Results 1 to 11 of 11
Any pointers for applying Fluid Film?
    rides bikes
    Nov 2014
    Never messed with the stuff, so looking for tips and tricks.
    I have a 2008 Tundra that I bought about a year ago from upstate NY. It's really clean for its age (hence why I bought it), but it's lived 10 years in the Northeast, so it's got some spots. I think/hope this will be the last truck I buy for a long time, so I want to help it last. My plan was to throw it up on jack stands and pull all four wheels. I was going to do a lap around the frame with a wire brush and black primer for the flaky spots, and another lap with the Fluid Film. Seems straightforward enough - just spray it everywhere, right? Assuming I should avoid the brakes and exhaust and try hit everything else? Frame, rockers, fuel/brake lines, springs, hardware, brackets....all fair game? Any special precautions? Can I get this stuff on my lawn, driveway, clothes? What else should I be spraying while I've got it all set up?
    The only tip I've heard is to warm it up a little before spraying it to help it flow better.
    I'll probably do this in the next week or two. If it goes well, I'll also do my wife's car. Maybe not...that's her problem.
    Lifer Falko's Avatar
    MoonTown
    Re: Any pointers for applying Fluid Film?
    It's all natural, or at least not so toxic, so spraying it on shouldn't be a worry.
    As for painting rust before spraying it on, I wouldn't. The paint will just block the FF from getting into the rust where it will help stop it. The paint will just flake off the rust and take the FF with it. You can spray everything with it except brake pads and rotors. You can spray the battery terminals, keep it off the radiator, limit exposure on exhaust it stinks.
    Raymond NH
    Sounds like you got it. I buy it in gallon cans and have used a pressure feed gun to spray it in the past. I'm going to try an old Wagner power painter this year, I hear they are better for applying FF. It's pretty harmless stuff, but I'd put down a tarp is spraying over pavement. I doubt it'll harm grass, but I'd tarp my grass too, just in case. When I spray it, I also pull any rubber/plastic plugs and spray it in any crevice I can reach. Buy a rattle can or two and use the skinny red tube for really tight areas.
    Haverhill, MA
    I may be mistaken but don't the Toyota frames typically rust from the inside out? If so make sure you can spray the insides of the frame rails and anything else that may rust inside out. Try not to plug any drain holes with excess material or material mixed with dirt etc. to make a sludge.
    rides bikes
    Nov 2014
    Yeah I believe they do. I think mine is boxed at the front (forward of the firewall) and C from there back. Even at the front there are plenty of access holes in it.
    We use Boeshield under the hood and on Bikes, snow throwers, etc.
    Boeshield T-9(R) | Corrosion Protection and Waterproof Lubrication
    “When it comes to the kitchen, I have a narrow band of competency.”
    Master Mechanic Roger Barr in “Chasing Classic Cars.”
    MoonTown
    I expect Boeshield is much better than Fluid Film given is over 2X the cost.
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    If you plan on painting anything dont get fluid film on it....
    Jun 2016
    Exeter, RI
    I buy it by the gallon and apply it with a Wagner power sprayer, no thinning or warming up required. I go under the truck and blast it everywhere.
    Seacoast NH
    Quote Originally Posted by ADA929 View Post
    Interesting.. I happen to have a wagner power sprayer.. which is unilaterally useless for spraying paint. (Ask me how I know.)
    I also have an expensive as sin truck that I'd like to see not rust.
    It's different stuff, in my opinion more durable.
    We also use Birchwood Casey Sheath, a gun product that provides a thin protective oil coat that doesn't evaporate or run.
    People swear by CorrosionX and Compound L but I have never used them.
