nut, with a claimed 700ft/lbs of torque shouldn't lug nuts be a breeze? Maybe it's my compressor that's the weak link, Craftsman 1HP, 12,gal, 125psi max.
    Thoughts?
    Hyper
    Permanent N00b -Dutch-'s Avatar
    Feb 2014
    Pawtucket, RI
    Re: Pneumatic impact wrench question
    Step on a breaker bar.
    Feb 2008
    Rhody
    Quote Originally Posted by -Dutch- View Post
    Dude, I'm wicked strong, don't even need a breaker bar, I just want the convenience of zipping them off with an impact gun.
    Hyper
    Feb 2014
    Pawtucket, RI
    Lifer zxme's Avatar
    Mar 2007
    Mass
    125 maybe but do you have a gauge on it? also change air fitting to bigger size, helps a ton
    My Fav impact is this one-->20V Max Lithium 1/2 in. Cordless Xtreme Torque Impact Wrench Kit
    1/2 in. Composite Xtreme Torque Air Impact Wrench
    And only Air I like from them^^^
    Feb 2014
    Pawtucket, RI
    Damn, 1200 ft/lbs on a cordless? I've been pretty happy with my 300 ft/lb Ryobi all this time.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Air flow is key. If you can't deliver enough volume of air you won't make any power. You need a 3/8" hose and preferably a bigger than normal disconnect
    bigger impact, Ingersoll Rand 1350 ft lb.........or a breaker bar and a length of pipe
    by chance are you tryin to remove a left hand thread lug nut from an old Mopar
    Feb 2008
    Rhody
    Quote Originally Posted by zxme View Post
    It does have a gauge on it, and the tool says 90psi max, which I'm keeping it at. I'll check out the fittings. And that Harbor Freight wrench you linked, this is the same exact one but just the "compact" version, 700ft/lbs of torque instead of ~1100.
    LOL
    Hyper
    Feb 2008
    Rhody
    As already stated, not a strength issue, MY BICEPS ARE HUUUUUUGE, and not a stupid idiot thing, lefty loosey on the Bimmer. But in a seriousness, I am suspecting that this particular wrench just can't hack it and I gotta step up.
    I have a 3/8" hose, gotta check on the fittings though.
    Hyper
    Feb 2014
    Pawtucket, RI
    Be honest. How many wheel studs have you snapped while finger-tightening? Also, please don't steal my girl.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Is it skookum? You decide...
    Nov 2009
    Bristol County
    He does one on the air gun version too which is probably more relevant. And if I remember right, his conclusion is that it is decent. And I thought in general, the Earthquake has a good reputation with the DIY crowd.
    *Anyone who is new to his videos, he has a very critical eye and a bit of snobbery-standards that appear to come from being used to commercial-grade gear. Basically, he prefers quality as a matter of principle more than practicality.
    nedirtriders.com
    bimmer......lug bolts ?
    I remember once, a VW Vanagon lug bolts in front, studs & lug nuts in the rear iirc (may have been vice vesa) I was just changing my winter tires over with my 4 way, a couple of stubborn ones I had to get out my breaker bar, till I found one, it was a bolt, had it been a nut, I could have applied heat more effectively, anyhow, didn't break the lug bolt, I broke the breaker bar. (that it another whole story) Later in the day, I met with a client on other business, small talk brought us to my lug bolt predicament, he invited me down to spin it off one way or the other with one of his 1" drive impacts, it spun it out like it was just put on finger tight, I was really afraid it was going to twist it off
    Mar 2012
    Chichester, NH
    Thanks. Quick mobile search got me the wrong one.
    He's a bit abrasive at first, but is actually quite knowledgeable with a very unique style.
    Lifer golden chicken's Avatar
    Fitchburg, MA
    Set your compressor up so it delivers 90 psi while your gun is running, not static.
    Mar 2012
    Chichester, NH
    And ideally 90 psi at the working end, not at the compressor.
    Feb 2008
    Rhody
    Hmm, ok, I'll give that a try.
    And no more girls, please, a wife, ex-wife and three daughters is enough!
    Hyper
    Feb 2014
    Pawtucket, RI
    I showed my girl this thread and now she wants your number. You're screwed.
    Feb 2008
    Rhody
    Pics?
    Hyper
    I have the earthquake xt. Loosens up lug nuts at the lowest power sitting. Sounds like your compressor sucks. Gun doesn't work until there's over 90psi.
    Feb 2014
    Pawtucket, RI
    Pics?
    Best date ever.
    Lifer Falko's Avatar
    MoonTown
    I've found the regulators on cheaper compressors are a huge pinch point. Your tank gets charged to the on/off pressure the compressor cycles to, then the regulator goes directly to the hose. Most of those regulators are small and do not flow as much as a lot of air tools require.
    I have 2 BMW's and the same issue.......the XT can't blow off the studs FML
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    Hah, you remember correctly Bolts in the front on 2wd vanagons, the front brake rotors are also the wheel hub. The rears are nuts on 2wd. Syncro 4wd vans have nuts on all 4 corners. I haven't broken a breaker bar on the lug nuts/bolts but have broken two on the rear axle nut. Which is why I bought a decent 3/4 impact that fucker is torqued to 360 ft/lbs.
