Results 1 to 23 of 23
Remote car starters.
    KB KB's Avatar
    Manchester NH
    Anyone ever done one? I have been checking them out and noticed that you have to disable the stock alarm and basically install the new Alaram/Security system and use the new one that comes with the starter.
    I have 2 vehicles that I want to put them in 1 is my girlfriends Hyundia Accent. 1 is my VW Passat. I've been told that the starters are hard to work with on the VW's and fuck up the engine codes and shit.
    I am good with wiring schematics and think I might be able to put one in. I am just curious if anyone has. Hints? Tips? Tricks?
    Discuss!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Just Registered Doc's Avatar
    Jericho, VT
    Lazy Bastard just go outside and start your ladies car!
    Seriously I have never installed one but can't you get one installed for like $200
    VW wiring has always been their down fall.
    KB KB's Avatar
    Manchester NH
    She knows what's good for her. She starts MY car in the morning.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Just Registered Wishbone's Avatar
    Jul 2006
    If the car has a chipped key you will need to "bury" one in the car
    Littering and........
    Jul 2004
    Vermont
    I tried to have one installed in my Passat, it was about $600 because of all the wiring you have to hack into. Sucks.
    BTW, you're a bitch.
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by highsider View Post
    I'm a bitch but you're a Betch!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jul 2004
    Vermont
    Quote Originally Posted by rmbbikes View Post
    Fair enough.
    Seriously, though - Passats are a prick to wire for remote starters. Has something to do with the alarm system and the specially cut keys. It was expensive enough that I decided running out to start the car and drinking coffee until it defrosts is the way to go.
    I'm still waiting for them to come up with one for my diesel pickup.....
    Just Registered wylee's Avatar
    Jul 2006
    Northern NH
    I have installed a few "ultra start" units and will be installing a couple more (the wife and I both got new cars in October) this weekend. They are pretty straight forward if the car doesn't have a transponder key. The hardest part is getting under the dash to make the connections. Bulldog security makes a T-harness for the ignition that will save some time but it's not worth it IMO.
    The units I have used in the past are good for about a 1/4 mile line of sight. The one I'm putting in the new cars are supposed to good for a 1/2 mile line of site.
    If you're installing one in a car that has a transponder key, I'd recommend a bypass kit that operates without a key instead of hiding a key under the dash. If you do end up doing the "hide a key" trick, PM me your address and I'll send you a 556u or whatever the fuck it's called. The one "hidden key" install I did was such a pain in the ass I ordered a bypass kit for the next time.
    Health nuts are going to feel stupid someday, lying in hospitals dying of nothing.
    Jul 2006
    Northern NH
    Ultra start has a glow plug delay option for diesels.
    Jul 2004
    Vermont
    Quote Originally Posted by wylee View Post
    Really.....
    PS - I like your sig line.
    KB KB's Avatar
    Manchester NH
    wylee.........................Highsider is a mother fucker is you consider riding a goat, horse, or his mouth quickly.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    KB KB's Avatar
    Manchester NH
    So uuh yeah great. Should I just pay the 600 for the passat...I doubt it.
    Anyone actually have any valuable info?
    Highsider you don't count so shut it BETCH.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jul 2006
    Northern NH
    Ya fuckstik. I'll give it another try.
    What year are the cars?
    The VW might be a PITA. It looks like you would have to at least take the drives door panel off and get in there with a multimeter or test light. The car has to think the drivers door has been unlocked for it to remote start. The factory remote keyless may not work when the car is running after you remote start it.
    BypassKit.com - Direct source for Bypass Kit and databus interface solutions: No Key Required <--- Look up your cars here. (upper right corner there is a vehicle selector)
    You should be able to order the bypasses you need from Autotoys.com.
    2003 Passat wiring with PICS
    Lifer reiobard's Avatar
    Jul 2005
    Bennington, NH
    I'll do the accent for you, just buy the parts you need, i will also look at the Passat but the only VW's that i have tried have a mess for wires that are all the same color and test the same. I know that they CAN be done and i have done 100's but always turned away VW's because they suck and my old work told us that we weren't allowed to do them in VW's. Also are either of the cars stick shift? If so i would recommend Compustar remote starts since they have the neutral bypass built in.
    PS: I think i am going to need new tires on my bike soon...
    Haverhill, MA
    KB,
    The Accent shouldn't be any problem for someone with a little electrical knowledge and some time and patience to get done.
    The Passat on the other hand........the VW tends to become an issue because of the transponder keys and various other electrical anomalies associated with the fact that it is a VW. The info you have received to this point is definitely accurate as far as that car being a pain in the ass to do. One of the last remote starts I wound up doing before I got out of that industry was a mid 2000s VW Jetta. I spent a lot of time working with the technical department of Directed Electronics trying to figure out why, even though I wired everything exactly as I was supposed to (verified through many tests by myself and others), this damn Jetta's remote start would work sometimes and then not work others. Eventually the customer wound up getting tired of the random electrical issues that were happening with the remote start installed and had it removed. My recommendation would be to not do the starter in the Passat.
    Highsider
    There are many different Diesel capable remote starts out there. I personally have experience with the Directed Electronics stuff and they are fantastic with the way they work. Typically what your going to want to have happen with the Diesel is a lead being tapped into the wait to start signal that will not allow the engine to start until that light is out. Alternatively some units use a timer that is set by the installer of the unit to wait a predetermined amount of time, allowing the glow plugs to heat up and the wait to start light to go out, then crank the vehicle to start it. The one major downside to the Diesels when remote started is the high idle that they run at when started cold. You wind up burning a ton of fuel because your truck is sitting there revving alot higher than a gas truck would by comparison. With the high price of Diesel you might be better off not remote starting it.
    Joel
    Just Registered beet's Avatar
    May 2002
    Meriden CT
    I got one in my Hyundia Accent. Put it in for the wife, i don't use it I start & drive.
    www.bostonmoto.com
    Forum Rules
    Southwick, Matachusetts :)
    I had one installed in my old Hyundai Elantra, and it messed up with the alarm...and the doors would automatically lock after a few seconds so you need to make sure to have an extra key hidden. PITA. I'll make sure they look into this when I have one installed on my Sonata.
    www.elementsofbalancemt.com
    www.facebook.com/misstwisties
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    I have one bought for an 2002 sienna if you want
    has the intellegent key lock out. Brand new in box wife decided no thanks
    What I did on my Ford E150 was to just clean the insulation without
    actually separating the stock wiring. JUst soldered in a jumper so the stock harnass was intack.. a little longer but its worked for 6 years no problem.
    Glen Beck is John the Baptist
    Jul 2004
    Vermont
    Wow, even beet makes more sense than you.
    May 2002
    Meriden CT
    www.bostonmoto.com
    Forum Rules
    KB KB's Avatar
    Manchester NH
    Thanks for the info folks.
    Rob I'll take you up on the offer to do the Accent. I'll give you a ring and we can talk about what i need to get.
    Thanks Joel.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Jul 2005
    Bennington, NH
    ok, just let me know.
  1. Remote Car Starter
    By MsHap in forum Off-Topic
    Last Post: 01-22-07, 07:34 PM
  2. car alarms... and remote starts.
    By oreo_n2 in forum Off-Topic
    Last Post: 08-05-04, 09:24 PM
  3. i wish they still made kick starters
    Last Post: 03-03-04, 05:02 PM
  4. Remote control Camry
    By zx-stewie in forum Off-Topic
    Last Post: 12-02-03, 09:23 AM
