View Poll Results: You can access a server locally to retrieve an image file w.o. requiring a "network"
Voters
5. You may not vote on this poll
  • True
    2 40.00%
  • True, with conditions
    0 0%
  • False
    2 40.00%
  • False, and here's why
    1 20.00%
Results 1 to 22 of 22
Question for the Computer Geeks
    Oct 2001
    Bedford, MA
    Yes...
    You can configure a loopback interface and almost all server software will happily use it.
    (And actually almost every computer/operating system configures this by default, just run your software against "localhost"/127.0.0.1 and it should work)
    Everybody to the limit!
    Winchester, MA
    Not a big fan of macros, but this one always makes me think of the squid
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    false and here is why...
    Nice way to make a broad statement Joe...
    You started this crap on another site now you bring it here...whats teh matter you tech docs. did not have the info you needed?
    Ok..a server DOES NOT STORE DATA..ok
    You should be proud of my arguement...as it is your style to the T...
    A stand alone sever does not have data stored on to it....so there for in order to access the data that the server has stored to disk, you need to have some sort of a network...
    I network is defined as one computer(or as you posted inyour other threads...hardware) communicating with another...
    In a small infrastructure you many have disks built in(JBOD) if this is the case the SCSI buswhatever protocol is being utilized) IS the network..in which the processor of the server communicates to the disks to read and write the data... Thus a network...also in this network is your input and output devices...
    Ok now in a infrastructure the server communicated to an external storage device either by being directly attached or by a SAN(storage area NETWORK). In either case you have a network...whether is is attached through SCSI cables, fibre, ficon or escon...there needs to be a configuration in place in order to make them communicatie..thus a network....
    Manvile, RI
    Originally posted by benVFR
    Yes...
    this by definition is also a network...
    A loopback interface is using the serves internal network...
    Winchester, MA
    This is even more serious than I realized.
    Bravo, you two. The fate of the interweb hangs in the balance. Only you can save us now.
    God Cam_In_IL's Avatar
    Dec 2003
    Chicago
    This is a vague question. Where are you trying to access the information from - the same server? If you are trying to access it from a different machine it would need some sort of network.
    Be more specific...
    Yup.
    Littering and........
    Jul 2004
    Vermont
    You're all fuckin wrong.
    Here's what you do: You connect your johnson rod to the main female receptor. Then, you insert your interface into said receptor at a vigorous rate until the receptor acknowledges this connection with a loud data transfer. Then, you remove the johnson rod and download all over the receptor's hard drive.
    Christ, I have do EVERYTHING around here.
    Oct 2004
    Southeastern Taxachusetts
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
    Oct 2001
    Bedford, MA
    Big Red,
    Mystery Squid is right as per his original definition of a network as multiple distinct computers.
    I think you are really reaching with saying a "server" does not contain data and then trying to call a machine & it's SCSI drive as a network. A SCSI drive & controller is not a computer system that can function on it's own.
    You are trying to make huge generalizations and then at the same time be super specific.
    You can't make statements like that without being specific about what you're talking about.
    E.x. computer & external SCSI drive - Not a network
    Computer & large enterprise storage system - may or may not be a network
    Computer & Ipod on Firewire - Not a network
    Computer & Ipod on USB - arguably a network
    The loopback device on a TCP/IP stack is really not a network. You are simulating a network completely in software. You don't even need a network interface.
    Manvile, RI
    you would understand my arguement if you were in it from the begining....
    Network, defined as in the most general sense, i.e. more than two pc's, etc
    This was not the original debate....
    Winchester, MA
    He's right you know
    Oct 2001
    Bedford, MA
    I understood him as meaning multiple distinct computers, which is the "general" definition of a network to the non-tech people out there.
    Yes, a collection of objects in memory on my computer that form a neural network could be considered a network, but it sure does not match the consumer definition of a network.
    Network is a very broad term... and Squid's original thing that started this argument was "without using the internet", which implies at least two distinct machines connected via IP.
    Manvile, RI
    thank you...
    Jul 2004
    Vermont
    Originally posted by Mr. E. Squid
    Again, thank you for your expertise on this Ben.
    Red was trying to pull a technical argument on me, as I usually shell out.
    My original statement is in fact, and always was 100% true. Whereas red then decided to pull the "literal definitions" card. Which is fine, but it does in no way make my original argument false. Which, I always knew to be true in the first place.
    You tell 'em, Squidster!!!!!
    Manvile, RI
    Oct 2004
    Usually, I just sit back and shut my mouth....but I can't take this no more.
    stop stop stop stop
    Please make this fucking nonsense stop!! WTF difference does it make. Squid you have taken this too far......three threads on the same topic on another board and now this!!
    Who give a fuck!!
    MSF RiderCoach
    & smells good too.
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    ...and i thought i was a geek. wow.
    i dont know how you did it joe but you managed to bring a political style argument to a geek discussion. i am kinda disappointed.
    Brent LRRS #772
    2006 KTM 560 SMR
    Mar 2002
    Amherst, NH
    oh, I see, it's ALL me now...
    Brent LRRS #772
    2006 KTM 560 SMR
    I have a degree in this exact thing.
    Mr.e, you are wrong, no matter what you say, even if you flip-flop the other way
    -Clayton
    2006 Suzuki SV650
    Manvile, RI
    thank you
    Jul 2004
    Vermont
    All I have to say is:
    Shut your fucking face uncle fucka
    You're a cock sucking ass licking uncle fucka
    You're an uncle fucka, yes its true
    Nobody fucks uncles quite like you
    You're the one that fucked your uncle, uncle fucka
    You dont eat or sleep or mow the lawn,
    You just fuck your uncle all day long
  1. Computer question (Leebo)
    By REDST in forum Off-Topic
    Last Post: 09-29-06, 03:35 PM
  2. Computer question?
    By R7 in forum Off-Topic
    Last Post: 02-14-05, 09:39 PM
  3. Computer virus question....
    By highsider in forum Off-Topic
    Last Post: 01-29-05, 10:47 PM
  4. Star Wars geeks vid.
    By PinHead in forum Off-Topic
    Last Post: 03-30-04, 09:43 AM
